RWD 19xx-1984 DeVille and Fleetwood, 1985-1996 Fleetwood and Brougham Forum Forum for discussions regarding the rear wheel drive Pre80s-1984 DeVille and Fleetwood, 1985-1996 Fleetwood/Brougham. | Cadillac Forums: Throttle Body 95FWB
10-05-09, 08:01 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 1995 FWB 87,*** 1991 Seville 175,000 SOLD | | Join Date: Dec 2005 Location: MA Age: 50 | | | Throttle Body 95FWB Are deposits common on throttle bores and plates? I know that it is a little bit complicated because of coolant involved, but do you clean the throttle body regularly anyway? Thanks.
10-05-09, 08:59 PM
| | Cadillac Owners Fanatic Cadillac(s): 94&95 fltwd brghm's, 01 VIPER GTS | | Join Date: Dec 2008 Location: S/NH Age: 49 | | | Re: Throttle Body 95FWB yes common to get that gunky buildup on the throttle blades/bores
just dont use gumout to clean it, although it works it can mess up the o2 sensors, there is a product out there thats made for that purpose (sensor safe)
cant remember the name but it should be on the shelf at any decent
parts store, spray it and wipe it out with a rag, is the method I use
very easy to do....... |
10-05-09, 09:16 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 1995 FWB 87,*** 1991 Seville 175,000 SOLD | | Join Date: Dec 2005 Location: MA Age: 50 | | | Re: Throttle Body 95FWB Quote:
Originally Posted by thefleetwoodguy yes common to get that gunky buildup on the throttle blades/bores
very easy to do....... | Thanks for the reply. You probably mean o2 sensor-safe carb cleaner. Any learning procedure after cleaning (like disconnecting the battery for a minute)? Or just drive for a while and let the PCM learn new (clean) throttle condition? |
10-05-09, 09:21 PM
| | Cadillac Owners Enthusiast Cadillac(s): 90 broughams | | Join Date: Jan 2008 Location: Minneapolis | | | Re: Throttle Body 95FWB This reminds me of those zmax commercials on speed tv |
10-05-09, 09:25 PM
| | Cadillac Owners Fanatic Cadillac(s): 94&95 fltwd brghm's, 01 VIPER GTS | | Join Date: Dec 2008 Location: S/NH Age: 49 | | | Re: Throttle Body 95FWB Quote:
Originally Posted by HUF Thanks for the reply. You probably mean o2 sensor-safe carb cleaner. Any learning procedure after cleaning (like disconnecting the battery for a minute)? Or just drive for a while and let the PCM learn new (clean) throttle condition? | just clean and go, Ive noticed smoother idle on the few Ive cleaned that were dirty...... |
10-05-09, 09:27 PM
| | Cadillac Owners Fanatic Cadillac(s): 94&95 fltwd brghm's, 01 VIPER GTS | | Join Date: Dec 2008 Location: S/NH Age: 49 | | | Re: Throttle Body 95FWB hey huf may have that inner wheel well
if your still looking, got a 94 fltwd in a couple days ago
just got to verify its not rusty
Ill let you know if you like JIM |
10-05-09, 09:34 PM
Ill let you know if you like JIM | Yep, still need one. Please check out the condition but do not remove yet. The dealer I've bough the car from may have one for me too. I am waiting for a response from him. He insists he was not aware of the issue. |
10-07-09, 03:00 PM
|  | Cadillac Owners Master Cadillac(s): 94 Fleetwood Brougham | | Join Date: Aug 2004 Location: Rockford, IL Age: 42 | | | Re: Throttle Body 95FWB I put in a Ford 2.9L PCV filter in my LT1, haven't had a single deposit on my TB blades since.
Basically get the PCV filter that I list here. In the pass side valve cover where the hose goes into the valve cover, remove the elbow and insert the PCV filter, then cut down the hose to the TB so it will fit in the PCV filter.
Works very well. I was cleaning my TB every 6 months or so like you are supposed (GM says to clean almost every car's TB, few do.... on almost every car, at least around every 30K miles I think is spec), and since I have not NEEDED to clean it. The nice thing is it looks OEM.
I cleaned mine with a rag and TB cleaner. Have someone lock throttle open or block it open somehow.
I had my coolant to TB blocked at the time, so removing TB was very easy. Those lines are a bugger.... http://www.cadillacforums.com/forums...fleetwood.html (What basic performance mods for my Fleetwood???) |
10-07-09, 11:34 PM
Originally Posted by N0DIH I put in a Ford 2.9L PCV filter in my LT1, haven't had a single deposit on my TB blades since.
I had my coolant to TB blocked at the time, so removing TB was very easy. Those lines are a bugger.... http://www.cadillacforums.com/forums...fleetwood.html (What basic performance mods for my Fleetwood???) | NODIH,
Thank you for the info. Interesting! | | Cadillac Discussion Tools | | |
Censor is ON | | | |
