CadillacPimpinNOLA's 95 Fleetwood buildup 56K your computer will blow up - Page 48
Page 48 of 77 FirstFirst ... 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 ... LastLast
Results 706 to 720 of 1146
Like Tree156Likes
1985-1996 Fleetwood and Brougham Forum Discussion, CadillacPimpinNOLA's 95 Fleetwood buildup 56K your computer will blow up in Past Cadillac Vehicle Discussion; Thanks for the link pimpin!! I remember that one circulating. But, I want it all, rid myself of the DRL ...
  1. #706
    MrHolland's Avatar
    MrHolland is offline Super Moderator
    Automobile(s): 2010 Platinum Escalade, 1996 Fleetwood Brougham
    Jul 2010
    Midwest
    5,658
    Re: CadillacPimpinNOLA's 95 Fleetwood buildup 56K your computer will blow up
    Thanks for the link pimpin!! I remember that one circulating. But, I want it all, rid myself of the DRL and keep the auto functions.
    -----If and when I figure it out I will certainly created a thread.
  2. #707
    cadmanchris's Avatar
    cadmanchris is offline Cadillac Owners Enthusiast
    Automobile(s): 2001 DTS,2007 STS V8
    Dec 2006
    New Jersey
    44
    601
    My DTS has the DRL's through the low beams, so I wired the low beam power source to drive relays to power up the HID's so that they would work with the DRL's and the low beams.
    csbuckn and csbuckn like this.
  3. #708
    CadillacPimpinNOLA is offline Cadillac Owners Connoisseur
    Automobile(s): 1995 Fleetwood 1968 coupe DeVille
    Jul 2009
    Metairie/New Orleans,LA
    32
    1,152
    ok, glued the gauges in...get some wire tomorrow and start wiring them up
  5. #709
    turbojimmy's Avatar
    turbojimmy is offline Cadillac Owners Connoisseur
    Automobile(s): 1994 Fleetwood 60" Stretch; '07 Avalanche, '95 Nighthawk
    Apr 2004
    New Jersey
    3,963
    Quote Originally Posted by MrHolland View Post
    What happens if you disconnect the DRL diode at the brake pedal? The limo doesn't have a diode, but the wire is there. The Twilight Sentinel works fine.
  6. #710
    MrHolland's Avatar
    Jul 2010
    Midwest
    5,658
    Thanks Turbo, I'll check that out when I return home!!!!
  7. #711
    turbojimmy's Avatar
    Apr 2004
    New Jersey
    3,963
    It says that in order to replace the diode you have to remove the brake pedal bracket. But I would think you could get away with just unplugging it and leaving it there.
  8. #712
    Jul 2009
    32
    1,152
    I have no clue on any of that...thankfully mine doesnt have DRL
    now, I made a call today to the alternator guy, he said the parts just got in this morning...so I pulled the alt a few minutes ago...ready to drop it off tomorrow around 8:30...hopefully turn around time is quick like he said it would be and ill be on to better voltage...then I can wire the gauges up and see how much drop I have if any
  9. #713
    talismandave's Avatar
    talismandave is offline Cadillac Owners Master
    Automobile(s): 1980 Eldorado, 1974 Talisman, 2004 Volvo C70,
    Mar 2012
    Madison WI
    57
    7,893
    Quote Originally Posted by CadillacPimpinNOLA View Post
    That is perfect! Looks factory stock.
  10. #714
    Jul 2009
    32
    1,152
    theres some small gaps on the side but its not noticable unless you look close...took a friend for a ride earlier and cranked it up...hes said, turn it down, then said, I need another old school to do this with...he wants mega sound
    my friend with the green fleetwood hit me up earlier..hes having the trunk sprayed with a bed liner material...i was going to Re-Bag the vehicle but he now wants a small hydraulic setup, non hopping, so another place is going to do that...I however will be cutting the old decklid neon panel and installing the new bigger neons, wiring it all up, fixing all the sound and he wants the whole trunk trimmed out in mirror plexi glass and also have the amps mounted to the plexi...I have an awesome idea for what to do and in my mind looks killer...its if I can pull it off 100%, Ill have to make a new thread just for that when hes ready to do it
    talismandave and talismandave like this.
  11. #715
    Jul 2009
    32
    1,152
    just my luck...go pick my alternator up, said on there bench it done 180amps which is great, he said no guarantees but b/c my car spins faster than there bench tester I could see more output...If voltage stays up when at max bass and volume then im good, as long as i dont smell burning voice coils...he also said I may want to invest in a battery isolator if it drops voltage so they will get equal power from the alt...
    now my bad luck situation...I have no garage and its raining right now
    nice, pretty and cleaned up
  12. #716
    Jul 2009
    32
    1,152
    well, got lucky, rain started to slack off...got out in the rain and reinstalled it...dont be laughing at me standing on the sway bar using the hood to shield the rain either
    now tomorrow ima get some wire and wire the gauges up, weather permitting
  13. #717
    turbojimmy's Avatar
    Apr 2004
    New Jersey
    3,963
    Nice. So clean....
  14. #718
    Jul 2009
    32
    1,152
    thanks, I try to keep everything as clean as i possibly can while still daily driving it and no garage.
    got board and ordered a few 18" red LED strips...will hide them inside the car to light it up without seeing the LEDs
  15. #719
    Jul 2009
    32
    1,152
    was going to wire the gauges up today but I got a call and an offer I couldnt refuse so I didnt get the wire and had a good time at the Hornets/Lakers Game even though new orleans lost, plus it was wet by my house so tomorrows another day
    Plus we done a Good deed for the holiday season...all the suite food they were going to just throw away, my friend who brought me there, had them wrap it all up and on our way back we gave it to all the homeless ppl.
    these tickets came compliments of Harrahs through his wife that has a host, they actually emailed me while there about my car wreck and after writing them a letter back, I informed them that I was at the game in their suite and I dont have a host, then I said, gotta get everything out of yall I can...she said shed call me in the morning
    kicked back with some Jack and Coke
  16. #720
    The-Dullahan is offline Cadillac Owners Master
    Automobile(s): Orange And Purple Lights.
    Jun 2009
    Sitting on The Levee
    29
    6,632
    4 packs of lights came in yesterday... each pack has 2 12" red cold cathode tubes...i closed them in the trunk to view them but light coming through where the backseat should be prevents them from giving the full affect...at night and lighting a mirror plexi sign they should shine nicely...im going to use 6-8 on the sign...may purchase more later to throw under the seats or dash or somewhere to light the inside up...
    4 packs shipped was $38
    they come with extra wires to install in computer cases, i just snipped all that off...ill run them all together so i can work them with 1 switch
    and on an even better note, i was about to purchase a piece of 1/4"x24"x48" mirror plexiglass for a trunk sign, my brother said he may have some at work so im hoping...thats $100 i can save right there
    Oh they'll shine plenty at night. I've had these exact lights in my Cadillac for years now.
  17. Remove Advertisements
