engine stutter on 1994 fwb
Page 1 of 2 12 LastLast
Results 1 to 15 of 20
1985-1996 Fleetwood and Brougham Forum Discussion, engine stutter on 1994 fwb in Past Cadillac Vehicle Discussion; hi all, i'm having an intermittent engine stutter on my 94 fwb. it usually starts around 45 and up, and ...
    newside is offline Cadillac Owners Fanatic
    Automobile(s): 1994 fleetwood, 1979 deville, 1992 eldorado
    Mar 2010
    northern ny
    60
    139
    hi all, i'm having an intermittent engine stutter on my 94 fwb. it usually starts around 45 and up, and on hills. when i accelerate from cruising it will stutter. what i have done to the vehicle is, change the tranny fluid and filter, change the fuel filter, replaced the intake gasket, replace air filter and engine oil. i checked the engine at night for arching around the plug wires. i was thinking about the torue converter lock-up as a possiblity. any impute would be appreachiated. thanks
    sven914's Avatar
    sven914 is offline Cadillac Owners Connoisseur
    Automobile(s): 1989 Brougham d'Elegance, 1985 Fleetwood Brougham *Coupe*
    Dec 2008
    4,256
    Re: engine stutter on 1994 fwb
    Try replacing the plugs and wires.
    Stingroo's Avatar
    Stingroo is offline Cadillac Owners 10000+ Posts
    Automobile(s): 92 Caprice Wagon LS1/T56 | 1995 Lexus LS400 | Next: 16 MX-5
    Jun 2009
    Port St. Lucie, FL
    26
    18,399
    Check your EGR valve.
    jayoldschool's Avatar
    jayoldschool is offline GM RWD V8 addict
    Automobile(s): 81 FWB D'Elegance coupe
    Sep 2006
    Ontario, Canada
    44
    7,954
    Replace coil wire only, first. Inspect, clean, lube connections for the coil/ICM.
    Mar 2010
    northern ny
    60
    139
    Quote Originally Posted by jayoldschool View Post
    ok, thanks guys. i'll try these suggestions. i just got the carburator done on my 79 deville. it's one thing after another. lol, thanks again
    HUF's Avatar
    HUF
    HUF is offline Cadillac Owners Connoisseur
    Automobile(s): 1995 FWB 100,*** miles CURRENT. 1991 Seville 175,000 SOLD
    Dec 2005
    MA
    58
    2,117
    Quote Originally Posted by newside View Post
    Keep us updated. I have had exactly the same issue for two years. Still looking for possible cause...
    Wheelman322's Avatar
    Wheelman322 is offline Cadillac Owners Enthusiast
    Automobile(s): 1979 Coupe Deville, 1995 FWB & 6 Other Non-Cadillacs.
    Nov 2003
    New Jersey
    755
    Possibly a bad Optispark...I know the LT1 engine was known for that.
    HUF's Avatar
    HUF
    Dec 2005
    MA
    58
    2,117
    I have checked the coil wire on my 95 LT1 and it was super clean. The resistance was 2.5 kOhm, which is normal for a 12" plug wire. The ICM area was superclean as well. Probably the wire is not MY problem. Will keep investigating.
    turbojimmy's Avatar
    turbojimmy is offline Cadillac Owners Connoisseur
    Automobile(s): 1994 Fleetwood 60" Stretch; '07 Avalanche, '95 Nighthawk
    Apr 2004
    New Jersey
    3,963
    Can you power through it? For example, will it stop "stuttering" when you give it more gas? If so, it's probably the TCC solenoid.
    If it's not missing/stuttering under any other circumstances, it's probably the solenoid not holding and thus allowing the converter to lock/unlock rapidly until the PCM calls for a TCC unlock.
    Mar 2010
    northern ny
    60
    139
    turbojimmy, i can power through the stutter. i checked the wires and they have been replaced, the icm is clean, no corrostion. i think it is the tcc solenoid as the car runs excellent throughout it's operating ranges.
    HUF's Avatar
    HUF
    Dec 2005
    MA
    58
    2,117
    Do not jump to conclusion yet... Have you ever checked your exhaust manifold bolts and studs? If you have not done it , the chances are you will find some of them loose, missing or snapped/sheared off... A very common problem of all LT1 engines. I have recently tightened only two bolts on the driver side because I saw small exhaust leak - bubbles coming from the edge of the gasket when some water was sprayed over it. That leak is gone and believe it or not he throttle response is better now. I cannot say for sire that my stutter is history, but it has not occurred today under conditions it usually would do. Check the bolts. Replace them with grade 8 flange hex bolts black finish. You need 3/8"-16 x 1.000" and 3/8"-16 x 1.500" bolts. See if it helps.
    Mar 2010
    northern ny
    60
    139
    ok guys, been awhile since i've got back to this problem. i replaced the tcc lockout solinoid with no luck. i tightened the exaust manifold bolts with no results so now i'm going after the plugs and wires
    thefleetwoodguy is offline Cadillac Owners Enthusiast
    Automobile(s): 95 triple black fwb
    Dec 2008
    S NH
    56
    890
    wires
  16. #14
    drmenard is offline Cadillac Owners Connoisseur
    Automobile(s): 95 fleetwood 81 deville
    May 2003
    Massachusetts
    1,186
    If it's not the wires its the cap and rotor... But more than likley it will take plugs, wires ,cap and rotor...
  17. #15
    HUF's Avatar
    HUF
    Dec 2005
    MA
    58
    2,117
    I believe it is in human nature... starting with the most difficult part! lol
  18. Remove Advertisements
