Vacuum line diagram help!
Results 1 to 14 of 14
1985-1996 Fleetwood and Brougham Forum Discussion, Vacuum line diagram help! in Past Cadillac Vehicle Discussion; I replaced my valve covers on my 368 motor did not take pictures of the vacuum lines. Now I have ...
    1981CadillacDeville is offline Cadillac Owners Member
    Oct 2011
    15
    I replaced my valve covers on my 368 motor did not take pictures of the vacuum lines. Now I have no power brakes and the e brake does self eject. Need pictures of your engine bay!
    I figured out the brakes and ebrake one but still need help on others. I'll post pics of what I need when I get home
    sven914's Avatar
    sven914 is offline Cadillac Owners Connoisseur
    Automobile(s): 1989 Brougham d'Elegance, 1985 Fleetwood Brougham *Coupe*
    Dec 2008
    4,256
    Re: Vacuum line diagram help!
    I can't help with the diagram, but I can offer some helpful advice...
    First, acquire a factory service manual. You can get them for cheap on eBay; here is a list of auctions. The manual should have the vacuum routing.
    Second, color code you hoses. I replaced all of mine a few years ago and color coded them with paint markers, and now I know exactly where they all go.
    Oct 2011
    15
    Thank you for the advice sven. I will def do that next time.
    Fleetwood70 is offline Cadillac Owners Fanatic
    Automobile(s): 1970 Fleetwood 60-Special, 03 DHS
    Jan 2011
    27
    142
    Quote Originally Posted by 1981CadillacDeville View Post
    Isn't that a washer pump hose, not a vacuum line?
    SafariOne is offline Cadillac Owners Fanatic
    Automobile(s): 1981Cadillac Fleetwood Brougham D'Elegance Coupe m
    Mar 2008
    British Columbia
    392
    One looks like EGR valve and one looks like pcv or to air management valve.
    sven914's Avatar
    Dec 2008
    4,256
    ^Right. There's a gaping hole in the valve cover, where the PCV valve is supposed to go. The hose with the metal clip goes to that.
    Oct 2011
    15
    The hole is where my oil cap goes. That hose does not have enough slack to make it that far to the PCV. Does anyone have any detailed pictures of their engine compartment???
    csbuckn is offline Cadillac Owners Master
    Automobile(s): 84 Coupe w/500
    Jan 2008
    Minneapolis
    5,614
    I Dont have a picture but I believe that hose is still gonna be the pcv, especially if its a hard hose. Maybe the pcv is supposed to be on that side and the oil cap is supposed to be on the other you can try switching the pcv and grommet to the other side. If that hose is hard and ends right at the hole, its for pcv. Or maybe you can rotate the hose to the other valve cover.
    outsider is offline Cadillac Owners Connoisseur
    Automobile(s): 87 Brougham, 1969 Calais, 95 FWB, 05 CTS, 07 SRX
    Sep 2009
    Buxton, Maine, United
    33
    4,179
    That hose with the clip looks like it goes in the front of the carb (atleast there's one like that on my 87's carb)
    lol ignore that, just realized the air filter cover says digital fuel injection
    sven914's Avatar
    Dec 2008
    4,256
    I thought the oil cap went on the driver's side. Pretty awkward place with that hose there.
    Robin Banx's Avatar
    Robin Banx is offline Cadillac Owners Enthusiast
    Automobile(s): 1983 FWB (Mac), 1981 SDV (Junkyard Dog)
    Dec 2007
    Vancouver, B.C. Canada
    722
    Oil cap is on the right cover. PCV valve has a rubber elbow and lays horizontal on the right cover and goes to throttle body. That is a very nice engine room. It should be relatively easy to get the vacuum lines back in place. Except for the w/s washer line.
    Cheers....R.
    Isaias Camacho is offline Cadillac Owners Member
    Automobile(s): Cadillac Sedan Deville, 1981 , metalic brown colour #100060
    Jun 2012
    South Africa
    5
    Air Management Valve
    Hi there
    I'm in a pickel with my 1981 cadillac 4-6-8. My dad bought the Caddy way back in '81, and braught it to South Africa. due to the fact there was no Unleaded Fuel in South Africa at that time -we have the Cat - removed.
    Then about 7 years ago the caddy wasnt performing as well and a machanic that swore he knew what he was doing -tried to repear it. Well, it hasnt worked since then! I took ownership about 3 years ago, and i found out the the guy removed the Air management valve (well i think its called that), and i subsequently found it in some boxes just last week!
    The problem is i dont know where all the pipes go to on this Air Managemet Valve unit - this is why i have attached a picture with numbers and arrows - hoping someone can help.
    1- Air Management Valve Unit?
    a- where do all these yellow arrowed pipes lead too or from?
    2-where does this 2-pin green plug -plug into?
    3-what is that housing unit the pipes is attached to?
    4-what is that gold-like ring ? and where does this pipe specifically go to?
    5- these plastic conectors / vacuum units - what exactly is happening here?
    if you want i can mail anyone a clearer picture if thy want, but i was hoping someone can assust in the interim.
    many thanks
    Isaias
    Jun 2012
    South Africa
    5
    that pipe coming from the throttle body comes goes to a fitting tht is insetered in to the hole right by your finger in the picture. i dont know what you cal it but it is long enough withthe fitting attached to it .
  16. #14
    4-6-8 81Caddydeville is offline Cadillac Owners Member
    Automobile(s): None
    Jul 2014
    None
    1
    hey bro that one goes to the washer fluid tank i have the same engine
    Good Morning, Your CF account is activated. Please update your profile to show correct information and time zone - or do you really live in London - GMT ?
    This thread has been dead for just over 2 years - only two of the original posters are still active.
  17. Remove Advertisements
