Idle mixture screw broken.
Results 1 to 4 of 4
1985-1996 Fleetwood and Brougham Forum Discussion, Idle mixture screw broken. in Past Cadillac Vehicle Discussion; I have my q-jet off the engine, I tried adjusting one mixture screw, well it was seized and the head ...
    Fleetwood70 is offline Cadillac Owners Fanatic
    Automobile(s): 1970 Fleetwood 60-Special, 03 DHS
    Jan 2011
    27
    142
    I have my q-jet off the engine, I tried adjusting one mixture screw, well it was seized and the head just broke off of it, so there's no way to adjust it now. I set the other so the needle sticks out the same, but that's 6 turns out. Is that too rich? Will I have problems with it?
    92 brougham is offline Cadillac Owners Member
    Automobile(s): 92 brougham
    May 2011
    24
    Re: Idle mixture screw broken.
    Well I would drill out the screw and get another one . This way you can do the right adjustments
    Jan 2011
    27
    142
    Don't know how to drill it out, but I bought another throttle plate/body for ten bucks, works good now.
    May 2011
    24
    Cool...everything worked out
  7. Remove Advertisements
