Hot Outside!
Results 1 to 14 of 14
1985-1996 Fleetwood and Brougham Forum Discussion, Hot Outside! in Past Cadillac Vehicle Discussion; It has been in the 90's for quite some time now, I figured I should take a picture. Also the ...
    mjs182004's Avatar
    mjs182004 is offline Cadillac Owners Enthusiast
    Automobile(s): 91Broughamd'Elegance,06STS-V,76FWBd'Elegance,98SevilleSTS
    Dec 2008
    Eastlake, Ohio
    30
    769
    Hot Outside!
    It has been in the 90's for quite some time now, I figured I should take a picture. Also the Humidity is at 83%. We finally had a good thunderstorm last night that brought the temperature down into the high 70's. This picture was taken yesterday (monday) around 4:30pm.
    PRdeVille's Avatar
    PRdeVille is offline Cadillac Owners Member
    Automobile(s): '75 De Ville ; '95 Fleetwood Brougham
    Jun 2011
    Puerto Rico
    36
    41
    Re: Hot Outside!
    Danng!!
    Good thing for Cadillac A/C systems!
    sven914's Avatar
    sven914 is offline Cadillac Owners Connoisseur
    Automobile(s): 1989 Brougham d'Elegance, 1985 Fleetwood Brougham *Coupe*
    Dec 2008
    4,256
    Re: Hot Outside!
    So did you get the climate control parts you needed?
    mjs182004's Avatar
    Dec 2008
    Eastlake, Ohio
    30
    769
    Re: Hot Outside!
    not yet, still can't find one. At least for now the A/C works great, for about an hour until the lines freeze up. due to the fact that the compressor never shuts off even when the ecc is in the off mode.
    ShadowLvr400's Avatar
    ShadowLvr400 is offline Cadillac Owners Connoisseur
    Automobile(s): 1996 Fleetwood
    Oct 2003
    Central Florida
    34
    2,536
    Re: Hot Outside!
    98's pretty warm... The whole nation is slow roasting. We've been bumping over 100 here in FL, plus heat index. 105-110 with the heat index. 90% humidity is common to. Of course the AC on the 96 Fleetwood's not the most efficient setup.
    csbuckn is offline Cadillac Owners Master
    Automobile(s): 84 Coupe w/500
    Jan 2008
    Minneapolis
    5,614
    It has been terrible through out the country. Heat index put us at 110 yesterday and 118 today. One of the hottest weaks in MN history. I had to swap a tranny and play paintball the last couple days, what bad timing on that one.
    mjs182004's Avatar
    Dec 2008
    Eastlake, Ohio
    30
    769
    Re: Hot Outside!
    Today's heat index is suppose to be 110º F. It's been a crazy summer. It also sucks that earlier this week a couple of family members were complaining that my pool was to cold. so I ended up turning the heater all the way up. long story short, I forgot to turn it back down and the next day the water was way too hot. Around 100º F. Hopefully by now it has gone down.
    sven914's Avatar
    Dec 2008
    4,256
    Re: Hot Outside!
    Quote Originally Posted by mjs182004 View Post
    Have you done any diagnostic on the system to see what parts you need? The compressor not tuning off can be related to a bad programer, power module, and control head, as well as some other related electronics. I still might be able to get you the parts you need, but I need to know what parts those are.
    Here is a chart that might help you figure out the problem:
    RocketFast321's Avatar
    RocketFast321 is offline Cadillac Owners Fanatic
    Automobile(s): 1984 Buick Electra Estate Wagon aka Country Cadillac
    Jun 2003
    Montgomery,Al
    31
    395
    Re: Hot Outside!
    sven914's Avatar
    Dec 2008
    4,256
    Re: Hot Outside!
    Mine was reading 119 this morning...
    mjs182004's Avatar
    Dec 2008
    Eastlake, Ohio
    30
    769
    Re: Hot Outside!
    This one is from today in my STS around 8 PM
    pompste is offline Cadillac Owners Connoisseur
    Automobile(s): 1995 SEDAN DEVILLE-4.9 & 1978 SEDAN DEVILLE-425
    Jan 2007
    1,673
    Re: Hot Outside!
    We`re roasting here in Michigan too.Heat index was 110 here yesterday with dewpoints in the mid to upper 70`s,temp was 97.
    Slightly cooler near lake michigan.
    jayoldschool's Avatar
    jayoldschool is offline GM RWD V8 addict
    Automobile(s): 81 FWB D'Elegance coupe
    Sep 2006
    Ontario, Canada
    44
    7,933
    Re: Hot Outside!
    Currently 115 with the heat index here. No more "cold" Canada jokes! I have to do rotors and pads tonight in the garage. I am going to lose ten pounds.
    I need to find the photo I took of my Roadmaster's climate control when it was -45F...
  16. #14
    mjs182004's Avatar
    Dec 2008
    Eastlake, Ohio
    30
    769
    Re: Hot Outside!
    Ahhh, Today was a little warmer. I feel bad for you Jay, you might loose 20lbs when your done. I hate when I get sweat in my eyes, That sh*t burns like no other. Also I've only seen -3º F on the display of my Brougham. windchill has been in the - 20's. I'm sure you know all about windchill though.
  17. Remove Advertisements
