Head I.D. firing order
Results 1 to 4 of 4
Like Tree1Likes
  • 2 Post By CadillacPimpinNOLA
1985-1996 Fleetwood and Brougham Forum Discussion, Head I.D. firing order in Past Cadillac Vehicle Discussion; I was wondering how do.I.tell what heads I have one my 350 Oldsmobile. Motor. Any way to I.d it with ...
    jcolliga40 is offline Cadillac Owners Fanatic
    Automobile(s): 86 fleetwood
    Oct 2010
    255
    I was wondering how do.I.tell what heads I have one my 350 Oldsmobile. Motor. Any way to I.d it with all the numbers on it. I am trying to get a new gasket for it.
    I am also on the hunt for firing order cylinder line up and distributor set up. What plugs go where on my 67 Calais with the 429. Thanks again.
    Here is a site I found for head gaskets.http://www.mondellotwister.com/GasketsSealants.htm
    CadillacPimpinNOLA is offline Cadillac Owners Connoisseur
    Automobile(s): 1995 Fleetwood 1968 coupe DeVille
    Jul 2009
    Metairie/New Orleans,LA
    32
    1,152
    Re: Head I.D. firing order
    when it comes to oldsmobiles, all the heads for small blocks are pretty much the same, a head gasket is the same for all small blocks and a big block is the same for all olds big blocks
    you tell a small block head cuz it has a big number on the end upper part of the head, a big block olds had a letter
    as for firing order if i still remember correctly. its the same as a chevy engine but the distributor spins the opposite way
    mjs182004 and mjs182004 like this.
    csbuckn is offline Cadillac Owners Master
    Automobile(s): 84 Coupe w/500
    Jan 2008
    Minneapolis
    5,614
    All the info you need is right here. When you get done with heads section, go to the bottom and click on some of the other info. This stuff was pretty helpful.
    http://www.442.com/oldsfaq/ofhed.htm#Heads
    Oct 2010
    255
    Okay thanks
  7. Remove Advertisements
