fuel injected 350 into 85 coupe - Page 2
Results 16 to 30 of 43
1985-1996 Fleetwood and Brougham Forum Discussion, fuel injected 350 into 85 coupe in Past Cadillac Vehicle Discussion; Thats what I really wanted to do but I cant find info on getting it done anywhere....
  1. #16
    jak89 is offline Cadillac Owners Member
    Automobile(s): 1985 cadillac fleetwood coupe
    Aug 2011
    28
    30
    Re: fuel injected 350 into 85 coupe
  2. #17
    sven914's Avatar
    sven914 is offline Cadillac Owners Connoisseur
    Automobile(s): 1989 Brougham d'Elegance, 1985 Fleetwood Brougham *Coupe*
    Dec 2008
    4,256
    It's not that hard to do it yourself.
  3. #18
    brougham is offline Cadillac Owners Master
    Automobile(s): 1991 Cadillac Brougham D'Elegance 5.7 Litre, 1994 DeVille
    Jun 2003
    Canada
    6,431
    You can use a 93 Fleetwood too for the drivetrain. Same car as 91&92 but different body sitting on it. For that matter you can also use a Caprice or Roadmaster from the same years and they are cheaper and easier to find.
    They only used feedback carburetors to meet emissions for the 307 years. If you're going carb route you'd be better off just getting a normal one anyway because the computer setup is designed for whatever engine and body it's in. Start mixing parts and you can can run into problems. Not to mention the extra wiring involved.
  5. #19
    outsider is offline Cadillac Owners Connoisseur
    Automobile(s): 87 Brougham, 1969 Calais, 95 FWB, 05 CTS, 07 SRX
    Sep 2009
    Buxton, Maine, United
    33
    4,149
    i really wanna swap an LT1from a 95 into my 87...haha that would be sick.
  6. #20
    Aug 2011
    28
    30
    Quote Originally Posted by brougham View Post
    What do mean by I'd "be better getting a normal one anyway", It would be better to get a already carbed motor, right?
    So far I've located a carbed 350 for a decent price but I'm gonna be a little more patient and see what else I can find.
  7. #21
    Aug 2011
    28
    30
    Alright so I finally found some solid info for wiring with a manual carb I think. here it is
    As far as wiring all you will need is the wiring from the altenator, oil pressure switch, coolant temp switch, ditributor,and the starter and battery wires. You can remove everything else.
    now I just need to now what to hook these wires up to?
  8. #22
    sven914's Avatar
    Dec 2008
    4,256
    Alternator goes to the battery. The oil pressure switch is connected directly "STOP OIL PRESSURE" warning lamp. The coolant temp lamp is wired directly to the "COOLANT TEMP" lamp. The distributor would be connected to the battery, the spark plugs, and a manifold vacuum supply. The battery Positive wouldn't need to be moved and the starter will connect to the factory ignition switch.
    The distributor is the only thing that your car has (from your list), which is computer controlled. Everything else is just plugged into what ever it controls and it maintains/monitors the system by itself. For the most part, you would be able to reuse the car's factory wring harness.
  9. #23
    Aug 2011
    28
    30
    Why thank you, that clarified a lot. I found a 4 bolt main 1980 350 all it needs is a carb. its a four barrel motor. Can someone recommend a good series of carb to put on it?
  10. #24
    jayoldschool's Avatar
    jayoldschool is offline GM RWD V8 addict
    Automobile(s): 81 FWB D'Elegance coupe
    Sep 2006
    Ontario, Canada
    44
    7,894
    Edelbrock 1406. You would be better off getting an 87 or later roller cam small block, btw.
  11. #25
    sven914's Avatar
    Dec 2008
    4,256
    I would try to find a Rochester. A carburettor for a 350 or a 403 will work and a refurbished one isn't that expensive on eBay
  12. #26
    cadillac kevin's Avatar
    cadillac kevin is offline Cadillac Owners Master
    Automobile(s): chevy 350 powered 86 FWB, 00 safari h.t. 66 toro, 83 lesabre
    Dec 2010
    St. Louis, MO
    6,395
    sven, I think hes referring to the chevy 350, not the olds 350.
    jak, get a 600 cfm rochester 4 barrel and you'll be ok. thats what the higher output 350s came with (high output is a relative term though)
  13. #27
    sven914's Avatar
    Dec 2008
    4,256
    But a carbed Chevy won't fit right. There isn't enough clearance between the frame and fuel pump.
  14. #28
    Dec 2010
    St. Louis, MO
    6,395
    isnt there a way around that?
  15. #29
    sven914's Avatar
    Dec 2008
    4,256
    Two options: take a sawzall to the fame or get an Oldsmobile engine.
  16. #30
    csbuckn is offline Cadillac Owners Master
    Automobile(s): 84 Coupe w/500
    Jan 2008
    Minneapolis
    5,611
    The 4100 is Fuel injected, right? Just run a fuel regulator near the carb and you should be good. If you do need a pump, put an electric one on the frame close to the tank.
  17. Remove Advertisements
