Go Back   Cadillac Owners Group > Past Cadillac Vehicle Discussion > RWD 19xx-1984 DeVille and Fleetwood,
1985-1996 Fleetwood and Brougham Forum
Forum for discussions regarding the rear wheel drive Pre80s-1984 DeVille
and Fleetwood, 1985-1996 Fleetwood/Brougham.
Cadillac Forums: How do I install a fuel pump on a '79 Deville?
Old 11-14-08, 08:20 PM
Benzilla's Avatar
Cadillac(s): 79 CDPhaeton, 90 Brougham, 79 CDV, 89 Brougham, 72 Eldorado
View Benzilla's Photo Album
Casino Cash: $6336
My Phaeton blew the fuel pump, now I need to replace it. How do I go about doing that? I've never replaced one before, and honestly, I don't really know what I'm getting into. Is it pretty straight forward, or are there any tricks to it? Any info would be great, I don't want to have to take it to the mechanic for this.
BTW, obviously, it's the 425.
Thanks,
Ben.
  #2 (permalink)
Old 11-14-08, 08:26 PM
My_favorite_Brougham's Avatar
Cadillac(s): Had to go bigger: '00 Silverado 3500 Crew 4x4 with the 454.
View My_favorite_Brougham's Photo Album
Casino Cash: $10382
Re: How do I install a fuel pump on a '79 Deville?
Yep it's real easy. You can get a new pump from Advanced, Autozone, etc. for about $50.
It's mounted on the front driver side of the engine block, just behind the fan and radiator and adjacent to the water pump. It's held on by two bolts (1/2" if I recall correctly). Then it pulls out of the block and the arm that sticks in there. Two rubber fuel lines plug into the bottom of the pump by hose clamp, and one metal fuel line which goes to the carb. Unscrew and disconnect those, and put the new pump in. Make sure you get it in right, so that arm is the way it was when it came out. Then re-screw everything back on. And fire away!
Also, don't do this repair will the back of the car uphill. The gas will pour out all over you!
Greg
  #3 (permalink)
Old 11-18-08, 01:05 PM
Cadillac(s): Cadillac
View Steves_Customs's Photo Album
Casino Cash: $310
Let me just add something to this. If I remember correctly, there is a push rod that may slide out of a hole in the block. This rod is in between the arm of the pump and the cam. It just hangs in there, so when you remove the pump, watch for that to fall out.
  #4 (permalink)
Old 11-20-08, 05:21 PM
Cadillac(s): 95 fleetwood 81 deville
View drmenard's Photo Album
Casino Cash: $4307
no push rod on these motors.. the pump arm hits right on the cam...
deville, fuel, install, pump
