cadillac parts
Go Back   Cadillac Owners Group > Past Cadillac Vehicle Discussion > RWD 19xx-1984 DeVille and Fleetwood,
1985-1996 Fleetwood and Brougham Forum
Register FAQ Donate Calendar Mark All Cadillac Forums Read
Forum for discussions regarding the rear wheel drive Pre80s-1984 DeVille
and Fleetwood, 1985-1996 Fleetwood/Brougham.
Cadillac Forums: Exhaust Manifold Bolts
Old 05-11-08, 04:24 PM
v90hamm77 v90hamm77 is offline
Cadillac(s): 96 Fleetwood Brougham
Casino Cash: $2170
(Its a 96 FWB.) I'm about to get the driver's side manifold bolts and gasket replaced at the dealer. They said the labor fot the driver's side is $145 and the passenger side would be about $300 because there is more stuff to move or something. I'm just doing the driver's side because thats the only side I hear a leak on. The back bolt is missing a head and they say I might have to get another head if they can't get the bolt out. Only 122,000 miles on the motor, do you thank its that bad? Should I get dealer GM bolts and gasket or something aftermarket? I;ve looked at JEGS and couldn't find any. Thanks!!
  #2 (permalink)
Old 05-11-08, 09:14 PM
jayoldschool jayoldschool is offline
Cadillac Owners Enthusiast
Cadillac(s): 81 FWB D'Elegance coupe
jayoldschool's Avatar
Casino Cash: $4444
Re: Exhaust Manifold Bolts
Yes, go with grade 8 bolts, not the ones from the dealer. You can find them on ebay. If I were you, I would buy the bolts, then use one to see if you can put in in that rear hole and tighten it down. Often, the rear bolt just falls out. If you cant get it to go in (because the bolt broke off in the head), then that $150 is well spent. Having taken off manifolds to replace with headers, and extracting broken bolts, getting that done for that price is a no-brainer. The factory gasket is the best out there for a stock manifold (layered steel).
If they tell you they need to replace the head, just leave. Any good tech can get a broken bolt out, even if they need to weld a nut on it to back it out.
Just so you know what they have to do:
- remove all bolts (hard to get at)
- remove cat
- drill/extract broken bolt
Get them to cut out the spacer bar on the manifold when they are at it. There is a TSB on it that they can check. Cutting out the spacer makes the manifold less likely to crack. Check the manifold on the bottom. See how there is a bar between the front but not the back? It has been cut. If you buy aftermarket, they now come pre-cut.
  #3 (permalink)
Old 05-11-08, 09:42 PM
96Fleetwood 96Fleetwood is offline
Auto Enthusiast
Cadillac(s): '96 Fleetwood Brougham
96Fleetwood's Avatar
Casino Cash: $5608
Yep, no need to replace the head. They are crazy!
I need to fix the broken bolt on the driver's side manifold in the wagon. I might put the shortie headers from my Fleetwood on the wagon and then get long tubes for the Fleetwood... hmm....
*1996 Fleetwood Brougham*--slightly modified
http://www.cardomain.com/ride/2197169
  #4 (permalink)
Old 05-11-08, 10:53 PM
Casino Cash: $2170
I checked ebay an there are many kinds of bolts. What size are they? Here's the ebay page I was looking at.
http://motors.shop.ebay.com/items/ch...nifoldQ20bolts
  #5 (permalink)
Old 05-12-08, 09:57 PM
cadydaddy cadydaddy is offline
Cadillac(s): 94' Fleetwood, 95 RT/10 Viper, 2006 Honda XR650L.
Casino Cash: $1417
Go to another place, sounds like a rip off....big time.
My mechanic had to tap 2 new bolt holes and 3 more were broke off but came out and 3 were ok, and he charged me 300 total.
Go to a independent place.
vB code is On
d3 cadillac event
cadillac v-series performance cts-v, sts-v, xlr-v
Cadillac Automotive Concepts
cadillac air suspension parts
bud davis cadillac
cadillac wood grain dash kit
cadillac unlock navigation
cadillac high performance exhuast
cadillac merchandise
Powered by vBulletin® Version 3.6.10
hyundai genesis forum | cadillac performance mufflers | cadillac performance exhaust systems | racing seats | cadillac euro tail lights | cadillac air intakes | cadillac projector headlights | cadillac ground effects | cadillac floor mats | cadillac escalade body kits, hoods and lambo doors | cadillac body kits | cadillac carbon fiber hoods
