Fuse box question
Results 1 to 8 of 8
1985-1996 Fleetwood and Brougham Forum Discussion, Fuse box question in Past Cadillac Vehicle Discussion; hey i was just wondering if all my fuses are correct. ok first i have an 89 brougham. while checking ...
    Caddylover86 is offline Cadillac Owners Member
    Automobile(s): 1989 Fleetwood Brougham
    Apr 2011
    56
    Fuse box question
    hey i was just wondering if all my fuses are correct. ok first i have an 89 brougham. while checking all my fuses i noticed the one that says COMP requires a 20amp fuse. well there isnt any metal contacts in that slot like all the other ones. its just an empty space. also my ALDL is all crazy, i tried to jump the terminals to get the codes and the slot are all diffrent ie the ground is not where it should be and so forth. lastly ive noticed a few of my idiot lights dont work(bulbs are new) could this all be connected somehow, and if so how do i fix it.
    cadillac kevin's Avatar
    cadillac kevin is offline Cadillac Owners Master
    Automobile(s): chevy 350 powered 86 FWB, 00 safari h.t. 66 toro, 83 lesabre
    Dec 2010
    St. Louis, MO
    6,395
    Re: Fuse box question
    the computer slot should not have a fuse in it.
    also which idiot lights aren't working?
    sven914's Avatar
    sven914 is offline Cadillac Owners Connoisseur
    Automobile(s): 1989 Brougham d'Elegance, 1985 Fleetwood Brougham *Coupe*
    Dec 2008
    4,256
    The bulbs not working is more than likely an issue with the printed circuit; mine is doing the same thing so I wired the non functional lights to the ones I don't need. You can probably get another printed circuit from a junker, but I'm not sure how easy it is to swap.
    How did you determine that the ALDL ground terminal is not grounded? When you look at the connector, is there a raised notch on the top of the connector? If the notch is on the bottom, then the connector is upside down.
    Apr 2011
    56
    level ride doesnt work i think the compressor has been unhooked. check engine light, trunk open light, and a few others
    Apr 2011
    56
    ill check to see if it was put back on upside down and try to post a good pic. pretty much from what i can see inside the aldl there are only 4 maybe 5 actual pins inside it. all the others are empty and as a side not when i took it to the shop i take all my cars to they said the couldnt get their obd1 tool to talk with my cars computer...if that makes sense.
    sven914's Avatar
    Dec 2008
    4,256
    If the check engine lamp is not functional, you can't pull DTC's without a scanner. Jumping the terminals on the ALDL makes the check engine light flash the codes. In your case though, you may need to replace the ALDL or find some other way of tapping into the wires that go into the back of it.
    I lost the level ride, check engine, and washer lights. The check engine light is the most important, so I wired the coolant temp lamp to come on as the check engine light. I have an aftermarket coolant gauge, so I don't need the light anymore.
    There is also a slot for the "Stop Engine Temp" lamp, which was used with a block temperature sensor (the 307 isn't equipped with that sensor, so slot on the telltale is a dead hole). I don't know the wire colors for that bulb, but you could wire the check engine lamp to the engine temp slot and that way you would have diagnostic capabilities.
    csbuckn is offline Cadillac Owners Master
    Automobile(s): 84 Coupe w/500
    Jan 2008
    Minneapolis
    5,613
    So you couldn't just take a bulb from another spot and put it in the check engine spot?
    sven914's Avatar
    Dec 2008
    4,256
    In my case, the printed circuit isn't supplying ground to the bulbs (the contacts wore off), so no matter how new the bulb is, it will never light.
  11. Remove Advertisements
