Results 1 to 6 of 6
    Warren_R's Avatar
    Warren_R is offline Cadillac Owners Fanatic Cadillac(s) I Drive: 1989 Brougham D'Elegance
    Mar 2008
    SoCal
    57
    167
    Question blower issues / 1989 Brougham
    Hola Listeros,
    The blower on my '89 Brougham has an on/off habit of working. Either it's a normal blast of air; or none at all except at driving speeds of 30+ mph. There's a moderate airflow at that time, but none when idling or at slower driving speed. When started at normal idle, the air blows for about 4 seconds before slowing to a trickle.
    Has anyone had this happen before? If so, any idea as to what causes/caused it? I replaced the blower other day, no difference noted.
    I'm happy to note that otherwise she's a very well behaved Caddy
  2. Cadillac Network Advertisements Registered members do not see these ads. Click here to remove them.
    Always
    Advertising world
    2010
    Many
    longo's Avatar
    longo is offline Cadillac Owners Fanatic Cadillac(s) I Drive: 1992 sedan deville and 1989 Brougham deElegance
    Aug 2007
    Bruce Wi.
    53
    204
    Re: blower issues / 1989 Brougham
    Could be the AC power module. Facing car, located to the right of blower motor on top of evaporator case. 89 I bought, blower started working intermittently. My brother has the car in Vegas at the moment and he pulled the connector pack from the module, cleaned the connections and the ground and its worked normally ever since. Pricey part if replaced with new. About 2 bills at Rock auto. Heres a link to a picture.
    http://info.rockauto.com/getimage/ge...ts%5C35951.jpg
    Warren_R's Avatar
    Mar 2008
    SoCal
    57
    167
    Cleaning the connections is worth a try, at least!
    Is a special tool needed for cleaning inside connector holes? The price for an A/C power module makes the auto recyclers look like a fair bet, but dirty connectors sure look likely!
  5. Sponsored Cadillac Advertisements (Supporting Members don't see these ads):
    longo's Avatar
    Aug 2007
    Bruce Wi.
    53
    204
    No special tool needed. Brother just blew them out with compressed air. Check for a seperate ground wire, might be all that needs cleaning as well.
    Warren_R's Avatar
    Mar 2008
    SoCal
    57
    167
    OK, thanx for the info. I'll give the compressed air a try & use an eraser on any exposed areas like the grounding connection. There's a definite ground wire, so will be sure to clean that up as well.
    Thanks again, info is much welcomed =)
    Warren_R's Avatar
    Mar 2008
    SoCal
    57
    167
    I tried all the tricks mentioned, as it turns out the control module will need replacing
    ... on the upside, I found one for $160.00 at http://www.autopartsgiant.com ... crossing all fingers that will finally fix the prob.
Simply register and/or login to remove these advertisements.
  • You may not post replies
custom floor mats | cadillac performance mufflers | cadillac performance exhaust systems | racing seats | cadillac euro tail lights | cadillac air intakes | cadillac projector headlights | cadillac ground effects | cadillac floor mats | cadillac escalade body kits, hoods and lambo doors | cadillac body kits | cadillac carbon fiber hoods | air suspension kits | air suspension parts | air ride suspension | hyundai genesis forum | kia forte forum | used car savings
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183
