My 4 brl carb quit
Results 1 to 9 of 9
1985-1996 Fleetwood and Brougham Forum Discussion, My 4 brl carb quit in Past Cadillac Vehicle Discussion; Hi all just wondering what to check for when a 4 brl carb doesn't open all 4 only the top ...
    Angelo Gargarello is offline Cadillac Owners Member
    Automobile(s): 86 cadillac fleetwood brougham
    Jun 2011
    Melvindale, Michigan, United S
    23
    27
    My 4 brl carb quit
    Hi all just wondering what to check for when a 4 brl carb doesn't open all 4 only the top smaller 2 are opening any advice other than get a new one..
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Re: My 4 brl carb quit
    I assume your car has vacuum secondaries. Vacuum secondaries will only open under load.
    cadillac kevin's Avatar
    cadillac kevin is offline Cadillac Owners Master
    Automobile(s): chevy 350 powered 86 FWB, 00 safari h.t. 66 toro, 83 lesabre
    Dec 2010
    St. Louis, MO
    6,395
    the secondaries will only open when under WOT above 30 mph (or so).
    if they are not opening under those conditions, you have a vacuum issue.
    Fleetwood70 is offline Cadillac Owners Fanatic
    Automobile(s): 1970 Fleetwood 60-Special, 03 DHS
    Jan 2011
    27
    142
    Check the choke mechanism, if it doesn't open the choke fully when engine is warmed up, the secondaries won't open either.
    Dec 2010
    St. Louis, MO
    6,395
    btw angelo- pick yourself up a FSM for an '86 fleetwood brougham. they're immensly helpful and worth the $15 or so you'll pay for one. just make sure its the final edition (black cover). it has a large section on the carb.
    according to the FSM, you need to check and replace split, cracked, or worn vacuum hoses. (replace 1 hose at a time)
    sven914's Avatar
    sven914 is offline Cadillac Owners Connoisseur
    Automobile(s): 1989 Brougham d'Elegance, 1985 Fleetwood Brougham *Coupe*
    Dec 2008
    4,256
    I would replace all of the vacuum lines. If one has gone bad, from age, then the others aren't too far behind, and you could have multiple leaks. The most important thing is rerouting the hoses to their factory original locations.
    Here's a diagram:
    cadillac_al is offline Cadillac Owners Connoisseur
    Automobile(s): 70 Deville 77 Fleet 78 Seville 92 Deville 03 Deville
    Feb 2007
    Maine
    55
    3,310
    Most likely the choke is just out of adjustment. If the choke doesn't open all the way the secondaries won't open. If you know any drag racers they could adjust it in 3 minutes flat.
    ChiTDI is offline Cadillac Owners Member
    Automobile(s): '86 Brougham
    Mar 2004
    54
    Quote Originally Posted by cadillac kevin View Post
    Your lucky day. I have a Haynes and an FSM for an '86 that has left our family for the recycler.
    Books are free you pay postage. PM me.
    Jun 2011
    23
    27
    thanks all that commented I changed them all reconnected and the past owner had one of them cut and shoved a screw in it but on the bright side I got on the free way and I felt her open all 4 the sound and feeling was amazing thank to all of you
  12. Remove Advertisements
