500 CID swap: Building the '79 Cadillac that should have been - Page 6
Page 6 of 6 FirstFirst 123456
Results 76 to 85 of 85
1985-1996 Fleetwood and Brougham Forum Discussion, 500 CID swap: Building the '79 Cadillac that should have been in Past Cadillac Vehicle Discussion; Distributor is in. Man, the car is a beast now. Mash the gas and she hunches backwards for just a ...
  1. #76
    bicentennialcadillac is offline Cadillac Owners Enthusiast
    Automobile(s): '76 Fleetwood Brougham, '79 Sedan deVille
    Aug 2004
    39
    635
    Re: 500 CID swap: Building the '79 Cadillac that should have been
    Distributor is in. Man, the car is a beast now. Mash the gas and she hunches backwards for just a split second and then wooooooosh. Highly recommend the MSD from MTS.
    As promised, pics ...
    Open element air cleaner and true duals are up next.
  2. #77
    Stingroo's Avatar
    Stingroo is online now Cadillac Owners 10000+ Posts
    Automobile(s): '92 Caprice Wagon LS1/T56 | '01 Buick Century | '95 Lexus LS400
    Jun 2009
    Vero Beach, FL
    26
    18,449
    Why go with the open element? Isn't your current setup technically better, since it seems to be drawing air in from outside behind the grille, which would be colder than under-hood air?
  3. #78
    Aron9000's Avatar
    Aron9000 is offline Cadillac Owners Master
    Automobile(s): Past: 95 Fleetwood, 91 Brougham. Now: 92 Lexus SC300
    Jul 2008
    Nashville, TN
    5,418
    I've always wondered this, but what does that small hockey puck looking thing on the air intake snorkel do? My 1991 has the same sort of air cleaner setup, I'm guessing its some sort of emissions control device since I never see it on pre 1971 cars.
  5. #79
    Aug 2004
    39
    635
    Quote Originally Posted by Stingroo View Post
    It's also drawing in hot air via the "hockey puck," which appears to be intended to draw hot air off the exhaust manifolds back into the intake.
    Really I just want to be able to hear that intake better at WOT.
  6. #80
    deVille33 is offline Cadillac Owners Connoisseur
    Automobile(s): 1977 Coupe (blue), 1977 Coupe (yellow), 1977 Coupe (green)
    Mar 2006
    Western Massachusetts
    1,493
    The hockey puck is a vacuum valve for cold starts. After the TVS reaches operating temperure, it allows vacuum to the valve which shuts the door to the hot air coming off the manifolds.
  7. #81
    outsider is offline Cadillac Owners Connoisseur
    Automobile(s): 87 Brougham, 1969 Calais, 95 FWB, 05 CTS, 07 SRX
    Sep 2009
    Buxton, Maine, United
    33
    4,198
    nice, I wanna get one of these distributors for my 69 caddy. what was the price range on one of these things? :O
  8. #82
    BigPoppaD is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Jun 2007
    84
    Quote Originally Posted by cosmo View Post
    Last time I swapped a 425 oil pan onto a 472, I had to shorten the pickup support owing to the longer caps on the 472. Seems Cadillac saved some weight by making the block even more thinwall, and even making the main caps smaller overall.
    And I had no problems with clearance, but, again, it was a 472.
    Oh, yeah, great build, and, true, an easy way to get a LOT more torque!
    Cosmo
    I'm prepping a 472 to drop into my 78. Are fitting issues the reason for the oil pan swap?
    Never mind, found out the sump of the pan is in different locations. Good info
  9. #83
    Aron9000's Avatar
    Jul 2008
    Nashville, TN
    5,418
    Quote Originally Posted by deVille33 View Post
    So I was right, it is an emissions control device. Helps the car warm up faster, carb cars run pig rich when they're cold, thus more emissions.
  10. #84
    casciomichael is offline Cadillac Owners Member
    Automobile(s): 1993 Sedan DeVille, 1978 Coupe DeVille (Project Car)
    May 2006
    Northern New Jersey
    29
    54
    How many degrees of base timing? Also what are the timing specs as far as Vaccum advance and total timing at WOT with this distributor?
    I like what you did with the car, keep it stock looking under the hood. I will have to post a pic of my dual snorkel cadillac air cleaner that I made. Looks stock but gives extra flow.
    Thanks,
    Mike
  11. #85
    Fleetwood472 is offline Cadillac Owners Fanatic
    Automobile(s): 78 Fleetwood w/ FI 472/ Switch pitch TH400
    Aug 2005
    240
    Nice thread. Figured i'd add a little bit of info with a 472/500 swap into the 77-92 caddies. If you drop in a 472/500 you can either reuse the existing 425 exhaust manifolds or you can use the 472/500 exhaust manifolds with slight modifications to the passenger side. The a-arm bolt needs to be trimed down a little to clear the 472/500 passenger side exhaust manifold. Also you need to grind the a-arm a bit for clearance issues. While the exhaust manifolds are being resurfaced at the machine shop you can have them mill off 3/8ths of an inch from the front landing on the passenger side of the exhaust manifold for clearance. The 472/500 exhaust manifolds are not as restrictive as the 425 exhaust manifolds. The idea of milling the exhaust manifold landing was thought up by Dave Menard from the MTS forum. Here are a couple of pics from my 78 fleetwood. One is a pic of when I learned the hard way and did the swap without milling the front landing and as you can see the a-arm hits the exhaust manifold bolt. The 2nd pic shows the front landing of the exhaust manifold milled down so the bolt clears the a-arm.
    Attachment 81829
  12. Remove Advertisements
