RWD 19xx-1984 DeVille and Fleetwood, 1985-1996 Fleetwood and Brougham Forum Forum for discussions regarding the rear wheel drive Pre80s-1984 DeVille and Fleetwood, 1985-1996 Fleetwood/Brougham. | Cadillac Forums: Brougham Tail Light Lens Repair
10-03-09, 12:51 AM
| | Cadillac Owners Member Cadillac(s): 1988 Brougham | | | | | Brougham Tail Light Lens Repair Just wondering if anyone has had any luck repairing the Brougham/RWD tail light lenses. Mine are old, and the tabs are breaking off the ends, which prohibit me from attaching the chrome bezel around the perimeter of the lens. Has anyone repaired these, and if so, was it epoxy, glue, or was there some kind of steel sleeve? |
10-03-09, 11:18 AM
| | Cadillac Owners Enthusiast Cadillac(s): 90 broughams | | Join Date: Jan 2008 Location: Minneapolis | | | Re: Brougham Tail Light Lens Repair I would probably go to the store and find the best glue, probably super glue, and go from there. If it works, I could only imagine its temporary. Especially in the winter |
10-03-09, 11:38 AM
| | Cadillac Owners Connoisseur Cadillac(s): 1994 Fleetwood Brougham | | Join Date: Jun 2009 Location: Stuart/Jacksonville, Florida Age: 19 | | | Re: Brougham Tail Light Lens Repair I don't recommend super glue for anything. Get some Marine Epoxy, it's meant to get wet.
I rebuilt the entire front driver's side door panel of my dad's Mazda 929 with factory clips, a tube of Loctite Marine Epoxy, and a pair of chopsticks. It's been on there for over a year.
It's not that expensive either, like $5.50 at your local hardware store. |
10-03-09, 11:56 AM
|  | GM RWD V8 addict Cadillac(s): 81 FWB 2DR, 65 Impala, 95 SS, 71 Pontiac, 94 Caprice, 92 RMW | | Join Date: Sep 2006 Location: Ontario, Canada Age: 37 | | | Re: Brougham Tail Light Lens Repair Just replace the part. There are tons of them out there... it is the same from 80-89. |
10-03-09, 11:58 AM
| | Cadillac Owners Enthusiast Cadillac(s): 90 broughams | | Join Date: Jan 2008 Location: Minneapolis | | | Re: Brougham Tail Light Lens Repair Quote:
Originally Posted by Stingroo and a pair of chopsticks | thats funny, I quess I need some for my toolbox |
10-03-09, 12:17 PM
| | Cadillac Owners Connoisseur Cadillac(s): 1994 Fleetwood Brougham | | Join Date: Jun 2009 Location: Stuart/Jacksonville, Florida Age: 19 | | | Re: Brougham Tail Light Lens Repair Used to spread the epoxy so it didn't get on my fingers. Chinese take out is handy sometimes.  |
10-03-09, 05:57 PM
| | Cadillac Owners Connoisseur Cadillac(s): 92 eldorado, 97 S.T.S.. | | Join Date: Nov 2005 Location: roberts creek b.c. canada | | | Re: Brougham Tail Light Lens Repair I fixed my 80 cdv. once, it sounds the same as your problem,I cut a small piece of hard wood into a rectangle shape,I then screwed the wood to the trim piece,(leaving just enough room to put it in place in the housing) then spin the wood piece so it's at right angles to the housing,then pull out on it so the wood will not spin when tightening the screw. hope this is what your after. | | Cadillac Discussion Tools | | |
Censor is ON | | | |
