brake light
Results 1 to 3 of 3
1985-1996 Fleetwood and Brougham Forum Discussion, brake light in Past Cadillac Vehicle Discussion; 90 brougham, warning brake light been on all week brake fluid good did have a small leak under the drivers ...
    lincolncadillac's Avatar
    lincolncadillac is offline Cadillac Owners Member
    Automobile(s): 1990 Brougham, 1989 Brougham
    Mar 2011
    Kingsland GA / Jacksonville FL
    47
    83
    brake light
    brake fluid good
    did have a small leak under the drivers door about 2 months ago, but doesnt appear to be leaking now.
    brakes are working fine
    some times when I press the brake it disappears
    ...master cylinder?
    ...air in system?
    just now starting to drive this car every once in a while since I got it, starting to find out what happens to a car after it sits for 2 years
    sven914's Avatar
    sven914 is offline Cadillac Owners Connoisseur
    Automobile(s): 1989 Brougham d'Elegance, 1985 Fleetwood Brougham *Coupe*
    Dec 2008
    4,256
    Re: brake light
    Check and make sure the parking brake is not partially engaged. Then check the connector on the combination valve for for corrosion, and make sure the terminals aren't shorted out.
    jayoldschool's Avatar
    jayoldschool is offline GM RWD V8 addict
    Automobile(s): 81 FWB D'Elegance coupe
    Sep 2006
    Ontario, Canada
    44
    7,931
    Re: brake light
    You have a leak. Leaks don't go away. line is rusted through under the doors, up on top of the frame. Very common with these cars. Get the car up in the air, find the leak, cut the line, fix it, and bleed the system. Flare the tubing properly, don't use compression fittings. Once you get pressure back and equalized, your light will go off.
