1995 fleetwood power steering issues
Results 1 to 9 of 9
1985-1996 Fleetwood and Brougham Forum Discussion, 1995 fleetwood power steering issues in Past Cadillac Vehicle Discussion; Power steering on my 1995 fleetwood seems to die out when the car is not moving. I've tried unplugging the ...
    outsider is offline Cadillac Owners Connoisseur
    Automobile(s): 87 Brougham, 1969 Calais, 95 FWB, 05 CTS, 07 SRX
    Sep 2009
    Buxton, Maine, United
    33
    4,165
    Power steering on my 1995 fleetwood seems to die out when the car is not moving. I've tried unplugging the variable assist steering deal and it didn't improve. Fluid looks good, not dirty and the level is right.
    Hoping it's not the pump and/or gear but what else could it be? any ideas?
    thanks.
    jayoldschool's Avatar
    jayoldschool is offline GM RWD V8 addict
    Automobile(s): 81 FWB D'Elegance coupe
    Sep 2006
    Ontario, Canada
    44
    7,939
    Re: 1995 fleetwood power steering issues
    Ten bucks on leaking water pump. The bearings/seal fails, allowing water to drip out the weep hole on the bottom of the pump. This drips on the belt, causing it to slip at low speeds. To check the pump (with the engine cold), reach under the pump with your hand. I bet it comes out with coolant on it. You don't see a drip on the driveway because the coolant just gets burnt off the belts.
    Sep 2009
    33
    4,165
    Just had the water pump replaced in may but I will look if it's leaking. could a previous coolant leak have ruined the belt?
    Sep 2006
    Ontario, Canada
    44
    7,939
    Maybe if it slipped for a long time it got glazed. Not as likely with a serpentine setup, though. Make sure you check that pump on the bottom, and if it is dry, change the belt. About ten bucks, and five minutes to change. A bit longer if you have tow pack...
    thefleetwoodguy is offline Cadillac Owners Enthusiast
    Automobile(s): 95 triple black fwb
    Dec 2008
    S NH
    56
    890
    along that same line of thinking maybe a weak belt tensioner?
    Sep 2009
    33
    4,165
    ooh didn't think about the tensioner. I'll swap out the belt this weekend...is there any way to test the tensioner? I may just pick one up and replace it anyways.
    Thanks for the ideas guys. I'll let you know this weekend how it turns out!
    Sep 2006
    Ontario, Canada
    44
    7,939
    Good call, Jim.
    HUF's Avatar
    HUF
    HUF is offline Cadillac Owners Connoisseur
    Automobile(s): 1995 FWB 100,*** miles CURRENT. 1991 Seville 175,000 SOLD
    Dec 2005
    MA
    58
    2,112
    I am at my third tensioner only after 95.000 miles.
    Sep 2006
    Ontario, Canada
    44
    7,939
    Weird. I have never changed one on any of my LT1s...
  12. Remove Advertisements
