CadillacPimpinNOLA's 95 Fleetwood buildup 56K your computer will blow up - Page 61
Page 61 of 77 FirstFirst ... 11 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 ... LastLast
Results 901 to 915 of 1146
Like Tree156Likes
1985-1996 Fleetwood and Brougham Forum Discussion, CadillacPimpinNOLA's 95 Fleetwood buildup 56K your computer will blow up in Past Cadillac Vehicle Discussion; I need a blue version of that wheel!...
  1. #901
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,986
    Re: CadillacPimpinNOLA's 95 Fleetwood buildup 56K your computer will blow up
  2. #902
    CadillacPimpinNOLA is offline Cadillac Owners Connoisseur
    Automobile(s): 1995 Fleetwood 1968 coupe DeVille
    Jul 2009
    Metairie/New Orleans,LA
    32
    1,152
    good luck with that, you can have it recovered its just finding one, and for a fair price...i have waited years patiently before this one popped up.
  3. #903
    Sep 2007
    Wilmington, NC
    13,986
    yeah, and blue isn't the most common interior color either (esp for cars with the woodgrain option... eldo/sev)
    i'm not even sure if that option was ever actually offered in the blue interior too... so i'm not really looking all that hard
    but a boy can dream
  5. #904
    cadillac kevin's Avatar
    cadillac kevin is offline Cadillac Owners Master
    Automobile(s): chevy 350 powered 86 FWB, 00 safari h.t. 66 toro, 83 lesabre
    Dec 2010
    St. Louis, MO
    6,395
    I've come across quite a few of the wood wheels in black interiors....haven't seen them in white or blue yet.
  6. #905
    Jul 2009
    32
    1,152
    i have seen a lot in black leather and dark wood grain, a few in tan like the one i got, thats really the only two colors i have seen but it was an option for any color those year eldorados...but all the previous ones ive found the leather was worn, worn grain chipped or showing age and a $350+ price tag...
  7. #906
    96LT1 is offline Cadillac Owners Member
    Automobile(s): 1996 Fleetwood
    Jul 2012
    40
    Quote Originally Posted by CadillacPimpinNOLA View Post
    yea i see that, i didnt know if there was reliefs cut into the wheel to pass between the airbag and wheel or not...either way, with them or without, im happy I finally found a nice one and cheap too
    i think there is relief cuts in the wheel,but i dont think that you would be able to see them too much. also the airbag attaches differently on the fleetwoods and eldorados, do you know if you can just pull off the part from the flletwood wheel and add it to the eldorado?
  8. #907
    Jul 2009
    32
    1,152
    from what i read it was the same exact wheel so the airbag should swap right over, if not ill figure it out and make it work
  9. #908
    Jul 2012
    40
    this is a bad picture but the parts circled in red are what the eldorado wheel dosent have
  10. #909
    Jul 2009
    32
    1,152
    im sure i can transfer stuff over, either way we'll find out soon, and one way or another i will make it work
  11. #910
    Jul 2009
    32
    1,152
    line driver came in faster than expected, got it yesterday instead of the april 2 delivery date, so thats a win, went out and pulled the driver seat, squeezed in the back seat area and wired it up, that and the dual USB hookup were the last two pieces I had left so everything for the tablet is done, i havent set the gain on the line driver but did test it and its 100...so now its on to the console when i have some spare time.
    USB hanging there cuz the ashtray was cut up for the switches, all will be hidden
  12. #911
    Jul 2009
    32
    1,152
    ok, wheel came in today, pulled the factory one
    96LT1 those pieces you talking about, i was able to unscrew them from my factory wheel, on the new wheel the opening on the back of the wheel has a restriction made into and uses small and shorter screws, maybe tomorrow im going to grind the heads of the screws down so they fit in there and be able to mount the airbag when im ready
    I have to dye the airbag to match the wheel leather and then water transfer the wood with a burlwood pattern and it will be done
  13. #912
    Jul 2012
    40
    looks great
  14. #913
    Jul 2009
    32
    1,152
    thanks, i ground the bolt heads down this morning at work, the bolt head fits now but one last small, minor issue, the bolts have a threaded end and the middle is smooth but larger in diameter, im going to have to enlarge the 4 holes on the wheel so they can pass through, doesnt have to go much and theres plenty to drill.
    about to go get a price on the water transfer in a lil while also
  15. #914
    Jul 2009
    32
    1,152
    got the pieces installed in the wheel, trying to find some color to do the airbag and ran into another issue
    I guess i have 4 choices now since the guy who does water transfer is obviously on a generic system. he says his burlwood is red and wont match mine. im pretty sure you print what you want and lay it on so he must have preinstalled images and dont want to upgrade or go outside the box
    so my 4 choices are...leave it as is with mismatched wood...do all the wood in the car...paint it to match my car...search for someone else
  16. #915
    Poda is offline Cadillac Owners Fanatic
    Automobile(s): 94 Fleetwood Base, 94 Fleetwood Livery-no vinyl top in sight
    Jan 2012
    Toronto, ON
    40
    286
    Given the amount of work you've put in to this car already, I vote for re-doing all the wood in the car. With real veneer.. It's on my "one day" list of things to do..
  17. Remove Advertisements
