Restoring The Cadillac Crest and Shield - Page 4
Page 4 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 46 to 60 of 61
Like Tree9Likes
1985-1996 Fleetwood and Brougham Forum Discussion, Restoring The Cadillac Crest and Shield in Past Cadillac Vehicle Discussion; Excellent work, Dave! The results of your crest resto are amazing....
  1. #46
    CADforce69 is offline Cadillac Owners Connoisseur
    Automobile(s): Cadillac Sedan de Ville 1969, Dodge 3700GT '73, Audi A3 1.8T
    Oct 2010
    Madrid (Spain)
    49
    1,634
    Re: Restoring The Cadillac Crest and Shield
  2. #47
    Longeardgaloot's Avatar
    Longeardgaloot is offline Cadillac Owners Member
    Automobile(s): 1968 Calais 4-Door Sedan
    Oct 2012
    Novato, CA
    52
    30
    Y'all have me inspired - I've got a 68 Calais and my trunk crest looks like this one, and my hubcaps ain't much better! Time to get to the hobby shop!
  3. #48
    cadillac kevin's Avatar
    cadillac kevin is offline Cadillac Owners Master
    Automobile(s): chevy 350 powered 86 FWB, 00 safari h.t. 66 toro, 83 lesabre
    Dec 2010
    St. Louis, MO
    6,395
    Quote Originally Posted by Longeardgaloot
    Testors colors are pretty much spot on to the factory caddy colors
  5. #49
    talismandave's Avatar
    talismandave is offline Cadillac Owners Master
    Automobile(s): 1980 Eldorado, 1974 Talisman, 2004 Volvo C70,
    Mar 2012
    Madison WI
    57
    7,893
    Glad you bumped this thread, I have been meaning to up-date.
    The Minwax poly has started to take on a slight amber tint to it. Still loos better than it did, but will have to redo it with a clear enamel at some point if it continues.
  6. #50
    ktr-sb is offline Cadillac Owners Fanatic
    Automobile(s): 06 SRX 3.6L 2WD
    Mar 2004
    427
    Quote Originally Posted by talismandave View Post
    Here's another take.
    It started out as proof of concept. The one on the right was a faded one that I got pretty cheap on ebay. The one on the left was the original - the clear cover material was completely gone, and on this one (from a 91) the "engraving" is actually a glued-on molded rubber piece. Only a scrap was left.
    So I scraped out and cleaned the emblem "cavity." Then I downloaded a high quality image of the emblem, making sure it was the same vintage. Next I imported the image into a Word document, and made sure to format the picture to actual size by measuring the emblem (it's like 1.2" or so). Hint: Use black and white draft mode with regular paper to save on ink and paper.
    Once I was sure I had the right image and the right size, I reset my printer for high-quality color photo printing, and used glossy photo paper to print. I then cut the image out and make sure it fits snugly, without creasing, into the emblem cavity.
    THIS NEXT STEP MUST BE DONE RIGHT. Take the lock cover, with the picture in place in the emblem cavity, and set it up on your workbench, making sure it is level both left/ right, top/ bottom, and on a diagonal. I used old single edge razor blades to shim the lock. Mix up some clear epoxy (I used Gorilla Glue brand) and pour it on top of the photo and in the cavity. Stop before overflowing, and, if necessary, use something long and thin that you don't mind throwing away (like a piece of weed eater string) and spread into the corners. IF THE LOCK COVER'S NOT LEVEL YOU WILL MAKE A MESS OF IT.
    I was impatient, and used halogen work lights to heat and cure the epoxy, so I think it yellowed a bit when it shouldn't have otherwise. And it has a fair amount of bubbles - this is the first time I cared about it cosmetically, perhaps more care, a fresher mix, or some other brand would cure that. But at arms-length, it looks very adequate, and the yellowed finish gives it an antique-y kind of original-ish look. My teenage son, for whose FBD'E this was done, chose it over the faded original.
    So, have at it. Not the best result, but not bad for an hour or so's work, using stuff I had on hand.
    talismandave likes this.
  7. #51
    Bro-Ham's Avatar
    Bro-Ham is offline Cadillac Owners Connoisseur
    Automobile(s): 1979 Sedan deVille d'Elegance
    Oct 2005
    Sarasota, FL
    49
    4,152
    Wow! That's great!
  8. #52
    lemonadeaf is offline Cadillac Owners Member
    Nov 2013
    4
    DUMP Question of the day
    does any one know what color names or color ID numbers Cadillac uses on their crest?
  9. #53
    Mar 2012
    Madison WI
    57
    7,893
    I doubt there are any official names or numbers? I just hit the Testors rack at the hobby shop.
    Red, blue, gold, black, and white, don't over-think it!
  10. #54
    Nov 2013
    4
    lol just notice i misspelled dumb
    alright that's fair enough. have you restored a crest from a steering Wheel before? i notice tutorials on key lock crest and hub caps. any advice for steering wheel? doing restoring for a buddy of mine and him sent me this pictures. (hopefully i uploaded them correctly)
  11. #55
    Nov 2013
    4
    steering wheel
  12. #56
    Mar 2012
    Madison WI
    57
    7,893
    Nope, never tried to pull one of those apart.
    Hopefully someone has and will chime in!
    BTW,
    lemonadeaf likes this.
  13. #57
    sven914's Avatar
    sven914 is offline Cadillac Owners Connoisseur
    Automobile(s): 1989 Brougham d'Elegance, 1985 Fleetwood Brougham *Coupe*
    Dec 2008
    4,256
    If it's a plastic emblem, then it can be popped off with a small screw driver or a knife. You need to be careful because they sometimes crack in half or the pegs that hold it the steering wheel brake off.
    The one's I've seen don't have the plastic cover over them (like on the c-pillar shields or the newer trunk locks), so the really don't need to be taken apart. Unless you want to clear coat it, you can paint it on the steering wheel; I would put newspaper everywhere and tape off the steering wheel with masking tape.
    lemonadeaf and Captdees like this.
  14. #58
    Nov 2013
    4
    great advise thank you everyone really appreciate it
  15. #59
    Captdees is offline Cadillac Owners Fanatic
    Automobile(s): 1979 Phaeton, 1967 Convertible, 1975 Talisman
    Feb 2014
    Kathleen Georgia
    122
    Hello all,
    I know this is super old thread but I just had to post this super easy way to restore wheel cover emblems I discovered this afternoon while reassembling my own.
    Drum roll!!!!! ............Ultra fine tip permanent sharpie markers.
    I just so happened to have an assorted pack a few feet away while working and it had every color I needed except for white so I decided to give them a try. The results where astonishing. The super fine tip makes it a breeze getting in between all the little nooks and crannies. I know it might be hard to believe but I dare anyone in doubt to give it a try. If I had a camera I would post pictures but unfortunately I can only take crappy phone pics.
  16. #60
    pompste is offline Cadillac Owners Connoisseur
    Automobile(s): 1995 SEDAN DEVILLE-4.9 & 1978 SEDAN DEVILLE-425
    Jan 2007
    1,673
    Quote Originally Posted by Captdees View Post
    Hello all,
    Glad you found a quick easy way!
    I hope they "don`t" fade in the sunshine.Even if they did fade,you could just do them again.
  17. Remove Advertisements
