I'm purchasing a 69 Deville convertible, and would like info and specs on what type of rear axle this is. I am planning performance mods, (+300 hp over stock) and am concerned with strength of the rear axle. Ring gear size? axle strength? Parts availability? Posi carrier? I've raced Chevy most of my life, but I am completely lost on finding info on this rear axle. I'm starting to think it's poor for performance. How would you rate it compared to a corporate 12 bolt?
Thanks for your input.
Went through the applicable sections of the factory service manual for you, and all I can tell you is that the standard gear ratio is 2.94:1 and that controlled rear differential was optional, noted with a "G" preceding the rear axle ratio code stamped on the housing. No other information is noted. I'm afraid I can't comment on the relative strength of the standard 1969 Cadillac axle versus a corporate 12 bolt model.
I think that rear end is every bit as strong as a Chevy 12 bolt but it may be harder to find lockers and gears for it. Then again it may be possible to mix 'n match some GM hardware in there.
Related Threads
Cadillac Owners Forum
4.8M posts
369.7K members
Since 2002
