engine stutter on 1994 fwb - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 20 of 20
1985-1996 Fleetwood and Brougham Forum Discussion, engine stutter on 1994 fwb in Past Cadillac Vehicle Discussion; thanks guys, i checked the ground at the coil, icm all ok. the wires were replaced by someone but, they ...
  1. #16
    newside is offline Cadillac Owners Fanatic
    Automobile(s): 1994 fleetwood, 1979 deville, 1992 eldorado
    Mar 2010
    northern ny
    60
    138
    Re: engine stutter on 1994 fwb
    thanks guys, i checked the ground at the coil, icm all ok. the wires were replaced by someone but, they could have been the cheaper ones and are breaking down. i will replace them. does the water pump have to come off to replace the cap and rotor?
  2. #17
    outsider is offline Cadillac Owners Connoisseur
    Automobile(s): 87 Brougham, 1969 Calais, 95 FWB, 05 CTS, 07 SRX
    Sep 2009
    Buxton, Maine, United
    33
    4,149
    yes, the water pump does have to come off
  3. #18
    Mar 2010
    northern ny
    60
    138
    ok guys i found the cause of the stutter, as i replaced the wires i new they were to new to be the problem, but when i removed the last plug on the drivers side i had to heat it out, it was froze good. when i did get it out it was covered in a thick white build up. that's the one that was nagging me. i'm not sure how it got that way but it runs great
  5. #19
    jayoldschool's Avatar
    jayoldschool is offline GM RWD V8 addict
    Automobile(s): 81 FWB D'Elegance coupe
    Sep 2006
    Ontario, Canada
    44
    7,895
    Can we see a picture of the plug, please? Use the "macro" setting on your camera.
  6. #20
    Mar 2010
    northern ny
    60
    138
    sorry jayoldschool, i don't have a camera, i have to borrow one. the build up could be anti freeze. i'm going to keep an eye on that cylinder. i did replace the intake gaskets a short time ago and i hope the head gasket isn't seeping abit
  7. Remove Advertisements
