Climate Control Switch
Results 1 to 7 of 7
1985-1996 Fleetwood and Brougham Forum Discussion, Climate Control Switch in Past Cadillac Vehicle Discussion; On my 91 Brougham, a problem recently came up with the climate control. Whenever I go to press AUTO, it ...
    mcgovernmatt's Avatar
    mcgovernmatt is offline Cadillac Owners Member
    Automobile(s): 1991 Cadillac Brougham d'Elegance
    Sep 2007
    Ludlow, MA
    36
    Whenever I go to press AUTO, it immediately swtiches back to ECONOMY.
    anyone else ever get this?
    brougham is offline Cadillac Owners Master
    Automobile(s): 1991 Cadillac Brougham D'Elegance 5.7 Litre, 1994 DeVille
    Jun 2003
    Canada
    6,477
    Re: Climate Control Switch
    It means your air conditioning has a leak and doesn't work.
    Automobile(s): 1999 BMW 740 Il. 2005 Jag XK8, 1988 Mercedes Benz 300 SE
    Feb 2003
    california
    69
    6,688
    In other words, its too low on freon and the ECU wont provide the ground signal to the compressor clutch. Designed in to protect the compressor.
    drmenard is offline Cadillac Owners Connoisseur
    Automobile(s): 95 FWB 81SDV 96 FWB 94 Fleetwood
    May 2003
    Massachusetts
    1,201
    I don't buy that theory..I have had many cars short cycle when low on freon... this never changed the setting on the dash... If you were right , to prove your theory all you would have to do is take the wire off the pressure switch on the compressor and ground it.. Now , if you are right , it will stay on AUTO and not shift off..I have had a ton of problems with these CC units... I think your problem is in the dash cc control..
    Feb 2003
    california
    69
    6,688
    To Verify go into diagnostics and confirm an A/C related code.
    Jun 2003
    Canada
    6,477
    When it is low it will still cycle and stay on auto. If it gets too low it wont and switches back to econo. All Cadillac models from that era do that. The only difference between auto and econo is auto runs AC when it's needed and econo doesn't.
    Feb 2003
    california
    69
    6,688
    The difference between low freon and too low has to do with ambient temperature in the car. If set to 60 and its 85 in the car, it will most likey defer to econ. if set to 75 and its 73 in the car, it will stay in auto and cycle the compressor.
  10. Remove Advertisements
