CadillacPimpinNOLA's 95 Fleetwood buildup 56K your computer will blow up - Page 25
Page 25 of 77 FirstFirst ... 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 75 ... LastLast
Results 361 to 375 of 1146
Like Tree156Likes
1985-1996 Fleetwood and Brougham Forum Discussion, CadillacPimpinNOLA's 95 Fleetwood buildup 56K your computer will blow up in Past Cadillac Vehicle Discussion; i need some to, just not real worried about those right now...
  1. #361
    CadillacPimpinNOLA is offline Cadillac Owners Connoisseur
    Automobile(s): 1995 Fleetwood 1968 coupe DeVille
    Jul 2009
    Metairie/New Orleans,LA
    32
    1,152
    Re: CadillacPimpinNOLA's 95 Fleetwood buildup 56K your computer will blow up
  2. #362
    MrHolland's Avatar
    MrHolland is online now Super Moderator
    Automobile(s): 2010 Platinum Escalade, 1996 Fleetwood Brougham
    Jul 2010
    Midwest
    5,615
    Hey Pimpin, what dust shields did you buy?? I found some that measure 13 3/16, is that what you bought too?? I'm trying to keep from modifying!!
  3. #363
    Jul 2009
    32
    1,152
    yea thats what I got, those have to be cut down a lil bit...still havent done mine yet
    i placed 2 paint sticks againt the rear hub of the rimextended them across the center to the rim side, then taped them together...thats how i found out how much i have to cut them down
  4. #364
    MrHolland's Avatar
    Jul 2010
    Midwest
    5,615
    What up pimpin?? Where you been, it's been quiet in here. Quick question for ya, how close are your rear tires to the latches that hold on the skirts? Did you modify any of that? With a 2inch spacer I think I'll have to trim the top part of the plastic fork where the latch goes. I don't think I'll have any clearance problems with the spokes on the skirt!!
  5. #365
    85 FLEETWOOD COUPE's Avatar
    85 FLEETWOOD COUPE is offline Cadillac Owners Fanatic
    Automobile(s): 96 CADILLAC FLEETWOOD BROUGHAM
    May 2011
    GEORGIA
    463
    if they hit you can trim the peice down it wont effect how the skirts hold on,thats how i did with wire wheels,i dont know about the swangas tho
  6. #366
    Jul 2009
    32
    1,152
    like i said, as long as you keep the rear shocks air up you shouldnt have any spoke or rim hitting issues... I have pics somewhere on here one what i modified on the skirts, I keep my rear low though...other than that im trying to find a daily driver, something small and cheap yet reliable so i can pull a few parts off to paint that effect drivability and cant be done in 1 day.
    i trimmed the plastic sticking up on the left side of the pic cuz it was close to the tire, thats all the mods I done...i notched the metal itself cuz i run the rear low so it fits between the cap and spokes
  7. #367
    MrHolland's Avatar
    Jul 2010
    Midwest
    5,615
    That's not it. The plastic fork where the release lever goes, my tire will be very close to that. It's in the first pic you posted. That's gonna be my only problem. Are you tires close there?
  8. #368
    Jul 2009
    32
    1,152
    yea its close but it never rubs, i can get my hands in there to remove them easily also...that definatly will not be an issue
    not great pics but you can see a lil bit, dont mind the dirty vogues or the cat that decided to piss on my rim last night
  9. #369
    MrHolland's Avatar
    Jul 2010
    Midwest
    5,615
    Thank you sir. I may actually have to go with 1.5-1.75 inch spacers to get mine to sit like that. I measured for a two inch spacer and the tire seemed to be about a half inch from the skirt. Funny how different cars measure out differently. Thank you once again!!
  10. #370
    Jul 2009
    32
    1,152
    when i mounted the 1.25" adapters and set the rim on it looked like it sits now with the 2" adapter, when i tightened the wheel on it pulled it way in...you need to fully bolt them on to figure where your at.
  11. #371
    Angry Matt's Avatar
    Angry Matt is offline Cadillac Owners Enthusiast
    Automobile(s): (2) '81 FWBs, '86 Cutlass Supreme
    May 2009
    Limerick, PA
    38
    690
    Where'd you get the wheels from? I just got an original set of RWD 15's without center caps and I can't find spinners that fit anywhere. The hubs look exactly like yours.
  12. #372
    MrHolland's Avatar
    Jul 2010
    Midwest
    5,615
    Texan wire wheels
  13. #373
    Jul 2009
    32
    1,152
    yep TWW you can get caps or 2 prongs. and these are front wheel drive rims, for yours to be RWD and not he TWW RWD rims. you have cragar starwires
  14. #374
    Jul 2009
    32
    1,152
    got it in this week to make a few dollars on the side. hooked up pop trunk on a 06 toyota avalon which is really hard to do and you loose the ability to open the trunk fully, just got done with my friends 91-92 lac. his was fairly easy. a lil cutting and welding but easier than the avalon
    reverse actuator through the back wall
    the lac
  15. #375
    MrHolland's Avatar
    Jul 2010
    Midwest
    5,615
    This is what I think ill use for brake dust shields. They are a little more expensive but if I measured correctly they should be a nice fit. Ill let you know how they work out if I get them.
    http://www.tulipcitywheels.com/tcwst...t_detail&p=897
  16. Remove Advertisements
