1967 Coupe Deville - Replacing Mono AM-FM with *Stock* Cadillac Stereo
Results 1 to 6 of 6
1985-1996 Fleetwood and Brougham Forum Discussion, 1967 Coupe Deville - Replacing Mono AM-FM with *Stock* Cadillac Stereo in Past Cadillac Vehicle Discussion; Hello All, I recently purchased a 67 Coupe Deville. The stock (mono) AM-FM radio that is in the car currently ...
    polaris26 is offline Cadillac Owners Member
    Automobile(s): 1967 Coupe DeVille
    Aug 2011
    Pennsylvania USA
    13
    Hello All,
    I recently purchased a 67 Coupe Deville. The stock (mono) AM-FM radio that is in the car currently doesn't work. I have an opportunity to purchase a 1967 Cadillac *Stereo* AM/FM radio with the separate amplifier module. My question is: How much work would it be for me to "upgrade" my car to the optional stereo model radio? Did the stereo model have two speakers (in the rear I am assuming), or four speakers, like a modern car would? Can I use any modern style speakers or do they have any special specs I need to be aware of? Where does the amplifier mount? Is this retrofit any more difficult than installing the typical aftermarket stereo?
    thanks in advance,
    Dave
    77CDV's Avatar
    77CDV is offline Cadillac Owners 10000+ Posts
    Automobile(s): 77 CDV, 06 DTS III, 69 FWB
    Mar 2006
    Newbury Park, CA
    45
    10,021
    Re: 1967 Coupe Deville - Replacing Mono AM-FM with *Stock* Cadillac Stereo
    Dave,
    This is GM we're talking about. Swapping in the factory stereo is easy. There are four speaker, two front, two rear. The hardest part will be finding a stereo dash pad to replace the mono dash pad in the car now. The amplifier mounts behind the dash, just to the left of the glove box IIRC. After that, it's just a matter of wiring up the speakers. The factory speakers for these cars tend to have a lower resistance than most modern aftermarket speakers. The exact specs should be in the 1967 FSM. They can be a bit pricey, but they're worth it, since using speakers with higher resistance will eventually blow the radio's transistors.
    Good luck with your swap!
    Craig
    Aug 2011
    Pennsylvania USA
    13
    Hi Craig - thanks for the info. Assuming I can find the right dash pad, would that be more work than it's worth vs. say putting speakers on the side panels under the dash like a lot of cars have for aftermarket stereos? Dollar-wise, between the dash pad, the vintage stereo radio itself, the extra (correct) speakers, this "upgrade" would add up to quite a lot of cash outlay, so maybe it's not even worth doing. Sounds like just as much work and expense as putting in a modern sound system. The only plus would be it would be what the car would have had stock if it had had that AM/FM stereo option. I looked at the dealer option list for the 1967 DeVille Stereo AM/FM radio and it is listed for $288 in 1967 dollars! This would be about $1900 today!
    On the other hand, I have seen modern radios with mp3 inputs that fit the existing Cadillac dashboard and control layout (the 'Custom Autosound' models). Does anyone have experience with these?
    thanks,
    Dave
    77CDV's Avatar
    Mar 2006
    Newbury Park, CA
    45
    10,021
    A lot of guys do the modern radios with the two front speakers concealed under the mono radio front speaker grille. It lacks a bit for bass, but the overall sound quality is acceptible. I'm personally against cutting kick panels or door panels as it destroys the originality of the car and IMO looks hoopty. Whatever you decide to do, make sure it's all easily undone, or the car will be forever dead to the serious collector.
    cadillac kevin's Avatar
    cadillac kevin is offline Cadillac Owners Master
    Automobile(s): chevy 350 powered 86 FWB, 00 safari h.t. 66 toro, 83 lesabre
    Dec 2010
    St. Louis, MO
    6,395
    ^I agree. whatever your decision, do not hack up the doors or kick panels. I've seen it done so many times and it never looks even remotely tasteful or original.
    CADforce69 is offline Cadillac Owners Connoisseur
    Automobile(s): Cadillac Sedan de Ville 1969, Dodge 3700GT '73, Audi A3 1.8T
    Oct 2010
    Madrid (Spain)
    49
    1,634
    My 69 had such a kind of adaptation. Originally had the AM/FM stereo with 4 speakers (radio is dead). Most probably front speakers stopped working properly and new mid 70s were installed on the kick panels. It looked a botched job so I took them out and restored kick panels when I did interior. If you have the mono pad and don´t want to change it, one option is installing 2 front speakers under the dash, looking down. Holes for screws would be out of sight and they can be easily uninstalled in the future.
    I´m considering installing one of these modern-classic radios on my caddy: http://www.ebay.com/itm/69-70-71-72-...sories&vxp=mtr They can keep the exterior original appearance of your car´s radio with a modern mechanism, including a direct input for all modern sound devices.
  9. Remove Advertisements
