Type of Engine Oil... curious...
Page 1 of 12 1 2 3 4 5 6 7 8 9 10 11 ... LastLast
Results 1 to 15 of 176
Like Tree1Likes
1985-1996 Fleetwood and Brougham Forum Discussion, Type of Engine Oil... curious... in Past Cadillac Vehicle Discussion; I apologize if there is already a thread for this, but I searched and I couldn't find anything so... I ...
    JamesC's Avatar
    JamesC is offline Cadillac Owners Fanatic
    Automobile(s): 1987 Brougham (sold), 1993 Fleetwood Brougham
    Aug 2009
    SE Wisconsin (a KS boy at <3 )
    31
    230
    I am curious what types of engine oil do you all use?
    What is the correct/proper oil type to be used in our old Cadillacs for them to run their best? (posed to 1980-1992 Fleetwood/Brougham owners specifically)
    Final note, this will probably show my naivete on the subject, but I'll risk it, I've heard that running synthetic oil through older cars is a big no, no - is this true?
    By the way, I didn't do that in my Caddy when I gave it it's tune up.
    jayoldschool's Avatar
    jayoldschool is offline GM RWD V8 addict
    Automobile(s): 81 FWB D'Elegance coupe
    Sep 2006
    Ontario, Canada
    44
    7,904
    Re: Type of Engine Oil... curious...
    The "no synthetic in an old car" is a complete myth. Every old car I buy, I put synthetic in. It is a superior product. If you can afford it, use it. Of course, regular dino (non-syn) oil is perfectly fine, as well. Just keep it changed on a regular schedule. You can find the correct oil viscosity for your driving conditions in your owner's manual. For most, it will be 5w30. If your engine is high mileage, I would suggest considering a slightly higher hot viscosity: 5w40. This will maintain pressure when the engine is idling at a stop light and help to eliminate a dim oil light that can happen with the 307 Olds motors.
    mjs182004's Avatar
    mjs182004 is offline Cadillac Owners Enthusiast
    Automobile(s): 91Broughamd'Elegance,06STS-V,76FWBd'Elegance,98SevilleSTS
    Dec 2008
    Eastlake, Ohio
    30
    769
    I use conventional Pennzoil 5w30, which reminds me that i need to do an oil change soon before winter hits
    DopeStar 156's Avatar
    DopeStar 156 is offline Cadillac Owners Master
    Automobile(s): 1989 Fleetwood Brougham d'Elegance|2015 Chevy Silverado 1500
    Dec 2003
    North Jersey
    31
    6,344
    Valvoline Max Life 10W30 and a quart of Lucas.....
    JamesC's Avatar
    Aug 2009
    31
    230
    Quote Originally Posted by jayoldschool View Post
    So would you suggest using a synthetic oil (probably 5W40)in my car for example, a 1987 Cadillac Brougham with 142,XXX miles? Draining the oil out and putting in a synthetic won't hurt it, yes? Currently it has Valvoline conventional oil in it mixed with a can of Restore... something my Mom put into her 1985 Caprice Classic ever since she bought in back in '91 or '92 (with 80,XXX some miles) at every oil change and it has over some 220,XXX miles on it.
    ALSO, what exactly makes synthetic oil superior over conventional oil (other than what you mentioned about conventional needing more so regular maintenance)? Also is there really a difference between high mileage oils over the regular types, as a mechanic once told me there's really no difference between them, but for price.
    Oh, and thanks for the info!
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,915
    Synthetics tend to maintain their viscosity ratings over a wider range of oil temperatures, they flow better at/during low temperature starts, and maintain an oil film longer under engine-off conditions (as in: sitting for a week or so.)
    BUT, newer automotive-grade synthetics, as well as SL and SM rated conventional oils, do not carry as high an anti-scuff additive package as the older ratings due to EPA pressure to "reduce emissions". Your engine uses flat-tappet valve lifters, so it needs all the protection you can reasonably provide. I, personally, would stop short of the Lucas additives.
    DopeStar's recommendation of a MaxLife, LongLife or fleet/marine conventional oil for your car is probably a better choice, as those types tend to carry a higher ZDDP (Zinc - Phosphorous anti-scuff) package than todays "energy conserving" lighter bodied oils. Your car, with 142,xxx miles, qualifies as high mileage. It will easily carry a fleet 10W-30 oil package. Use a WIX filter.
    Angry Matt's Avatar
    Angry Matt is offline Cadillac Owners Enthusiast
    Automobile(s): (2) '81 FWBs, '86 Cutlass Supreme
    May 2009
    Limerick, PA
    38
    690
    I am a believer that these cars were built before synthetic was on the market, so they don't need it. Not to say synthetic isn't better, but IMO I don't think it's necessary. Not to mention that I'll never pay that much for oil. I've always run 10w30 or 40, whatever namebrand is on sale and never had a problem. Don't ever buy oil from the dollar store. My wife came home with some once and it was blacker than the oil that I drained out of the car, so I put it in her corrolla.
    JamesC's Avatar
    Aug 2009
    31
    230
    Quote Originally Posted by submariner409 View Post
    Synthetics tend to maintain their viscosity ratings over a wider range of oil temperatures, they flow better at/during low temperature starts, and maintain an oil film longer under engine-off conditions (as in: sitting for a week or so.)...
    So... then you'd suggest to you 10W30 Valvoline MaxLife Conventional Oil for my car then, that would make it run at it's best? Although as you said some synthetics have an advantage over conventional... getting mixed answers among other people here ( >.< ) and not sure which would work best for my situation and car. Oh if it matters I'm in south-central Kansas.
    greencadillacmatt's Avatar
    greencadillacmatt is offline Cadillac Owners Connoisseur
    Automobile(s): '09 Dodge Challenger RT, '84 Cadillac CDV, '94 Jeep GC LTD
    Sep 2008
    Otsego,Michigan
    26
    2,239
    I thought that all of the 1985 and newer Olds 307's used a roller camshaft. http://oldsjunction.classicoldsmobil...IDEngineDetail 5th row down.
    77CDV's Avatar
    77CDV is offline Cadillac Owners 10000+ Posts
    Automobile(s): 77 CDV, 06 DTS III, 69 FWB
    Mar 2006
    Newbury Park, CA
    45
    10,021
    What viscosity to use depends on the expected temperatures the car will experience before the next oil change. Unless you're expecting boiling hot or arctic cold, 5W30 or 10W30 will suffice. Synthetic oil is a superior product for the reasons stated above, and I use it in all my cars. If you don't want to go to the trouble of running down marine oil, there are ZDDP additives on the market that can be used to augment the newer oil formulations.
    csbuckn is offline Cadillac Owners Master
    Automobile(s): 84 Coupe w/500
    Jan 2008
    Minneapolis
    5,612
    These 307s have roller cams. From what I've heard, if you have been using conventional oil and switch to a synthetic after X amount of miles, the slugde that synthetic eats away will expose detoriated gasket material behind it leading to premature gasket failure. I have always believed that you should stick with one type of oil. I could be wrong cause I'm no expert
    sven914's Avatar
    sven914 is offline Cadillac Owners Connoisseur
    Automobile(s): 1989 Brougham d'Elegance, 1985 Fleetwood Brougham *Coupe*
    Dec 2008
    4,256
    I've always used Castrol 5w30 High Mileage. The 307 was designed to run best, from an economical standpoint, on 5w30 oil. Switching to 10w## oil will give you better protection for the first five-ten minutes of a cold start, but 5w30 offers overall superior protection. Using a marine/diesel oil is an option to help clean your engine (diesel oil is designed for harsher conditions and has more cleaning detergents), but in cases of higher mileage engines, diesel oil can clean too well and cause loss of compression.
    Bro-Ham's Avatar
    Bro-Ham is offline Cadillac Owners Connoisseur
    Automobile(s): 1979 Sedan deVille d'Elegance
    Oct 2005
    Sarasota, FL
    49
    4,152
    I have 10W30 in my car right now but I had the oil changed at a different place than usual. My regular mechanic uses 10W40 for the car. For some reason I feel the 10W30 that is in the car is causing me to hear more ticking sounds than when I used 10W40 before. Is this my imagination? What is best for hot/humid Florida summers with highs in the mid 90's and lows around 80? What is good for mild Florida winters with highs in the 70's and lows around 45-50? My car is a 79 Sedan deVille, 88k miles.
  16. #14
    Sep 2006
    Ontario, Canada
    44
    7,904
    Good point on the roller/flat tappet issue! Guys, the ZDDP levels of oil have been steadily lowered for the past ten years. This is to protect catalytic converters. Old flat tappet engines, like the 80/81 368 and the 425 NEED a higher level of ZDDP than you can get in regular oil! This will protect the cam and lifters from wear. Best place to get what you need? GM. Go in, and ask for PN 88862586, GM Engine Oil Supplement.
    Bro-ham, if it were my car, I would run synthetic 5w40, with GM EOS added at fill time.
  17. #15
    Bro-Ham's Avatar
    Oct 2005
    Sarasota, FL
    49
    4,152
    Jay-son, Thanks! Will that make it run smooth as butter? The last time I used synthetic oil was a Rolls-Royce I had several years ago and the oil found every crevice to seep through. Hope my Cad retains synthetic better. I will try it! Dave
  18. Remove Advertisements
