| Re: 200 to 700 tranny swap I dont think it will need to be swapped. I have swapped a TH350 in place of a 700R4 before, and though it barley fit, I didnt even have to change the cross member for that either. But that too, is something that can be given a definate answer with a tape measure or once you get both trannys out, set them side by side, dead even with one another, if the the tranny crossmember mounts are pretty much exactly side by side, then you dont need to swap them. The tranny mounts have to come off anyways, when you go to install them under the swapped tranny, put the original crossmember in place, if it works, use it, if not, go grab the other and swap it. |
