Results 1 to 4 of 4
    tbcaddy18 is offline Cadillac Owners Fanatic Cadillac(s) I Drive: 1986 FWB 307
    Apr 2007
    Southern California
    22
    193
    Signs of a bad water pump? 86 FWB
    Hey all,
    Does anyone know what the warning signs are for a water pump starting to go bad?
    ...just asking because when im driving my car (86 FWB 307), when accelerating under load I hear a squeaking noise. This only happens when the car reaches operating temperature and under load. The car does not overheat.
    I also tried the test where you try and move the fan up and down (since the fan is connected to the front of the water pump) to see if it's loose or not, and it is slightly loose, but nothing to be worried about.
    I dont think its a transmission issue, as it runs and shifts fine...I also recently changed the transmission fluid and the TCC solenoid in it. My car has 155,0000 miles, ive never changed any major parts on it.
    Thanks,
    Tabz
  2. Cadillac Network Advertisements Registered members do not see these ads. Click here to remove them.
    Always
    Advertising world
    2010
    Many
    Angry Matt is offline Cadillac Owners Fanatic Cadillac(s) I Drive: '81 CDV, '81 FWB
    May 2009
    Limerick, PA
    31
    495
    Re: Signs of a bad water pump? 86 FWB
    The water pump won't feel that loose with the belt on. If you can get the belt off, the water pump will rattle when you move the fan if it's shot. Also check and see if it's leaking, some of them have a small port on the bottom that will drip when they are ready to be replaced. I've had several go in the past and mine always make noise all the time, not just under load. Not saying they can't, just sharing my experiences. They sound like loud skateboard bearings at idle.
    Apr 2007
    Southern California
    22
    193
    hmm.. yea no leaking on mine as of yet. I guess I'll just wait and see if the noise gets louder/worse and go from there.
  5. Sponsored Cadillac Advertisements (Supporting Members don't see these ads):
    Ian6 is offline Cadillac Owners Fanatic Cadillac(s) I Drive: 89 Brougham, 98 Deville, 04 DTS, 05 Deville
    Feb 2010
    Fort Worth, Texas
    19
    222
    my 307. 89 brougham has a weep hole on the water pump, and when it started to leak from there is when i changed it. idk if this helps but i would think if its not leaking you should be good. but if you're that worried about it just take it to your mechanic if you know a good honest one.
Simply register and/or login to remove these advertisements.
  • You may not post replies
custom floor mats | cadillac performance mufflers | cadillac performance exhaust systems | racing seats | cadillac euro tail lights | cadillac air intakes | cadillac projector headlights | cadillac ground effects | cadillac floor mats | cadillac escalade body kits, hoods and lambo doors | cadillac body kits | cadillac carbon fiber hoods | air suspension kits | air suspension parts | air ride suspension | hyundai genesis forum | kia forte forum | used car savings
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183
