1970 Deville coupe 472 Belt problems...
Results 1 to 12 of 12
1985-1996 Fleetwood and Brougham Forum Discussion, 1970 Deville coupe 472 Belt problems... in Past Cadillac Vehicle Discussion; Tried to use the search function, but it brought me to this section. This year requires 3 belts. 2 for ...
    tibert11 is offline Cadillac Owners Member
    Automobile(s): 70 DeVille Coupe
    Aug 2011
    31
    8
    Tried to use the search function, but it brought me to this section. This year requires 3 belts. 2 for the PS and AC and 1 for the alt and water pump. If im not mistaken. Well I can not find anywheres of how to run them, no picture diagram or anything. The belts popped so I could not reffer to the car as a guide. Any information would be helpful at this point.
    Kind regards,
    Trey
    Fleetwood70 is offline Cadillac Owners Fanatic
    Automobile(s): 1970 Fleetwood 60-Special, 03 DHS
    Jan 2011
    27
    142
    Re: 1970 Deville coupe 472 Belt problems...
    Here's a shot from FSM, (A) Alternator and WP belt, (B) 2 (two) AC and PS belts running side by side. Hope this helps.
    CADforce69 is offline Cadillac Owners Connoisseur
    Automobile(s): Cadillac Sedan de Ville 1969, Dodge 3700GT '73, Audi A3 1.8T
    Oct 2010
    Madrid (Spain)
    50
    1,634
    Should not be there an A.I.R. pump? See this pic from the 1969 FSM and check which configuration has your car:
    image host
    If it was this, you need 4 belts with the above specifications. You can order the belts you need from Rockauto. It´s easy as you can search item by make, year and model. To see which option you need see which pic matches with your car.
    Aug 2011
    31
    8
    Mine seems to be the first one. Thing is, the belts I got will not go around the Compressor, PS and Crank pulleys. Guess they gave me the wrong belts???
    Oct 2010
    Madrid (Spain)
    50
    1,634
    Did you loose nut and screws securing steering pump? You need doing that to ease belt installation.
    Aug 2011
    31
    8
    Yes, loosened everything. Pump is as close in as you can get it. All I can think is that they gave me the belts for no A/C. =(
    Oct 2010
    Madrid (Spain)
    50
    1,634
    Then, you´ll have to measure with a rope which length range will fit and go to the shop to change it. Be sure the other belt is ok.
    Aug 2011
    31
    8
    Well it was the wrong belts. I have no idea how they were that far off. But bad luck strikes again, they only had 1 in stock. Lol. So have to wait till Tuesday. Thank everyone for the help and diagrams!!! Liking this place already!! I posted a few pics in the RWD picture section if anyone wants to check it out.
    Kind regards,
    Trey
    Oct 2010
    Madrid (Spain)
    50
    1,634
    Hope everything is solved next Tuesday. Sweet car!
    SFCRangerDoc is offline Cadillac Owners Member
    Automobile(s): 1969 Cadillac Sedan DeVille
    Jan 2014
    34
    17
    I know I'm TOTALLY necroposting on this, but that belt diagram is EXACTLY what i needed. Just inherited a 69 Sedan DeVille and needed belt diagram Now I know exactly what I need instead of guessing.
    cadillacmike68's Avatar
    cadillacmike68 is offline Cadillac Owners Connoisseur
    Automobile(s): 68 DVC, 96 FLTWD Brg, 09 STS N* Platinum, 11 CTS Premium
    Jan 2005
    Left the desert - Back in FL
    56
    1,303
    1969 and 1970 had Different belt arrangements.
    1970 was the Only year back then WITHOUT an AIR pump (yea!!).
    1969 used 4 belts:
    2 for the AC & PS (or just PS) (59.5" with AC or 48.0" without
    1 for the Fan and AIR pump 45.5"
    1 for the Altrnator (off a 2nd fan pulley) 35.5"
    It's easy to convert a 68 or 69 to the 1970 3 belt setup. You just need the 1970 Crank pulley (3 pulleys with the 3rd one further out than 1968 or 69) and the 1970 single fan pulley.
    The 3rd belt on the 1970 is 50.5"
    Jan 2014
    34
    17
    I've got a seized ac pump so I'm bypassing it with a shorter belt to the ps pump. I wasn't sure of the length so the diagram on this confirmed the 48 length I need hehe
  15. Remove Advertisements
