Stuck distributor on 69
Results 1 to 9 of 9
1985-1996 Fleetwood and Brougham Forum Discussion, Stuck distributor on 69 in Past Cadillac Vehicle Discussion; I forgot to post this before... this past weekend I tuned up my 69 with new plugs, wires, rotor, cap, ...
    outsider is offline Cadillac Owners Connoisseur
    Automobile(s): 87 Brougham, 1969 Calais, 95 FWB, 05 CTS, 07 SRX
    Sep 2009
    Buxton, Maine, United
    33
    4,149
    this past weekend I tuned up my 69 with new plugs, wires, rotor, cap, points, and condenser.
    Problem is, when I went to time the thing the distributor wouldn't turn. Sprayed it down with PB Blaster and Kroil but still pretty well stuck.
    Anyone got any tricks for freeing it without breaking anything?
    CADforce69 is offline Cadillac Owners Connoisseur
    Automobile(s): Cadillac Sedan de Ville 1969, Dodge 3700GT '73, Audi A3 1.8T
    Oct 2010
    Madrid (Spain)
    49
    1,634
    Re: Stuck distributor on 69
    Maybe it´s stuck by the grease/rust on the block and no timing adjustment for decades. In addition to a loosening product, you can add some engine oil, leaving it some hours to actuate and then knocking the distributor metallic base preferably with a nylon hammer (without distributor cap). As it´s difficult to hit the part precisely, you can place a stick on different parts of the distributor base and hitting the stick but the most effective way is hitting directly.
    Sep 2009
    33
    4,149
    Thanks CADForce. I was afraid of breaking something by hitting it. I will give that a try next time.
    My girlfriend's father was going to try to hit it with a 20 lb sledge hammer and I was like "NOOOOOOOOOO!" haha
    csbuckn is offline Cadillac Owners Master
    Automobile(s): 84 Coupe w/500
    Jan 2008
    Minneapolis
    5,612
    Where would you hit? Isnt it a cylinder shaft?
    Sep 2009
    33
    4,149
    It is a cylinder shaft but there are some parts that jut out near the top that you could probably put a stick on and hit...the thing was stuck pretty good though.
    Oct 2010
    Madrid (Spain)
    49
    1,634
    Quote Originally Posted by outsider View Post
    I was thinking of something more subtle than a 20 lb sledge hammer Anyway, if you hit a stick placed on the base surface or hit directly with a nylon hammer there will be no damage unless you hit the rotor or the points by accident.
    cadillac_al is offline Cadillac Owners Connoisseur
    Automobile(s): 70 Deville 77 Fleet 78 Seville 92 Deville 03 Deville
    Feb 2007
    Maine
    55
    3,310
    There is no easy way to get them out as far as I know. I seem to have about a 50/50 chance of getting them out without breaking them. Be careful. I have been having a lot of good luck breaking things loose with Castle Thrust; it's a spray penetrating oil. I usually start out tapping on the vacuum advance to get it to start turning some and work it from there. I have used the old pinch bar on a couple when nothing else seems to work. Good luck.
    I bought a new distributor for my Seville but I can't get the old one out either. I won't feel so bad if I break it because i have a new one waiting to go in.
    cosmo is offline Cadillac Owners Member
    Automobile(s): 1976 Sedan deVille
    Nov 2010
    South Elgin, IL
    53
    39
    I've actually done this recently.
    Kroil (Kanolabs.com), and, if it runs, spray it when it's hot.
    Spray it every day for about a week.
    Remove the A/C compressor, it's in the way.
    Use a pipe wrench, very near the base, and try twisting it.
    If it twists, twist it more, while trying to pry it upward.
    Things to NOT do: Hit the distributor anywhere but directly on the base, and then only to input some vibration to aid the Kroils penetration.
    Twist using the vacuum can for leverage.
    Expect results immediately after spraying Kroil.
    Try this without removing the compressor. The oblique angles will break the distributor.
    Cosmo
    cadchris's Avatar
    cadchris is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac 91 Bro-Ham, 91 Yello-dorado
    Sep 2008
    Florida
    46
    245
    In case anyone found this older thread on an internet search, here's some updates about the subject. I did a lot of research about this problem. Here is an updated link with a lot of tech. tips and info on freeing a stuck distributor in this thread.
    http://www.cadillacforums.com/forums...ml#post3465241
    See posts# 112, #121, #134.
    I hope this helps others with a stuck distributor. If anyone finds different ideas work, post back here to let everyone know.
    Good Luck,
    Regards,
    Chris
  12. Remove Advertisements
