Go Back   Cadillac Owners Group > Past Cadillac Vehicle Discussion > RWD 19xx-1984 DeVille and Fleetwood,
1985-1996 Fleetwood and Brougham Forum
Forum for discussions regarding the rear wheel drive Pre80s-1984 DeVille
and Fleetwood, 1985-1996 Fleetwood/Brougham.
Cadillac Forums: Loud Engine Knocking?
Old 11-04-09, 11:54 AM
DopeStar 156's Avatar
Forbidden in Heaven and useless in Hell.
Cadillac(s): 05 STS / 89 Fleetwood Brougham d'Elegance / 76 Coupe deVille
View DopeStar 156's Photo Album
Casino Cash: $11910
Went to start up my '76 today and while it was idling I was revving the engine since it sounded like it was bogging a little. After a few revs I now hear this loud knocking coming from the engine when it runs. Car has oil in it and no fluids are pouring out of the car or anything like that, the engine just knocks really bad. What happened and how can I fix this?
‡ DopeStar ‡
  #2 (permalink)
Old 11-04-09, 12:02 PM
Cadillac(s): 1994 Fleetwood Brougham
View Stingroo's Photo Album
Casino Cash: $4515
re: Loud Engine Knocking?
Plugs and wires maybe?
  #3 (permalink)
Old 11-04-09, 12:19 PM
Cadillac Owners Enthusiast
Cadillac(s): 90 broughams
View csbuckn's Photo Album
Casino Cash: $10345
Re: Loud Engine Knocking?
If it sounds like a metal knock or tic that gets faster as you rev the engine......
I know how mad you get when the cars arent going right so I dont want to tell you any bad news. If its just a lifter, you may be able to get away with some fresh oil and some additive. Another thing you can look at is the flywheel, when it comes loose or cracks it makes a simular sound. The flywheel is a long shot but it happened to me on a caprice. An automotive stethoscope would be a big help.
  #4 (permalink)
Old 11-04-09, 12:25 PM
Casino Cash: $11910
It's a knocking sound that matches the speed of the engine, I guess it sounds like metal. Whatever it is I just wanna know. I wasn't even revving it that hard, just a few shots of the accelerator to stretch it's limbs so to speak.....
  #5 (permalink)
Old 11-04-09, 01:04 PM
Casino Cash: $10345
Worst case scenerio, its a bearings or a lifter. Either way the motor will have to be opened up. Lifters are not that hard but a bearing is a decent amount of work.
  #6 (permalink)
Old 11-04-09, 02:58 PM
tateos's Avatar
Cadillac(s): 1997 ETC, 2000 DTS
View tateos's Photo Album
Casino Cash: $8359
I did that once to an engine once - the ticking got worse and worse - ended up I had spun a connecting rod bearing
  #7 (permalink)
Old 11-04-09, 04:16 PM
greencadillacmatt's Avatar
Cadillac(s): 1984 Coupe DeVille 1990 Brougham d'Elegance 350
View greencadillacmatt's Photo Album
Casino Cash: $5630
If it was a bearing that's on it's way out, wouldn't he have low oil pressure? Might that be a way to identify what it is? I hope it's nothing too serious, I really like that '76 of yours.
  #8 (permalink)
Old 11-04-09, 04:45 PM
Casino Cash: $10345
He'd still have oil pressure unless maybe the bearing material spun down into a main oil passage and clogged it but I've never seen that before.
  #9 (permalink)
Old 11-04-09, 05:17 PM
Cadillac(s): 94&95 fltwd brghm's, 01 VIPER GTS
View thefleetwoodguy's Photo Album
Casino Cash: $7695
racing a cold engine can and does cause lifter "hangup"
Im not sure id call that a knock, more of a clacking sound
which will normally go away after a mile or so of driving
if its a loud wrapping noise, that would make me think connecting rod big end
  #10 (permalink)
Old 11-04-09, 06:07 PM
Cadillac(s): 1980 Sedan deVille D'Elegance
View flux1414's Photo Album
Casino Cash: $1860
I've been wondering what that damn clicking noise is for the first minute or two after a cold start...Thanks
Is that something I should worry about?
  #11 (permalink)
Old 11-04-09, 07:40 PM
Angry Matt's Avatar
Cadillac(s): '81 CDV, '81 FWB, '95 SDV
View Angry Matt's Photo Album
Casino Cash: $4805
My 472 was tapping really bad after a recent unrelated issue. It sat for a week or two prior to me starting it and the tap worked itself out after about 5 minutes or so of idling. How long did you have it running for? Chances are, if you haven't been driving it and you didn't do anything to harm it, it's probably nothing. Try some tranny fluid down the primaries when it's idling high, that should cure a carbon knock.
No, mine does that, the oil just hasn't worked its way everywhere yet.
  #12 (permalink)
Old 11-04-09, 07:41 PM
jayoldschool's Avatar
GM RWD V8 addict
Cadillac(s): 81 FWB 2DR, 65 Impala, 95 SS, 71 Pontiac, 94 Caprice, 92 RMW
View jayoldschool's Photo Album
Casino Cash: $18269
Lifter tick is a lot different than rod knock. No possible way to confuse the two.
  #13 (permalink)
Old 11-04-09, 10:56 PM
Casino Cash: $11910
Thanks everyone. Car's been sitting since this afternoon so what I'll do is do an oil change this weekend and start it up again. The car does do a lot of sitting so it might just be something that's stuck or hung up. For the time being I'll leave it alone and maybe it'll free itself up, if not it looks like I may be taking an engine apart at some point....
  #14 (permalink)
Old 11-04-09, 11:05 PM
I~LUV~Caddys8792's Avatar
Casino Cash: $21907
Dope, before you do an oil change on the old beast, go to BGfindashop.com, type in your zip code, and when you find the nearest retailer, have them sell you a can of 105 (BG Quick Clean For Engines) and add that to the old oil and run it for 15 minutes and change the oil. What 105 does is eat away at the deposits that build up on lifters & rocker arms and washes it away with the oil. If you do this and the noise goes away, then it's just a noisy lifter or rocker arm. If not, then it's something more serious. Either way, a can of 105 runs about $7.00, so it's cheap insurance.
105 is described in further detail here:
http://www.bgprod.com/products/engineoil.html
Here's BG find-a-shop.
http://www.bgfindashop.com/locator/index.php
Let us know what happens!
-Chad
From all of these signs saying sorry but we're closed
All the way down the telegraph road
-Dire Straits, Telegraph Road. 1982
  #15 (permalink)
Old 11-04-09, 11:13 PM
sven914's Avatar
Cadillac(s): 89 Brougham deVille d'Elegance
View sven914's Photo Album
Casino Cash: $4565
Engine noises can be the hardest to diagnose, mainly because there are some many things that make similar sounds, but also because people have different way of describing the sound.
Rod Knock: Occurs when either the wrist pin bearing or the rod main bearing deteriorates to a point that it allows the piston to move in the cylinder bore (small end knock: commonly referred to as piston slap) or the end of the connecting rod to bang around on the crank shaft journal (big end knock: most common and is terminal). Rod Knock is most noticeable over 2500 RPM, but feathering the gas will cause a distinctive back rattle between 2500-3500 RPM.
Valve Train Noise: Gets louder with an increase in RPM, and is caused by Low Oil Pressure, Excessive Valve Lash, or Damaged Parts. If the noise goes away after the engine warms up, it could suggest a sticking lifter.
engine, knocking, loud, tapping
