84 Deville Stereo Install
Results 1 to 15 of 15
1985-1996 Fleetwood and Brougham Forum Discussion, 84 Deville Stereo Install in Past Cadillac Vehicle Discussion; Just wanted to make a thread about the install that I'm doing in the 84 Coupe Deville. Had to cut ...
    csbuckn is offline Cadillac Owners Master
    Automobile(s): 84 Coupe w/500
    Jan 2008
    Minneapolis
    5,612
    Just wanted to make a thread about the install that I'm doing in the 84 Coupe Deville. Had to cut the center bezel since it has the radio that the knobs go through the bezel.
    You can see that there is no room for a single din unless you cut the opening wider. You have to remove the top vents to get to two screws behind them, vents pop out with a flathead in the tabs inside of them. They must be pointing up or down to slide out.
    Old radio was easy enough to get out, dont forget the screw far back and below, this one didnt have a screw there.
    My old radio was labeled incase you need to hard wire. The Memory wire is on a seperate harness.
    Behind the radio, doesnt look like it here but there is plenty of room for a stereo. The stock radio is one of the biggest car stereos I've ever seen.
    Rough cut just inside what is needed, used sandpaper on the dremel to finish. I used a dremel with a cable attachment.
    I really wanted a nice finish so I took my time to finish the cut. Turned out pretty good. The cage is the only thing that holds it in place but, if you bend the tabs correctly, it sits very tight. I dont think I'm gonna have any issues with skipping over bumps.
    Thats as far as I've made it because I dont have the wiring harness to plug into the stock harness yet. I'll finish tomorrow.
    jayoldschool's Avatar
    jayoldschool is offline GM RWD V8 addict
    Automobile(s): 81 FWB D'Elegance coupe
    Sep 2006
    Ontario, Canada
    44
    7,894
    Re: 84 Deville Stereo Install
    You need a trim ring on that cage.
    Jan 2008
    Minneapolis
    5,612
    And its killing me. It didn't fit after the install in the 90 but I thought I kept it, can't find it. Ill take it off my other car for final pictures.
    AElayyat's Avatar
    AElayyat is offline Cadillac Owners Connoisseur
    Automobile(s): 85 Fleetwood Brougham, 90 Brougham 5.7, 05 Deville DTS
    Feb 2004
    So. Cali
    35
    1,135
    Looks good so far.
    I had an aftermarket CD player installed in my 85 Fleetwood Brougham & had the shop do all the cutting. Previous owner installed an aftermarket Sony tape player that died out on me & the wire harness was cut...long story short who ever installed the Sony hard wired it instead of using a harness.
    Jan 2008
    Minneapolis
    5,612
    Got it all together. Best Buy didn't sell trim rings but he had an extra. Got lucky there.
    Got the wiring done. Trying those grey twist on caps at the connections, hope they work well, they twisted on very tight. The extra connection is the constant, they didn't fit together so it needed to be hardwired. Orange wire not connected to anything.
    Clean install.
    outsider is offline Cadillac Owners Connoisseur
    Automobile(s): 87 Brougham, 1969 Calais, 95 FWB, 05 CTS, 07 SRX
    Sep 2009
    Buxton, Maine, United
    33
    4,149
    wow good install! enjoyed the pictures
    Jan 2008
    Minneapolis
    5,612
    Thanks. The trim ring is bigger than I would like but it looks nicer than without it. There is a small trim ring that covers pretty much just the cage but I'm not too worried.
    Benzilla's Avatar
    Benzilla is offline Cadillac Owners Connoisseur
    Automobile(s): 1979 Phaeton Coupe, 1990 Brougham d'Elegance 5.7 liter
    Oct 2005
    Chattanooga, TN
    4,416
    Looks nice, when I did the radio in my '83 I got a special bracket from crutchfield.com that made the radio fit very securely. It basically just screwed into all the places the factory one did, and had a platform of sorts for the new radio to go in. I think I lost about three screws in the dash trying to get that rear clip to line up & get a screw back there, lol.
    Are you planning to upgrade the speakers?
    Faded Crest's Avatar
    Faded Crest is offline Cadillac Owners Connoisseur
    Automobile(s): '66 SDV, '76 CDV, '89 BRM, '92 BRM, '98 Concours, '00 SDV
    Apr 2008
    North Carolina
    45
    3,222
    I would be tempted to pain the little remnant of wood grain plastic on either side black to blend it all in.
    Jan 2008
    Minneapolis
    5,612
    I have some pioneer 3-ways for the front but the stock ones work decently so ill be lazy about putting them in. For the woodgrain, ill keep it like that till I find the smaller trim. Ill post here when I get the front speakers in.
    1980coupe's Avatar
    1980coupe is offline Cadillac Owners Connoisseur
    Automobile(s): 78 CDV, 79 CDV delegance, 80 CDV, 80 FWB 2dr delegance (rip)
    Jan 2009
    El Paso, TX
    39
    1,150
    Looks good.
    When I installed my radio, no may was I going to cut the bezel out for the radio, I wanted to keep the original look of the stereo casstte. So what I did is I placed it in the glove box. I cut out a piece of the glovebox liner and ran the wires thru there. When it is not in use, I just close the glovebox and looks all factory. Besides, the clock on the original radio still works.
    greencadillacmatt's Avatar
    greencadillacmatt is offline Cadillac Owners Connoisseur
    Automobile(s): '09 Dodge Challenger RT, '84 Cadillac CDV, '94 Jeep GC LTD
    Sep 2008
    Otsego,Michigan
    26
    2,239
    The back speakers are SUPER easy to get to. I just layed down in the trunk and installed. It's just a few clips and they're in!
    Jan 2008
    Minneapolis
    5,612
    After putting the carpet in, I turned on the stereo just to here a back speaker popping. I guess they'll have to come out the 90. I'm just glad I havent got rid of the 90 yet. It saved me last night for a seatbelt bolt and now for the rear speakers.
  16. #14
    Mark 78 Coupe is offline Cadillac Owners Enthusiast
    Automobile(s): 1978 Coupe De Ville, 1993 Fleetwood
    Sep 2011
    Cleveland/Ft. Myers Beach FL.
    58
    528
    Quote Originally Posted by 1980coupe View Post
    Looks good.
    I agree. When I get the replacement for my 78, I am also going the glove box route. I even got a junkyard box to cut up so I can still have the original if I choose to ever remove the aftermarket unit. And, by the way, for someone who chose to go the in dash route, excellent job. Patience is certainly a virtue!!
  17. #15
    1980coupe's Avatar
    Jan 2009
    El Paso, TX
    39
    1,150
    Quote Originally Posted by Mark 78 Coupe View Post
    I got an extra glovebox liner myself too...buy the adapter wires for your cars wiring to the radios wiring, that way you wont cut up the wiring..
  18. Remove Advertisements
