RWD 19xx-1984 DeVille and Fleetwood, 1985-1996 Fleetwood and Brougham Forum Forum for discussions regarding the rear wheel drive Pre80s-1984 DeVille and Fleetwood, 1985-1996 Fleetwood/Brougham. | Cadillac Forums: Build: Cadillac 500cid
07-02-09, 01:06 AM
| | Cadillac Owners Enthusiast Cadillac(s): 90 broughams | | Join Date: Jan 2008 Location: Minneapolis | | | Re: Build: Cadillac 500cid Sorry about that...
So would an oil pan from a 77-79 deville work or is it just 80-81? Right now it has a mid-sump pan. |
07-02-09, 11:22 AM
|  | GM RWD V8 addict Cadillac(s): 81 FWB 2DR, 65 Impala, 95 SS, 71 Pontiac, 94 Caprice, 92 RMW | | Join Date: Sep 2006 Location: Ontario, Canada Age: 37 | | | Re: Build: Cadillac 500cid Believe it has to be the 80 and up 368 pan. You could get the 368 until 85 in commercial chassis, as well. |
07-03-09, 12:43 AM
| | Cadillac Owners Connoisseur Cadillac(s): Cadillac 78 Seville, 78 Coupe de Ville, 92 Sedan de Ville | | Join Date: Feb 2007 Location: Maine Age: 48 | | | Re: Build: Cadillac 500cid I always heard the 77-79 425 pan and pick-up would work. Try a search on that because I'm sure I've read it several times. |
07-03-09, 11:44 AM
| | Cadillac Owners Enthusiast Cadillac(s): 90 broughams | | Join Date: Jan 2008 Location: Minneapolis | | | Re: Build: Cadillac 500cid Does anybody know where to get motor mounts for an 80 brougham/deville? New or used? I cant find them anywhere and theres no part cars around yet. Maybe someone here has a dead 368. |
07-03-09, 11:44 AM
| | Cadillac Owners Member Cadillac(s): Cadillac | | Join Date: Aug 2008 Location: Fort Lauderdale | | | Re: Build: Cadillac 500cid |
07-03-09, 12:08 PM
| | Cadillac Owners Fanatic Cadillac(s): 1982 Cadillac Coup Deville | | | | | Re: Build: Cadillac 500cid Quote:
Originally Posted by csbuckn Does anybody know where to get motor mounts for an 80 brougham/deville? New or used? I cant find them anywhere and theres no part cars around yet. Maybe someone here has a dead 368. | www.rockauto.com looks like them have them. |
07-03-09, 12:22 PM
| | Cadillac Owners Enthusiast Cadillac(s): 90 broughams | | Join Date: Jan 2008 Location: Minneapolis | | | Re: Build: Cadillac 500cid Quote:
Originally Posted by Slacker | I think I need the ones that are on the engine, not the ones on the frame. Are they called something different? MTS didnt answer the phone. |
07-05-09, 08:06 PM
| | Cadillac Owners Connoisseur Cadillac(s): Cadillac 78 Seville, 78 Coupe de Ville, 92 Sedan de Ville | | Join Date: Feb 2007 Location: Maine Age: 48 | | | Re: Build: Cadillac 500cid I have been having a hard time to find engine mounts too. All the parts places have the frame mounts listed as motor mounts but no actual engine mounts. Every Google search brings up hundreds of frame mounts but no engine mounts. I don't know what else they would be called. |
07-11-09, 02:08 AM
| | Cadillac Owners Enthusiast Cadillac(s): 90 broughams | | Join Date: Jan 2008 Location: Minneapolis | | | Re: Build: Cadillac 500cid So I got a parts car, 77 deville. The motor mounts look good. The oil pan looks like it will fit. Would the pass exhaust manifold work without any mods to the control arm? They look the same though. Also, I couldnt find the SPID codes on the trunk, are they somewhere else? I'm trying to see what gears are in the rear. |
07-11-09, 12:27 PM
| | Cadillac Owners Fanatic Cadillac(s): 95 fleetwood 81 deville | | Join Date: May 2003 Location: Massachusetts | | | Re: Build: Cadillac 500cid Your 77 rear end has 2.28 gears.. unless it has the towing package.. then it has 2.73's.....does it have disc brakes in the rear? the only rear I found with discs in the rear was a posi...almost every part you will need to put that 500 in that 90 FWB can be taken off that 77.... |
07-15-09, 12:17 PM
| | Cadillac Owners Enthusiast Cadillac(s): 90 broughams | | Join Date: Jan 2008 Location: Minneapolis | | | Re: Build: Cadillac 500cid I'm trying to figure out what tranny is in the 77, did it come with options or just a 400. |
07-15-09, 11:19 PM
| | Cadillac Owners Connoisseur Cadillac(s): Cadillac 78 Seville, 78 Coupe de Ville, 92 Sedan de Ville | | Join Date: Feb 2007 Location: Maine Age: 48 | | | Re: Build: Cadillac 500cid th400 |
07-18-09, 10:01 PM
|  | GM RWD V8 addict Cadillac(s): 81 FWB 2DR, 65 Impala, 95 SS, 71 Pontiac, 94 Caprice, 92 RMW | | Join Date: Sep 2006 Location: Ontario, Canada Age: 37 | | | Re: Build: Cadillac 500cid Devilles got rear drums. Fleetwood Brougham got discs in 77-79. |
07-28-09, 01:53 AM
| | Cadillac Owners Enthusiast Cadillac(s): 90 broughams | | Join Date: Jan 2008 Location: Minneapolis | | | Re: Build: Cadillac 500cid 100_7731.JPG
got the 425 out. didnt even mess up the front bumper like I planned. Had to lift he motor and push the car back because of the sand. Those dimpled exhaust manifolds look very restrictive. The frame mounts seem to be in a different spot on the frame than the 90s. They seen more toward the front on the car. Maybe I'll get some pics of it tomorrow. |
10-22-09, 04:29 AM
| | Cadillac Owners Enthusiast Cadillac(s): 90 broughams | | Join Date: Jan 2008 Location: Minneapolis | | | Re: Build: Cadillac 500cid So I got the 500 apart and all the pieces off the 425. There are a couple other things you would want to grab off a 425/368 like the heater connection on the back of the motor(90 degree angle instead of straight back towards firewall), oil filter adapter, pulleys and throttle cable brackets.
One of the cylinders on the 500 has some rust so I hope the machine shop can get it out with a hone job, pistons are not in the budget. I'll put some pics up tomorrow after work. The funnest part was getting the block in my car by myself but Im still alive. | | Cadillac Discussion Tools | | |
Censor is ON | | | |
