CadillacPimpinNOLA's 95 Fleetwood buildup 56K your computer will blow up - Page 70
Page 70 of 77 FirstFirst ... 20 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 LastLast
Results 1,036 to 1,050 of 1146
Like Tree156Likes
1985-1996 Fleetwood and Brougham Forum Discussion, CadillacPimpinNOLA's 95 Fleetwood buildup 56K your computer will blow up in Past Cadillac Vehicle Discussion; got the bottom, matched up to the back board and both sides on, was going to put the ports in ...
  1. #1036
    CadillacPimpinNOLA is offline Cadillac Owners Connoisseur
    Automobile(s): 1995 Fleetwood 1968 coupe DeVille
    Jul 2009
    Metairie/New Orleans,LA
    32
    1,152
    Re: CadillacPimpinNOLA's 95 Fleetwood buildup 56K your computer will blow up
    got the bottom, matched up to the back board and both sides on, was going to put the ports in and 2 front pieces for the 1st baffle but again made a minor mistake. going to have to trim about 3/4" of of the port where it meets baffle...easy enough but its raining now so no go.
    at least its trimming and not adding...also need to get some more screws as i have only a few left
    when its dry i will also have my neighbor rip these 2 boards i have so i can 90 and brace all the corners up strong
  2. #1037
    Jul 2009
    32
    1,152
    small update, bunch of pics
    trying to get too much done at once, box is at a stand still till my neighbor helps me rip two boards...and my new router works great but the expensive ass home depot flush bit tore the hell out of my box so it will be a lil extra work when i get it finished to bodywork and fix a few areas on and around the port
    pulled the sunglass holder down and found from all the movement it ripped all but one wire out, have to put some deadener on the new panel as it slaps the plastic inside the headliner and makes a terrible noise
    pain drilling these holes but it has to be done...2 more runs of 0gauge
    i cant finish running it till i get the old box and stuff out, seat included
    nice rounded edges on the port for less turbulence, helps out on the meter a bit to
    70lbs of destruction, also cheap ass blade for the jigsaw bent and cut about a 7inch chunk out the mounting baffle, on the inside, not bad enough to cause any harm but still messed up
    then i jumped on this the other day, tired of the missing wreath and broken crest and i dont use this function as i have no latch in the car at all
    weled up, smoothed over, have a bunch of primer on it, the bodyline is not perfectly straight but it will be when i block it out before its time to paint
    tomorrow i tackle the waterpump, check and make sure my cap and rotor is good while in there and after that maybe ill try to get some work done on the box. of course as soon as i have some free time to do the waterpump and flush the heatercore, a damn cold front comes through
  3. #1038
    Jul 2009
    32
    1,152
    so today i knocked the waterpump out and of course the cap and rotor had to be replaced, so that was some more money down the drain...riding good now...the cap itself was actually broken where the coil wire hooks up.
    then my neighbor hooked me up... ill tell ya this right now, im 29 years old, i tried and failed miserably at ripping a board 45 to do my corners, actually it was pretty embarrasing.
    my neighbor is "92 years old" , he had them cut to length and ripped perfect in about 20 minutes
    so tomorrow ill be installing these hopefully, then i can put the top panel on, fix the port where the router screwed me and then get it to work to begin the body and paint process
    Stingroo likes this.
  5. #1039
    Stingroo's Avatar
    Stingroo is offline Cadillac Owners 10000+ Posts
    Automobile(s): 92 Caprice Wagon LS1/T56 | 1995 Lexus LS400 | Next: 16 MX-5
    Jun 2009
    Port St. Lucie, FL
    26
    18,378
    This... this is inspiring me.
  6. #1040
    Jul 2009
    32
    1,152
    ok, had an almost major issue witht he box, somehow it racked a lil bit and one side of the front baffle was sticking out further than the other...problem is the trim panel wont sit flush with it how it was...i couldnt rip it apart and fix it cuz everything else was correct and i dont know why it was like it was, anyway
    a lil 40grit and a D/A sander and i knocked the bad area down, re-routed one port side and good to go.
    added the wood back where the router screwed me the other day and started adding some filler to make it all smooth. want to go finish sanding but its looking like it may rain and rain is no good for MDF
    90 pieces also installed, glued and screwed
    im so ready to get all this over with and in, ill run the wire after i tear the car down then its right back in with the box and subs...wont be long after to wire the new amp up and get the dual alternator project started
  7. #1041
    Jul 2009
    32
    1,152
    scratch that, took the risk and got the sanding done a few minutes ago, rain still threatening...now have to get it to work to finish sand it and get some primer on it so i can see if there are any imperfections to fix...not sure when ill get it to work though.
  8. #1042
    Jul 2009
    32
    1,152
    ok, a lil update, so far, so good.
    got the box to work yesterday after lunch, managed to get it sanded and 2 nice coats of primer on it...let it dry over night
    got in this morning, took a while sanding it smooth but got it done, had a few areas i burned through and some pin holes that had to be filled and reprimed...done that and sanded them smooth
    then i wet the floor and blew everything off. got a lil sealer on and then 3 coats of Red paint
    tinted primer
    sanded after adding the second few spots of primer
    maroon tinted sealer
    red paint
    tomorrow ill get in hopefully early adn get the clearcoat on it and it will be 100, ready to go in the car...i was shooting for saturday or sunday but theres a small benefit show that i may attend before ripping it all apart
    i got my 2nd alternator back today, guy said 240 amps, $240...when it stops raining im going to swap it out and then bring him my old one see what i messed up in it.
    only thing that will stop me from ripping everything apart and getting my box swapped out is the weather
  9. #1043
    csbuckn is offline Cadillac Owners Master
    Automobile(s): 84 Coupe w/500
    Jan 2008
    Minneapolis
    5,612
    So you paint wood like metal with car paint? Sand, primer and paint? A certain primer you use?
  10. #1044
    Jul 2009
    32
    1,152
    yep, thats how i been doing it for a long time, if its smooth like mdf ill use 320 all over, since i used bodyfiller on it in certain spots to cover the screws i sand them with 80 and work up till i get to 320...prime with whatever automotive high build primer that sherwin williams sells us. sand and repeat if necessary as you see i had to reprime a few spots...blow all the dust off so its nice and clean...spray sealer on it and in 10-15 minutes depending on your temp/humidity spray your base color.
    tomorrow i have a lil work but im going to try to get the clear on so it can dry and hopefully nothing settles in the clear so i wont have to do any sand and polishing.
    i swapped my alternator out earlier and when i started the car it went 13-13.5-14 volts so that tells me i definatly done something to the old alternator. guy said maybe burned a diode up or something so he gets it tomorrow to inspect...prolly wont bang on it hard till i swap everything out and get the second alternator hooked up...then ill be charging 420amps
    slowly but surely, making it happen
  11. #1045
    Jul 2009
    32
    1,152
    soon as i got to work, wet the floor, blew any that may hae settle on the base coat and went to mix some clearcoat.
    got in there and going for a heavy flow coat, i got 1 damn run on the face of the box...so its drying now, either later today or tomorrow ill shave it down and polish it out. no biggie
    cant see it in the picture but its very noticable in person so ill get that done asap...in a lil while im going to gas up the car and drop the other alternator off to the shop
  12. #1046
    Jul 2009
    32
    1,152
    well i started cutting the run out, the clear was still not 100% dry after scraping the top of the run down, and also they had a dry area i really didnt like, prolly wouldnt have been seen but i knew it was there. so tomorrow ill finish scrapping the run out and i sanded the whole box face with 1000 grit. im going to re-clear it and it should look nice and slick. didnt get 100% orange peel out but a lot so it will look slick
    now the other good/bad news...my alternator checked out fine at the shop, my new alternator is charging right but drops at red lights like the other alternator...so that means 1 or many of those optimas are bad...so if they cant handle that power, they definatly cant handle the new power and thus an upgrade is needed. a heavy and expensive upgrade
  13. #1047
    Jul 2009
    32
    1,152
    if its not one things, its another...clear was nice and dry this morning, however while sanding i burned through and the run wasnt completely out, so i had to sand it out, dust some color back on to cover the burn spot and once that was done, i blew it all off, wet the floor down and wet the box up with 2 nice coats of clear...so its drying and either today or tomorrow ill bring it home and have it ready for tear down hopefully sunday
  14. #1048
    MrHolland's Avatar
    MrHolland is offline Super Moderator
    Automobile(s): 2010 Platinum Escalade, 1996 Fleetwood Brougham
    Jul 2010
    Midwest
    5,642
    Quote Originally Posted by CadillacPimpinNOLA View Post
    Are you wearing a helmet??
  15. #1049
    Jul 2009
    32
    1,152
    no i had a hoodie sweatshirt on, cold front came through and i hate cold weather
    im deciding missing the show tomorrow b/c of my batteries, that would give me plenty time to rip the car apart and get at least the wires ran and the new box and subs in so i can drive the car, once thats done i can focus on getting the new amp mounted and wired up and maybe start on the dual alternator setup. also look at where to put new batteries when i decide to order them.
  16. #1050
    Jul 2009
    32
    1,152
    just left pull-a-part...got only what i could fit in the car, couple chrome lower moldings, skirts, and a washer pump...triple black brougham, wish i had the room b/c it had a decent bumper, better than mine, 2 perfect headlights and crack free dash pad...might clean the moldings up and put them on
  17. Remove Advertisements
