Wiring for amplifier, anyone know a good firewall opening? - Page 3
Page 3 of 3 FirstFirst 123
Results 31 to 38 of 38
1985-1996 Fleetwood and Brougham Forum Discussion, Wiring for amplifier, anyone know a good firewall opening? in Past Cadillac Vehicle Discussion; Yes, hide the wires under the carpet. If you ground to the chassis, be sure to sand the area down ...
  1. #31
    beatz02's Avatar
    beatz02 is offline Cadillac Owners Fanatic
    Automobile(s): '94 FWB; '94 STS
    Feb 2010
    Gardena, CA
    33
    136
    Re: Wiring for amplifier, anyone know a good firewall opening?
    If you ground to the chassis, be sure to sand the area down to bare metal.
  2. #32
    Angelo Gargarello is offline Cadillac Owners Member
    Automobile(s): 86 cadillac fleetwood brougham
    Jun 2011
    Melvindale, Michigan, United S
    23
    27
    Okay will do thanks. Started at 6 it's 8 and all I got ran was the red and white and my remote wire half ran took an hour to rip the dash apart to run it :/ (installing a amp takes time!!)
  3. #33
    Stingroo's Avatar
    Stingroo is online now Cadillac Owners 10000+ Posts
    Automobile(s): '92 Caprice Wagon LS1/T56 | '01 Buick Century | '95 Lexus LS400
    Jun 2009
    Vero Beach, FL
    26
    18,446
    10 gauge wire?
    How small is your amp?
  5. #34
    Jun 2011
    23
    27
    like small got if off my friend and a sub for 20 bucks. But I went to best buy and the guy said it will work fine.
  6. #35
    The-Dullahan is offline Cadillac Owners Master
    Automobile(s): Orange And Purple Lights.
    Jun 2009
    Sitting on The Levee
    29
    6,632
    Ten Gauge? If you are running a piece of Ten Gauge from the battery, all the way to the trunk as power wire, while it will basically be the simplest install in the history of the world, how much amperage are you actually trying to get out of it on the other side?
    I usually use ten gauge for turn-on wire, as it's actually the smallest wire I keep spools of that I really use for the cars. Anything smaller I use for other projects.
  7. #36
    Jun 2011
    23
    27
    The 10G wire came in an AMP starter kit so I know it will power it I just didn't have the 200 to blow on the good wire that is when I get out of school
  8. #37
    csbuckn is offline Cadillac Owners Master
    Automobile(s): 84 Coupe w/500
    Jan 2008
    Minneapolis
    5,620
    From the engine, its under the brake booster. From inside, its above the brake peddle. You will see bigger vacuum lines coming out of a circular rubber grommet, just pull the grommet up a little and push the 10g through.
  9. #38
    Jun 2011
    23
    27
    Ya I hooked it up; ran the power cable next to the speedo cable coming up from the trans and it fit fine. About to upgrade to a 0 once I get my check and run a split box under the dash for lights and any thing else that would need power.
  10. Remove Advertisements
