Results 1 to 5 of 5
Thread: 78 deville engine in 68 deville
    Junior solis is offline Cadillac Owners Member
    Automobile(s): 64&68 deville
    May 2011
    Sandpoint, Idaho, United State
    35
    8
    I found a running driving 78 deville can I put the engine in my 68
    deVille33 is offline Cadillac Owners Connoisseur
    Automobile(s): 1977 Coupe (blue), 1977 Coupe (yellow), 1977 Coupe (green)
    Mar 2006
    Western Massachusetts
    1,493
    Re: 78 deville engine in 68 deville
    I don't see why not. The two engines are configuered about the same. The topic has never come up on the forum, because most enthusiasts would perfer the bigger engine in the larger bodied car. If you plan on doing this, ( you don't say how many miles on the 425 ) I would suggest checking your bearing clearances and replacing the timing gear set. You may also concider changing out the power steering pump, as the 472 pump has a double pulley.
    77CDV's Avatar
    77CDV is offline Cadillac Owners 10000+ Posts
    Automobile(s): 77 CDV, 06 DTS III, 69 FWB
    Mar 2006
    Newbury Park, CA
    45
    10,022
    What happend to the 500?
  5. #4
    May 2011
    35
    8
    The 500 sold
  6. #5
    lacville78 is offline Cadillac Owners Fanatic
    Automobile(s): None at the moment
    Feb 2011
    30
    374
    If your gonna use the 425 it should be pretty much a bolt in.
    Also you could hit up the classified section to sell some of the parts off the old 78 it should help finance the swap
    I have a 78 and am in need of parts and i hate to hear when they hit the crusher with good parts.
    When you pull the 425 consider putting an RV cam in it, that and good exhaust would wake it up
  • You may not post replies
