RWD 19xx-1984 DeVille and Fleetwood, 1985-1996 Fleetwood and Brougham Forum Forum for discussions regarding the rear wheel drive Pre80s-1984 DeVille and Fleetwood, 1985-1996 Fleetwood/Brougham. | Cadillac Forums: Build: Cadillac 500cid
10-22-09, 06:25 PM
|  | Cadillac Owners Fanatic Cadillac(s): 1984 Coupe DeVille 1990 Brougham d'Elegance 350 | | Join Date: Sep 2008 Location: Otsego,Michigan Age: 19 | | | Re: Build: Cadillac 500cid How bad is the rust in the cylinder? Can you post a pic? If it is light enough rust you may be able to hone it. Good luck! |
10-22-09, 10:44 PM
| | Cadillac Owners Enthusiast Cadillac(s): 90 broughams | | Join Date: Jan 2008 Location: Minneapolis | | | Re: Build: Cadillac 500cid |
10-23-09, 02:14 PM
| | Cadillac Owners Fanatic Cadillac(s): 1982 Cadillac Coup Deville | | | | | Re: Build: Cadillac 500cid Quote:
Originally Posted by cadillac_al I have been having a hard time to find engine mounts too. All the parts places have the frame mounts listed as motor mounts but no actual engine mounts. Every Google search brings up hundreds of frame mounts but no engine mounts. I don't know what else they would be called. | The places I've asked for the non-rubber side of the mount (just metal), they said you'd have to go to a junk yard to pick them up. I'm assuming this is because it's a part that normally wouldn't need replacing whereas the rubber can go on the other half of the mount. |
10-23-09, 03:32 PM
| | Cadillac Owners Enthusiast Cadillac(s): 90 broughams | | Join Date: Jan 2008 Location: Minneapolis | | | Re: Build: Cadillac 500cid i was thinking that cadillac king guy would have some mounts. all those acres of cadillacs...he has to have something. i have a guy on my craigslist that has a 425 but he rejected my offer for the parts. maybe ill email him again |
10-23-09, 11:10 PM
| | Cadillac Owners Fanatic Cadillac(s): 1977 Coupe (blue), 1977 Coupe (yellow), 1977 Coupe (green) | | Join Date: Mar 2006 Location: Western Massachusetts | | | Re: Build: Cadillac 500cid What about the mounts that came with your 425? Would they adapt to your application? |
10-23-09, 11:53 PM
| | Cadillac Owners Enthusiast Cadillac(s): 90 broughams | | Join Date: Jan 2008 Location: Minneapolis | | | Re: Build: Cadillac 500cid yea, I got mine from the 425 and they work. Do the ones from the 368 work also? |
10-24-09, 10:39 AM
| | Cadillac Owners Fanatic Cadillac(s): 1977 Coupe (blue), 1977 Coupe (yellow), 1977 Coupe (green) | | Join Date: Mar 2006 Location: Western Massachusetts | | | Re: Build: Cadillac 500cid Not sure. Have zero experience with 368. There are similarities with all these blocks and they may intrchange. |
10-24-09, 04:01 PM
|  | Cadillac Owners Fanatic Cadillac(s): 1984 Coupe DeVille 1990 Brougham d'Elegance 350 | | Join Date: Sep 2008 Location: Otsego,Michigan Age: 19 | | | Re: Build: Cadillac 500cid Correct me if I'm wrong, but I believe that the 472, 500, 425, and 368 all use the same engine block, with different bores, strokes, and heads. The blocks are all physically the same. So it would make sense that the metal part of the mount should interchange between all of them. Just an idea. |
11-11-09, 10:31 AM
| | Cadillac Owners Fanatic Cadillac(s): 1987 Brougham D'Eligance, 1969 Calais Sedan | | Join Date: Sep 2009 Location: South Portland, Maine Age: 26 | | | Re: Build: Cadillac 500cid ^ That sounds correct according to what I've read |
11-19-09, 09:48 PM
| | Cadillac Owners Enthusiast Cadillac(s): 90 broughams | | Join Date: Jan 2008 Location: Minneapolis | | | Re: Build: Cadillac 500cid 000_0081.JPG
here she is, back from the shop. Got a 454 TBI too. But I got a couple questions. If I use the TH400, can I still use the digital speedometer? Also, is there a stock driveaxle that will bolt up to the TH400/500? Maybe one that can be shortened easily. The shop still has the heads and they'll probably need guides and a valve job. |
11-19-09, 10:23 PM
|  | Cadillac Owners Fanatic Cadillac(s): 2001 DTS & 1968 Sedan Deville | | Join Date: Dec 2004 Location: Glendale, Arizona Age: 27 | | | Re: Build: Cadillac 500cid Looks great, glad to see im not the only one with a black 500 block |
11-21-09, 01:59 AM
| | Cadillac Owners Member Cadillac(s): 1986 Fleetwood Brougham D'Elegance | | Join Date: Nov 2009 Age: 22 | | | Re: Build: Cadillac 500cid hey man ou have helped me out a couple of times and told me to watch this thread im post poning my build till I get my suttlement from disability, how much did it cost to get it looking so beautiful? |
11-21-09, 10:35 AM
| | Cadillac Owners Enthusiast Cadillac(s): 90 broughams | | Join Date: Jan 2008 Location: Minneapolis | | | Re: Build: Cadillac 500cid tanked, flux, decking, cyl hone, centerline crank/cam hone, cam bearings, frost plugs, drill extra oil drainback hole and paint for 200 at a small machine shop. |
11-21-09, 01:17 PM
| | Cadillac Owners Enthusiast Cadillac(s): 90 broughams | | Join Date: Jan 2008 Location: Minneapolis | | | Re: Build: Cadillac 500cid Also, has anybody ever welded the spider gears to make posi? I heard its easy and cheap |
11-21-09, 04:11 PM
|  | GM RWD V8 addict Cadillac(s): 81 FWB 2DR, 65 Impala, 95 SS, 71 Pontiac, 94 Caprice, 92 RMW | | Join Date: Sep 2006 Location: Ontario, Canada Age: 37 | | | Re: Build: Cadillac 500cid Wow! Great price. What's the heads/cam/pistons/intake that you are going with?
Oh, don't weld up your spiders. It will not be fun to drive on the street. That is for drag only cars. To be perfectly honest, you only need posi if you are going to be accelerating at full throttle from a dead stop on a regular basis. I have a posi in my SS, and it gets used, but never really use the posi in my Caprice wagon. All my other cars have open rear carriers, and they are fine. | | Cadillac Discussion Tools | | |
Censor is ON | | | |
