RWD 19xx-1984 DeVille and Fleetwood, 1985-1996 Fleetwood and Brougham Forum Forum for discussions regarding the rear wheel drive Pre80s-1984 DeVille and Fleetwood, 1985-1996 Fleetwood/Brougham. | Cadillac Forums: Loud Engine Knocking?
11-05-09, 12:05 AM
|  | GM RWD V8 addict Cadillac(s): 81 FWB 2DR, 65 Impala, 95 SS, 71 Pontiac, 94 Caprice, 92 RMW | | Join Date: Sep 2006 Location: Ontario, Canada Age: 37 | | | Re: Loud Engine Knocking? Good vid references. I will say that the rod knock that I have experienced is a deeper tone than that. Would probably have to do with the V configuration and much more block material than the boxer engine in the Subie... |
11-05-09, 03:00 AM
|  | Cadillac Owners Connoisseur Cadillac(s): 77 CDV, 01 ETC, 06 DTS III, 69 FWB | | Join Date: Mar 2006 Location: Newbury Park, CA Age: 37 | | | Re: Loud Engine Knocking? Well, heck, Dope, November doesn't seem to be your month! Here's hoping things are just sticking a little from the car sitting so much. I'd really hate to see major engine work needed. Let us know what happens. |
11-05-09, 03:06 AM
|  | Forbidden in Heaven and useless in Hell. Cadillac(s): 05 STS / 89 Fleetwood Brougham d'Elegance / 76 Coupe deVille | | Join Date: Dec 2003 Location: North Jersey Age: 23 | | | Re: Loud Engine Knocking? It sounds like the rod knock video......
‡ DopeStar ‡  |
11-05-09, 10:10 AM
| | Cadillac Owners Member Cadillac(s): 1980 Sedan deVille D'Elegance | | | | | Re: Loud Engine Knocking? Quote: |
| That sucks dude, I feel for ya. Sounds like you may get to experience the joy of pulling and rebuilding an engine... |
11-05-09, 11:45 AM
|  | Forbidden in Heaven and useless in Hell. Cadillac(s): 05 STS / 89 Fleetwood Brougham d'Elegance / 76 Coupe deVille | | Join Date: Dec 2003 Location: North Jersey Age: 23 | | | Re: Loud Engine Knocking? Well considering I can't drive it anywhere or tow it, I'm kinda screwed here. How hard is it to do something like this? |
11-05-09, 12:17 PM
|  | GM RWD V8 addict Cadillac(s): 81 FWB 2DR, 65 Impala, 95 SS, 71 Pontiac, 94 Caprice, 92 RMW | | Join Date: Sep 2006 Location: Ontario, Canada Age: 37 | | | Re: Loud Engine Knocking? You can drive it to a garage. It may or may not seize up on the way.
If it were me, I would do the following. Pour in a quart of trans fluid. Run the engine, get it up to temp. If it is a sticking lifter, the trans fluid will free it up. If you have wiped a lobe off the cam, the tick will still be there. If it is rod knock, the noise will be there. Turn the engine off, jack it up, and drain your oil. Carefully examine the oil for metal particles or a "silver-y" sheen. This will be the remains of the soft bearing material. Remove the oil filter and let it drain. Cut it open, and unfold the filter material. Look for metal particles. If you find metal in the oil and/or filter, you have lost a bearing, and the engine will need a tear down. You can pull the pan (have to remove the engine mount bolts and jack up the engine a few inches) and check the rods on the crank. If you have wiped or spun a bearing, the rod will be loose on the crank. Engine must come out, crank must be turned, and new bearings go in. |
11-05-09, 12:47 PM
|  | Forbidden in Heaven and useless in Hell. Cadillac(s): 05 STS / 89 Fleetwood Brougham d'Elegance / 76 Coupe deVille | | Join Date: Dec 2003 Location: North Jersey Age: 23 | | | Re: Loud Engine Knocking? |
11-05-09, 03:11 PM
|  | GM RWD V8 addict Cadillac(s): 81 FWB 2DR, 65 Impala, 95 SS, 71 Pontiac, 94 Caprice, 92 RMW | | Join Date: Sep 2006 Location: Ontario, Canada Age: 37 | | | Re: Loud Engine Knocking? That sounds like exhaust leak, not knocking. I know, the audio is bad, and I'm sure it is much easier to tell in person... |
11-05-09, 05:28 PM
|  | Forbidden in Heaven and useless in Hell. Cadillac(s): 05 STS / 89 Fleetwood Brougham d'Elegance / 76 Coupe deVille | | Join Date: Dec 2003 Location: North Jersey Age: 23 | | | Re: Loud Engine Knocking? It has that already hahahaha. It'd be awesome if that's all it is but I dunno. |
11-05-09, 06:01 PM
| | Cadillac Owners Member Cadillac(s): 1980 Sedan deVille D'Elegance | | | | | Re: Loud Engine Knocking? I agree with Jay, it sounds a lot like exhaust. My '80 was without manifold gaskets and it sounded quite similar. It's tough to really tell with the video though...you may be lucky yet  |
11-05-09, 08:05 PM
| | Cadillac Owners Connoisseur Cadillac(s): 1994 Fleetwood Brougham | | Join Date: Jun 2009 Location: Stuart/Jacksonville, Florida Age: 19 | | | Re: Loud Engine Knocking? You know what it really reminds me of?
Speed Buggy. |
11-05-09, 09:08 PM
|  | GM RWD V8 addict Cadillac(s): 81 FWB 2DR, 65 Impala, 95 SS, 71 Pontiac, 94 Caprice, 92 RMW | | Join Date: Sep 2006 Location: Ontario, Canada Age: 37 | | | Re: Loud Engine Knocking? Dope, engine knock on a cast iron V8 sounds like a 5lb sledghammer hitting a manhole cover. Does that make sense? It is really deep, no echo, low frequency. |
11-05-09, 09:27 PM
| | Cadillac Owners Enthusiast Cadillac(s): 90 broughams | | Join Date: Jan 2008 Location: Minneapolis | | | Re: Loud Engine Knocking? that almost sounds to fast to be a bearing. |
11-06-09, 12:57 AM
|  | Cadillac Owners Enthusiast Cadillac(s): 89 Brougham deVille d'Elegance | | Join Date: Dec 2008 Location: Louisville OH Age: 21 | | | Re: Loud Engine Knocking? I agree, it sounds too high to be a main bearing. It does sound right to be piston slap, which isn't harmful to the engine, just really annoying. If you hear what sounds like a double tap when you feather the gas, then piston slap is the problem. Also if the noise goes away when the engine warms up, it be a sign of piston slap, because as the metal expands with the heat, the piston fits the bore better.
This is what low end rod knock sounds like on a real engine (be patient it'll eventually start): |
11-07-09, 03:44 AM
|  | Forbidden in Heaven and useless in Hell. Cadillac(s): 05 STS / 89 Fleetwood Brougham d'Elegance / 76 Coupe deVille | | Join Date: Dec 2003 Location: North Jersey Age: 23 | | | Re: Loud Engine Knocking? So you think I blew a manifold gasket or something? How can I really be sure? I'll change the oil this weekend and let it run for a while and see if it straightens out. God i hope so, I don't have the heart to dump this car..... | | Cadillac Discussion Tools | | |
Censor is ON | | | |
