Alternator Install Help
Results 1 to 6 of 6
Like Tree1Likes
  • 2 Post By jayoldschool
1985-1996 Fleetwood and Brougham Forum Discussion, Alternator Install Help in Past Cadillac Vehicle Discussion; So I installed a new 270 amp alternator yesterday; but I was having a hard time getting the belt over ...
    beatz02's Avatar
    beatz02 is offline Cadillac Owners Fanatic
    Automobile(s): '94 FWB; '94 STS
    Feb 2010
    Gardena, CA
    33
    136
    but I was having a hard time getting the belt over the pulley. I stretched it over it but there has to be an easier way to get it on..
    I noticed that when I pulled the belt, one of the pulley's below moved up a little to accommodate the stretch..
    So how do I make belt installation easier?
    92 brougham is offline Cadillac Owners Member
    Automobile(s): 92 brougham
    May 2011
    24
    Re: Alternator Install Help
    That pulley that you seen move is the belt tensioner . Move that and the belt will go on
    outsider is offline Cadillac Owners Connoisseur
    Automobile(s): 87 Brougham, 1969 Calais, 95 FWB, 05 CTS, 07 SRX
    Sep 2009
    Buxton, Maine, United
    33
    4,165
    right, that moving pulley is the tensioner. to put the belt on you put a ratchet or wrench on the nut on that tensioner and turn it to move that pulley up and allow enough slack to get the belt on.
    beatz02's Avatar
    Feb 2010
    Gardena, CA
    33
    136
    Aight. So it's easier to reach the belt tensioner from the bottom, right? I'm about to take this one out and replace it with a 390 amp; Sweet!
    csbuckn is offline Cadillac Owners Master
    Automobile(s): 84 Coupe w/500
    Jan 2008
    Minneapolis
    5,614
    390 amp alt, wow!
    jayoldschool's Avatar
    jayoldschool is offline GM RWD V8 addict
    Automobile(s): 81 FWB D'Elegance coupe
    Sep 2006
    Ontario, Canada
    44
    7,940
    He's going to do some mobile welding on the side.
    outsider and outsider like this.
  9. Remove Advertisements
