Changed all my interior bulbs to LEDs
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 18
1985-1996 Fleetwood and Brougham Forum Discussion, Changed all my interior bulbs to LEDs in Past Cadillac Vehicle Discussion; It's awesome - I highly recommend it. Looks more modern and actually illuminates the inside. The old, stock bulbs were ...
    turbojimmy's Avatar
    turbojimmy is offline Cadillac Owners Connoisseur
    Automobile(s): 1994 Fleetwood 60" Stretch; '07 Avalanche, '95 Nighthawk
    Apr 2004
    New Jersey
    3,963
    It's awesome - I highly recommend it. Looks more modern and actually illuminates the inside. The old, stock bulbs were useless.
    MudAnt's Avatar
    MudAnt is offline Cadillac Owners Enthusiast
    Automobile(s): 1986 Fleetwood Brougham d'Elegance
    Jun 2009
    Edmonton, Alberta, Canada
    24
    647
    Re: Changed all my interior bulbs to LEDs
    Are there any LEDs available for the 80's Broughams?
    turbojimmy's Avatar
    Apr 2004
    New Jersey
    3,963
    Quote Originally Posted by MudAnt View Post
    I'm sure there are. Find your bulb numbers and type them into eBay followed by "LED". That's how I found mine.
    csbuckn is offline Cadillac Owners Master
    Automobile(s): 84 Coupe w/500
    Jan 2008
    Minneapolis
    5,612
    Nice, less draw on the battery too, right?
    turbojimmy's Avatar
    Apr 2004
    New Jersey
    3,963
    Quote Originally Posted by csbuckn View Post
    Yes, much less draw. They're dimmable, too, but that's not an option on the Fleetwoods. My DTS would dim before they went out, which was neat.
    The-Dullahan is offline Cadillac Owners Master
    Automobile(s): Orange And Purple Lights.
    Jun 2009
    Sitting on The Levee
    29
    6,632
    Yes, much less draw, but in theory, unless you are using the lights while the car is sitting (not running) then it would not make much difference. Yes, Mudant, there are LED bulbs for your car. My Car has always had red LED bulbs. Probably the first modification I ever made to the car, aside from...you know...rebuilding the 307 so it actually ran again.
    SDCaddyLacky's Avatar
    SDCaddyLacky is offline Cadillac Owners Enthusiast
    Automobile(s): 94 Fleet Bro, 64 Deville. Past: 72 Sedan, 68 Coupe Deville
    Jul 2009
    San Diego, Cali
    587
    That's really cool, how about LEDS for the rear tail lights?
    turbojimmy's Avatar
    Apr 2004
    New Jersey
    3,963
    Quote Originally Posted by SDCaddyLacky View Post
    They make 'em, but unless they've changed somehow the lower current draw screws up the flashers.
    MudAnt's Avatar
    Jun 2009
    24
    647
    I've been thinking of getting an LED for my 3rd brake light as well, it slightly reduces your chances of being rear-ended
    Cadillacboy's Avatar
    Cadillacboy is offline Cadillac Owners Connoisseur
    Automobile(s): 1996 Cadillac Fleetwood Brougham
    Dec 2003
    36
    4,388
    That's a fantastic upgrade ,I am planning to change dull lights to LEDs too
    thefleetwoodguy is offline Cadillac Owners Enthusiast
    Automobile(s): 95 triple black fwb
    Dec 2008
    S NH
    56
    890
    great idea , I like the white light looks nice
    can you share the bulb #s for the 93-96 fwb's ?
    save us some time looking them up........
    turbojimmy's Avatar
    Apr 2004
    New Jersey
    3,963
    Sure,
    The courtesy lamps (above the doors) are 192s. The LED replacements say 192/194. The 194 is a higher-watt version of the 192, which is irrelevant for the LEDs. I did have to dremel each housing out a bit to accommodate the larger diameter base of the LED lamp. Depending on the type you get, you may have to do this too. I ordered a 5-LED 192/194 bulb. They have 4 LEDs in a "circle" and one at the end to closely mimic the light output of a regular bulb. HOWEVER, they sent me a 9 LED bulb, which has 8 in a circle (4 pairs) and one on the end. I made them fit, but they're too long. Get the 5 LED versions.
    I replaced the dome light with a 25-bulb LED panel. I don't know if regular Fleetwoods have a dome, or if it's a limo-thing. I hard-wired the 25-bulb panel into the housing. The LED panel has a adhesive backing and it stuck to the inside of the housing nicely.
    The door lamps (puddle lamps) are S 214-2, commonly referred to as "214" bulbs. They're 'bayonet' style bulbs. I got 6-LED replacements for those.
    Last, the rear view mirror lamps are 168s. I got 168 replacement bulbs, but they look big to me. I have not been able to dismantle the mirror yet to install them. Each bulb housing has a tiny torx-head screw on it. Need to figure out what size it is and get a torx bit.
    You can get all this stuff on eBay.
    Hope that helps.
    Stess is offline Cadillac Owners Member
    Automobile(s): Fleetwood -95
    Nov 2010
    Stockholm, Sweden
    17
    Looks really nice thanks for the info!
  16. #14
    sven914's Avatar
    sven914 is offline Cadillac Owners Connoisseur
    Automobile(s): 1989 Brougham d'Elegance, 1985 Fleetwood Brougham *Coupe*
    Dec 2008
    4,256
    Quote Originally Posted by turbojimmy View Post
    You need to wire resistors into the flasher circuit to make it work.
  17. #15
    Jun 2009
    29
    6,632
    The lower voltage draw problem with using LED bulbs for rear or signal lamps, causing the flashers to misfire is easily correctable. You need a different relay and that's it. Not too hard to find online or sometimes at some specialty electronics stores (Think hobby stores, not Autozone)
  18. Remove Advertisements
