hood ornament and factory alarm system? - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 25 of 25
Like Tree2Likes
1985-1996 Fleetwood and Brougham Forum Discussion, hood ornament and factory alarm system? in Past Cadillac Vehicle Discussion; Originally Posted by sven914 You could get a precharged, high voltage capacitor and wire it into the alarm system. I ...
  1. #16
    Adrian12's Avatar
    Adrian12 is offline Cadillac Owners Fanatic
    Jul 2006
    Treffen, Karnten, Austria, 109
    138
    Re: hood ornament and factory alarm system?
    Quote Originally Posted by sven914 View Post
    You could get a precharged, high voltage capacitor and wire it into the alarm system. I don't know if you want to charge the entire car though; if you send power through the chassis grounds, you could fry all of the electronics, especially the horns, lights, and theft deterrent module.
    You could, however, put the capacitor under the hood ornament and when someone moved it off the base, it would be like getting hit with a stun gun.
    To get the car to call you when the alarm is going off, you would need to get an auto dialer and find someway of getting it run on battery voltage and receive a signal from the theft deterrent. Most of the auto dialers I've seen need to be connected to a hardline, but I'm sure you could get a cellar one.
    hi sven
    i don't understand how i should damage electronics.
    it's a second system, from chassis to earth (floor where people stay)
    the other system is the car system from battery + to battery -
    the next question is, how strong is a car ignition coil for an electrical shock? too hard?
    and how could this be wired to the chassis? started with a relais coming from theft deterrent module (thats not the problem to activate the coil)
    but where should the wires of the ignition coil go???
  2. #17
    sven914's Avatar
    sven914 is offline Cadillac Owners Connoisseur
    Automobile(s): 1989 Brougham d'Elegance, 1985 Fleetwood Brougham *Coupe*
    Dec 2008
    4,256
    Everything in the car is grounded to the chassis. The battery is also grounded to the chassis, which completes the circuit and allows the flow of elections from battery positive back to the negative side. There are no wires that physically connect the ground side of the electronics to the the negative terminal.
    If you charged the chassis, that voltage would back feed into everything connected to the chassis. Electronics do not like being powered though the ground side, and it can cause a lot of internal damage.
  3. #18
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Quote Originally Posted by Adrian12 View Post
    Adrian, I do hope you're not actually considering electrifying the car as a theft deterrent.
  5. #19
    cadillac kevin's Avatar
    cadillac kevin is offline Cadillac Owners Master
    Automobile(s): chevy 350 powered 86 FWB, 00 safari h.t. 66 toro, 83 lesabre
    Dec 2010
    St. Louis, MO
    6,395
    ^its illegal (or at the least not advisable) to electrify your car because if someone gets hurt, you're liable for their injuries. its a lawsuit waiting to happen.
  6. #20
    sven914's Avatar
    Dec 2008
    4,256
    Right. If your going to go to that extreme, you might as well park you car in a puddle of water and run a broken extension cord out to it. This way nobody come near your car until you cut the power.
  7. #21
    Cadillacboy's Avatar
    Cadillacboy is offline Cadillac Owners Connoisseur
    Automobile(s): 1996 Cadillac Fleetwood Brougham
    Dec 2003
    36
    4,390
    May be you could write off a warning about your installation to disclaim yourself from a lawsuit against you if anyone gets hurt from touching your emblem but dunno for sure if still it works for you . Well, I believe a retracting hood emblem would be more than great
  8. #22
    The-Dullahan is offline Cadillac Owners Master
    Automobile(s): Orange And Purple Lights.
    Jun 2009
    Sitting on The Levee
    29
    6,632
    I Florida, you can electrify your something, so long as you have a proper Government warning on it. It's the same as wet floor signs. If you put down a wet floor and fifteen people proceed to break their necks in the puddle you were warning them about, you or your business is not liable.
    As for installing an alarm, take two washers with inner grommets, put them onto the base spring on the ornament in affixed position so they encircle it entirely, only a fraction of an inch apart. This will give a full 360 degree radius around the spring. Now, make it a circuit by adding a wire to each washer, thereby meaning that if your ornament is jarred in any direction, the circuit is complete as the washers make contact and the current is bridged to the alarm. The entire setup is basically universal and incredibly simple. Personally, my ornament is connected to the steel of my car by a series of bolts, so I have no use for something like that, but I imagine that if I DID have a spring base ornament, that is what it would have.
  9. #23
    Sep 2010
    East Boston MA.
    29
    26,325
    Hmmmmm, electrified moat theft deterrent system. Have to give that one a try.
    In all seriousness though Adrian, electrifying any part of the car is out of the question, legal or not. Even if you were to post warnings all over the car, what if a child or animal were to come in contact with it, or someone brushed by it accidentally. You were referring to connecting to the ignition coil, that would actually be lethal! Maybe you could hook the ornament up to one of those joke store gag items that just give you a little jolt, but I think your original idea of having the alarm trigger if someone tampers with it is the way to go.
  10. #24
    sven914's Avatar
    Dec 2008
    4,256
    And if you think about, anything that isn't strong enough TKO someone, is just going to piss them off, and you're going to get a crowbar through your windshield.
  11. #25
    Jun 2009
    29
    6,632
    The best defense is a good offense. Tie a large, menacing dog to your bumper. Worked for my Adoptive Mum back in the Homeland.
    In all seriousness, Hearses incur constant vandalism, it is in their nature (Court on Tuesday to schedule a now Felon's restitution payment of several thousand he owes me for that exact reason), but I think they make up for it by the fact that if anyone ever tried stealing them, the authorities would be all over them within a minute or two, because they kind of stand out. This is largely true with any older car as well, because they are not always easy to hide and do not blend in.
    I think running it to the alarm rather than electrifying it, is definitely the way to go. If not, you could always retrofit the whole thing so it is stuck in place and unable to bend or twist or move at all where the spring base is, at which point they cannot take it without cutting it, meaning they do not want a whole one AND they will need to make sure they bring tools.
  12. Remove Advertisements
