1984 fleetwood brougham questions - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 30 of 30
Like Tree4Likes
1985-1996 Fleetwood and Brougham Forum Discussion, 1984 fleetwood brougham questions in Past Cadillac Vehicle Discussion; Originally Posted by zach1112 connects between the end of the fender and where the bumper bolts in, theyre little squares ...
  1. #16
    csbuckn is offline Cadillac Owners Master
    Automobile(s): 84 Coupe w/500
    Jan 2008
    Minneapolis
    5,614
    Re: 1984 fleetwood brougham questions
    Quote Originally Posted by zach1112 View Post
    Most people call them front fillers. You can get them on ebay or layitlow.
  2. #17
    zach1112 is offline Cadillac Owners Member
    Automobile(s): 1984 fleetwood brougham
    Mar 2012
    25
    14
    Quote Originally Posted by csbuckn View Post
    ah i wasnt exactly sure what they were called lol thanks for the help ill look around
  3. #18
    j2rossit is offline Cadillac Owners Enthusiast
    Automobile(s): 85 FW Brougham, 68 Wildcat 'vert, 92 & 96 Roadmaster Wagons
    Jan 2011
    Southern Ontario
    934
    Firing order: 18436572 odd #s in front counter clockwise rotation
    just to make sure, the front driver's side piston is #1, front passenger side piston is #2, second from front driver side is #3, second from front passenger side is #4. and back and forth like that.
    zach1112 and zach1112 like this.
  5. #19
    Mar 2012
    25
    14
    Quote Originally Posted by j2rossit View Post
    thank you, im gonna go out in a little while and make sure i have all the wires in the right places, i still have no idea why i have no power though i literally had the petal to the floor last night and it wouldnt go anywhere
    any ideas?
  6. #20
    Jan 2011
    Southern Ontario
    934
    What kind of plugs did you buy? most can't be adjusted and are pre-gapped. How did you select which ones you bought? I've found that some of the selection guides at the part stores for pre-gapped plugs can have mistakes in them. Under the hood there should be a sticker with the correct gap, mine is 0.060 inches. Look up on the manufacture's website to make sure that the plugs you bought were meant for this gap.
    And I took a look at my engine and on my passenger side is the AIR system control valve. It puts oxygen into the exhaust system to allow for more complete burning of the hydrocarbons I believe. It detects intake vacuum to control how much oxygen to put in and is hooked up to the air pump below the alternator.
  7. #21
    Mar 2012
    25
    14
    thanks man ill check everything out im getting so sick of car troubles haha first my fiances mazda took a shit on us and now my cadillacs doing the same
    i forgot to answer your question too my bad lol they were autolite plugs i cant remember the exact kind all i remember is they had copper like the original plugs
  8. #22
    Jan 2011
    Southern Ontario
    934
    I believe that autolites need to have the gap checked and can be gapped using standard gapping tools.
    if it has a v groove on the inside of the hooked electrode then they can't be gapped, but I don't think autolite has that.
  9. #23
    Mar 2012
    25
    14
    alright thanks man im gonna go down and pull all the plugs and make sure theyre gapped right
    i appreciate all the help
  10. #24
    jayoldschool's Avatar
    jayoldschool is offline GM RWD V8 addict
    Automobile(s): 81 FWB D'Elegance coupe
    Sep 2006
    Ontario, Canada
    44
    7,940
    While you are pulling the Autolites, get some AC Delcos and give the Ford plugs to someone else
  11. #25
    Jan 2011
    Southern Ontario
    934
    Here's a website to order new ones. I haven't used them but I've thought about picking some up since mine are on their way out.
    http://www.cadillaccraftcenter.com/fillers.htm
  12. #26
    Mar 2012
    25
    14
    thank you so much!
  13. #27
    Mar 2012
    25
    14
    Im such an idiot haha went out to work on the car today and found out i crossed the 2nd and 4th wire all is well now i just gotta fix my exhaust think i might hold out until i have the money to run duals though i looked underneath when i was working the other day and i definitely have enough room i just have to borrow a pipe bender and a welder off a friend lol
  14. #28
    Jan 2011
    Southern Ontario
    934
    We've all had our "finest" moments working on cars. I once spent a day on my back with heat, penetrant, impact driver, massive breaker bar..... trying to get the nut off of an engine mount bolt the first time I went to pull an engine. It was only after I took a good look at the nut that I realized it was spot welded on the mounting bracket and that you were supposed to just pull the bolt out from the other side. 10 mins later I had the engine up.
  15. #29
    Sep 2006
    Ontario, Canada
    44
    7,940
    Glad it worked out! Easy mistake to make.
  16. #30
    Mar 2012
    25
    14
    haha its always the dumbest things too, i do autobody work and back when i was living in jersey i was in a shop working on a ford f-150 taking the rear bumper off well i was fairly new to the job at the time and didnt know there was two bolts under the bumper that you take out to release it from the brackets so i spent about 4 hours trying to turn the bolts for the actual brackets to just take the whole assembly off not knowing that they were lock tighted in and not going anywhere without a torch until finally right before i took my lunch break one of the other guys came over and told me i was doing it completely wrong, that was one of the most ridiculous things i ever did probably lol
    Quote Originally Posted by jayoldschool View Post
    the worst part was i argued with my father in law for two days swearing that put em back in the right order and refusing to check and sure enough he was right lol
  17. Remove Advertisements
