1986 Fleetwood Brougham engine swap
Page 1 of 2 12 LastLast
Results 1 to 15 of 17
1985-1996 Fleetwood and Brougham Forum Discussion, 1986 Fleetwood Brougham engine swap in Past Cadillac Vehicle Discussion; hey guys im a new member here, I have a 2006 DTS performance and I just bought a 1986 Fleetwood ...
    caddytat is offline Cadillac Owners Member
    Automobile(s): 06 DTS, 86 Fleetwood Brougham
    Aug 2011
    30
    4
    hey guys im a new member here, I have a 2006 DTS performance and I just bought a 1986 Fleetwood Brougham with the 5.0. I really want to put in a bigger engine for a little more power. What would be the easiest, most reliabe engine to put in it? (350, 403)
    thanks alot
    andy
    outsider is offline Cadillac Owners Connoisseur
    Automobile(s): 87 Brougham, 1969 Calais, 95 FWB, 05 CTS, 07 SRX
    Sep 2009
    Buxton, Maine, United
    33
    4,192
    Re: 1986 Fleetwood Brougham engine swap
    350 seems to be most common on them since it was an option (tow package i think)
    jayoldschool's Avatar
    jayoldschool is offline GM RWD V8 addict
    Automobile(s): 81 FWB D'Elegance coupe
    Sep 2006
    Ontario, Canada
    44
    7,982
    The 350 that was an option in 90-92 was a Chevy 350, not Olds.
    So, a straight bolt in, using all your accessories would be anything from the Olds family. 350, 403, 455. There are a couple threads around here where others have swapped in the the Olds 350.
    Aug 2011
    30
    4
    Thanks for the replies....I will have to do a search (I know prob should have done that in the first place but I'm lazy). Is there significantly more power in say the 455 or 403 than the 350 to make it worth it. Also out of the three sizes which one is most reliable. Thanks.
    cadillac kevin's Avatar
    cadillac kevin is offline Cadillac Owners Master
    Automobile(s): chevy 350 powered 86 FWB, 00 safari h.t. 66 toro, 83 lesabre
    Dec 2010
    St. Louis, MO
    6,397
    any of them are reliable. they're all well built. the pre '73 455 will give you the most power (about 370-400 hp and 500+ ft/ lbs of torque)
    the pre 73 350 will give you 300 hp and 350 ft/lbs of torque.
    both will require swapping your transmission for one that can handle more powr (turbo 350 for the 350, turbo 400 for the 455)
    the 403 is kind of weak on power (200 hp IIRC), although with enough budget it can become one hell of a high power motor.
    csbuckn is offline Cadillac Owners Master
    Automobile(s): 84 Coupe w/500
    Jan 2008
    Minneapolis
    5,618
    I'm starting to think that a simple swap of the carb would be a huge difference. If you have a carb, put it on without all the emissions stuff. I think you would have to change the dizzy also.
    Dec 2010
    St. Louis, MO
    6,397
    the CCC carb isnt the problem (although it could benifit from a better than factory tune).
    the problem lies in crappy head design (swirl port), a wimpy camshaft, and a junky intake. by upgrading those 3 things, its possible to go from about 140 hp to 200hp.
    Jan 2008
    Minneapolis
    5,618
    Well, I put together an Olds 350 with a RV/Torque cam, 77 heads and an iron intake.....put all CCC stuff back on and it felt pretty much the same. I think the CC carb is the biggest factor in this motor.
    sven914's Avatar
    sven914 is offline Cadillac Owners Connoisseur
    Automobile(s): 1989 Brougham d'Elegance, 1985 Fleetwood Brougham *Coupe*
    Dec 2008
    4,256
    Quote Originally Posted by cadillac kevin View Post
    That's my plan; 350 heads and intake, and a 403 carburettor. With all that, you can't do any worse than the VIN 9 307 (180hp).
    N0DIH's Avatar
    N0DIH is offline Cadillac Owners Master
    Automobile(s): 94 Fleetwood Brougham
    Aug 2004
    Rockford, IL
    50
    7,531
    Weight out the costs, go look at a 5.3L with 50k miles or so on it from the boneyard. I have seen some for as low as $300. Grab the trans too. You get a modern drivetrain for far less than you can build an old school engine from scratch.
    Hence why my LT1 in the garage just sits....
    Aug 2011
    30
    4
    well i found an olds 403 pretty cheap....a mechanic buddy told me if I put a better shift kit in the stock tranny it should be able to handle the power. Is that true? also what carb setup should I go for? thanks again for all the help
    sven914's Avatar
    Dec 2008
    4,256
    I wouldn't trust it. The stock transmission is pretty weak, and the 403 will put out a lot of power. I would get a Chevy TH700 transmission, which is more durable, and you will still have overdrive.
    ChatWithaNinja is offline Cadillac Owners Member
    Automobile(s): 1986 Fleetwood Brougham d'Elegance
    Feb 2011
    13
    And for my first post ever:
    What kind of labor and fabrication does a TH700 transmission require?
    I ask because I am looking into the same thing with my 86 FWB (and my name is also Andy. Odd eh?).
    Right now I am looking for a good used 350 - non-web mains, so pre 77, right? ACtually, when reading this site, they say that the webbed mains won't really be a hindrance as I am not looking for super power, just a good reliable block with more than the 140 the car came with. http://oldsjunction.classicoldsmobil...ks 1964 - 1990
    And here is a link for the OP on the 403 VS the 350
    http://oldsjunction.classicoldsmobil...st Small Block
  16. #14
    sven914's Avatar
    Dec 2008
    4,256
    The driveshaft would need to be custom fitted (you can get one from a '90-92 Brougham with the 350, but it may not fit right with the Olds motor), and the support beam under the transmission needs to be moved. The TH700 should have a universal (BOP) bell-housing, so you don't need an adapter.
  17. #15
    Sep 2006
    Ontario, Canada
    44
    7,982
    TH700R4 does not have the dual pattern bell housing like the TH200-4R. You will need an adapter plate (BOP to Chev) to mount the trans. Available from Jegs, Summit, etc.
  18. Remove Advertisements
