Horn pad removal---'78 Deville
Results 1 to 4 of 4
1985-1996 Fleetwood and Brougham Forum Discussion, Horn pad removal---'78 Deville in Past Cadillac Vehicle Discussion; After watching some online videos on to remove/replace the "ignition lock cylinder", on my '78 Deville,i`ve decided to try to ...
    pompste is offline Cadillac Owners Connoisseur
    Automobile(s): 1995 SEDAN DEVILLE-4.9 & 1978 SEDAN DEVILLE-425
    Jan 2007
    1,673
    After watching some online videos on to remove/replace the "ignition lock cylinder", on my '78 Deville,i`ve decided to try to do the job myself.My trusted mechanic has allowed me to use his tools to do the job.
    Only thing i have`nt been able to find online is how to remove the horn pad.There are 2 screws on the back of the steering wheel---do those screws hold the horn pad on?
    Thanks
    sven914's Avatar
    sven914 is offline Cadillac Owners Connoisseur
    Automobile(s): 1989 Brougham d'Elegance, 1985 Fleetwood Brougham *Coupe*
    Dec 2008
    4,256
    Re: Horn pad removal---'78 Deville
    Yes, those bolts are fro the horn pad. When you take it off, you need to be careful because there is a little piece that connects the contact pad to the horn; everyone I've taken off, that that piece has gotten lost.
    jayoldschool's Avatar
    jayoldschool is offline GM RWD V8 addict
    Automobile(s): 81 FWB D'Elegance coupe
    Sep 2006
    Ontario, Canada
    44
    8,026
    To remove the pad horn contact, push down, and rotate counterclockwise a little bit. It will pop right out. On some, there will be a spade connection on the pad itself where you can disconnect the wire first.
    Jan 2007
    1,673
    I started getting into it last nite--i`ve gotten as far as the part where i need the wheel puller--ran out of daylight so i`ll be back at it again tomorrow.Only piece that looked different to me was the retainer piece that keeps the little telescopic wheel arm from falling off if the 3 screws holding it in fall off.I hope i feel as brave today as i felt yesterday.This is the first time attempting a job this delicate.
    I did ok with the horn contact,thanks to your info.
    I bought the new ignition lock cylinder, just $13 at autozone.Brand:LOCKSMART
    Just wondering,does the turn signal arm screw off or is it attached internally by a screw?
    Also,is the igniton lock cylinder "retainer screw" a torx head or phillips?
  7. Remove Advertisements
