Fan Clutch/Cooling Issue
Results 1 to 10 of 10
Like Tree2Likes
  • 4 Post By sven914
1985-1996 Fleetwood and Brougham Forum Discussion, Fan Clutch/Cooling Issue in Past Cadillac Vehicle Discussion; ...
    sven914's Avatar
    sven914 is offline Cadillac Owners Connoisseur
    Automobile(s): 1989 Brougham d'Elegance, 1985 Fleetwood Brougham *Coupe*
    Dec 2008
    4,256
    QuestionFan Clutch/Cooling Issue
    Recently my car has been experiencing higher than normal coolant temperatures and I'm not exactly sure what is causing it. The temperature usually sits between 205º and 215º, but when I get on the highway (usually on the entrance ramp) the temperature starts to spike. In a few minutes the temp maxes out the gauge (goes past 260º) but less than thirty seconds later, it will read in the low 200's again. Whenever I stop to check the engine, while the gauge is scrolling "HI", there are no signs that anything is overheating.
    The radiator and thermostat were put in last year, so the coolant isn't that old. I thought it might be the water pump, but I don't have any signs that the pump is bad (no leaks, no noise), and I can't see the temp dropping that fast with a bad pump. I pulled DTC's and didn't get any, so the computer hasn't registered that the engine overheated.
    The only other thing I can think of is the radiator fan, and my manual doesn't give much information about it. With the engine still hot, I can spin the fan and get it to freewheel from one blade to the next. It seems loose to me, but the manual doesn't say how to test it when hot. The book says that with the engine cold, the fan should not freewheel any more than 5 turns, but that number seems somewhat relative. Does anyone know a more definitive way to test the clutch? I would also like to know how much of a pain it is to replace.
    Any other ideas and suggestions would be welcomed.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Re: Fan Clutch/Cooling Issue
    Does the temperature continue to rise once you're moving more than ~30 MPH? If so, it has nothing to do with your cooling fan, as the airflow from driving will cool the radiator. You're assessment of the water pump is correct, if it's turning, not making noise, and not leaking, it's fine. Have you checked your coolant level?
    sven914's Avatar
    Dec 2008
    4,256
    It usually doesn't start increasing until I reach 50mph, and then it spikes. I checked and there isn't anything blocking the radiator and the coolant level is fine.
    outsider is offline Cadillac Owners Connoisseur
    Automobile(s): 87 Brougham, 1969 Calais, 95 FWB, 05 CTS, 07 SRX
    Sep 2009
    Buxton, Maine, United
    33
    4,164
    are your temp sensors good? were they replaced before?
    sven914's Avatar
    Dec 2008
    4,256
    I replaced to one when I installed the gauge. I'm not so sure about the one for the computer.
    lincolncadillac's Avatar
    lincolncadillac is offline Cadillac Owners Member
    Automobile(s): 1990 Brougham, 1989 Brougham
    Mar 2011
    Kingsland GA / Jacksonville FL
    47
    83
    Clutch is cheap (i think like 45.00 for mine) and simple to replace. I started replacing mine but changed my mind, i just cleaned the bimetal coil and called it a day.
    Sep 2010
    East Boston MA.
    29
    26,325
    Quote Originally Posted by sven914 View Post
    At 50 MPH , your cooling fan serves no purpose. A bad clutch wouldn't cause an overheat problem at speed. From your description, the temp seems to rise and fall fairly quickly. To me, that indicates either air in the system (hear any gurgling?), a bad sensor or gauge., or possibly a slightly sticky thermostat?
    sven914's Avatar
    Dec 2008
    4,256
    The more I think about it, I'm thinking it is a bad gauge. Cyberdyne made the gauge and I called them to see if the gauge could misinterpret the reading from the sender. They said it was probably RFI or a bad ground screwing with the reading. I ordered a new one in June, because they are crap and the LCD display dies after two weeks (can't read the last digit), so hopefully when I get it, that will be the end of this issue.
    In the meantime, I might cook me up a thermostat...
    Rick James is offline Cadillac Owners Fanatic
    Automobile(s): 1996 FWB
    Aug 2011
    Reston, VA
    45
    101
    It sounds like your fan clutch is fine. It wouldn't spin more than a rotation or two if it was going bad.
    sven914's Avatar
    Dec 2008
    4,256
    One thing that I love about Cadillac is that problems will mysteriously resolve themselves. I was getting ready to take the thermostat out, and the gauge stopped reading high and the temperatures have been fine since.
  13. Remove Advertisements
