Aligning the trunk lid
Results 1 to 8 of 8
1985-1996 Fleetwood and Brougham Forum Discussion, Aligning the trunk lid in Past Cadillac Vehicle Discussion; I'm trying to adjust the trunk lid on my '68 DeVille Convertible. The lid fits well (apparently) everywhere except the ...
    cadillacbart is offline Cadillac Owners Fanatic
    Automobile(s): 1968 DeVille Convertible (current project)
    May 2005
    Thornton, CO
    157
    I'm trying to adjust the trunk lid on my '68 DeVille Convertible. The lid fits well (apparently) everywhere except the right corner where it meets the bumper. It's high on this side, and theres even a small gap where the new weatherstrip doesnt reach it on the right side, near the back (I climbed in the trunk and light was shing through here).
    Any tips on bringing this corner down? Maybe 1/4 inch, 1/2 inch max.
    Thanks for your input,
    John
    jayoldschool's Avatar
    jayoldschool is offline GM RWD V8 addict
    Automobile(s): 81 FWB D'Elegance coupe
    Sep 2006
    Ontario, Canada
    44
    7,894
    Re: Aligning the trunk lid
    Open the trunk, place a block of wood half way between the high corner and the latch, lower the lid, press down on the corner of trunk. Remove wood, close trunk, repeat until fit is perfect.
    May 2005
    Thornton, CO
    157
    Really? I give it a try tonight! I'll let you know how it comes out.
    Thank you.
    CadillacPimpinNOLA is offline Cadillac Owners Connoisseur
    Automobile(s): 1995 Fleetwood 1968 coupe DeVille
    Jul 2009
    Metairie/New Orleans,LA
    32
    1,152
    yep, thats why he has oldschool in his name, that is old school technique that still is used all the time, also you may require a BFH but the wood should do the trick
    May 2005
    Thornton, CO
    157
    Well, the block of wood trick worked pretty well. Still not enough. I can still see daylight- ever so slightly- through the weatherstripping at a couple of points in that side (looking from inside the closed trunk). I think the quarter may actually be a little low. I should have caught that before paint. Oh well too late to beat that quarter up. I'm hoping to find a weatherstrip with a higher profile. Don't want water in that trunk, I'm not patching that floor again!
    John
    Sep 2006
    Ontario, Canada
    44
    7,894
    To bring the weather strip up, remove the weather strip, clean the area, apply adhesive backed flat weather strip foam to both sides of the pinch to the height desired, apply weather strip adhesive, then the weather strip on top of the foam.
    Wait, is this old weather strip, or brand new? If old, replace with new first!
    May 2005
    Thornton, CO
    157
    Great idea! The weatherstrip is new, but I've already glued it in. I may have to relace it depending how well it comes out. I suspect it will tear, it's been in for about 2 months.
    Sep 2006
    Ontario, Canada
    44
    7,894
    You should be able to get it out if you are careful. That adhesive is pretty gummy.
  11. Remove Advertisements
