RWD 19xx-1984 DeVille and Fleetwood, 1985-1996 Fleetwood and Brougham Forum Forum for discussions regarding the rear wheel drive Pre80s-1984 DeVille and Fleetwood, 1985-1996 Fleetwood/Brougham. | Cadillac Forums: Convertible Top Issue
05-11-08, 12:32 AM
|  | Cadillac Owners Fanatic Cadillac(s): 1978 Cadillac Coupe Deville Le Cabriolet | | Join Date: Aug 2007 Location: Washington DC | | | Convertible Top Issue Now that the warm weather is rolling around, it's time to put the top to the '78 Le Cabriolet down. However, the motor needs repair, so it won't go down automatically. I know of a place to get it fixed, but will it cause any further damage if I manually open and close it? I feel like that would work for a while until I save up enough money to actually get it fixed. So, any ideas?
Thanks, Lee |
05-12-08, 08:09 AM
|  | Cadillac Owners Enthusiast Cadillac(s): 97 Deville Concurs,91 Geo Tracker 5spd 4WD Conv. | | Join Date: Jan 2006 Location: Staten Island NY | | | Re: Convertible Top Issue could you post some pics of the car please.  |
05-12-08, 05:04 PM
|  | Cadillac Owners Fanatic Cadillac(s): 1978 Cadillac Coupe Deville Le Cabriolet | | Join Date: Aug 2007 Location: Washington DC | | | Re: Convertible Top Issue Yeah, here are some. They are from last summer though, when the top still worked. http://picasaweb.google.com/L.Stopak...lleLeCabriolet |
05-15-08, 10:59 AM
|  | Cadillac Owners Enthusiast Cadillac(s): 97 Deville Concurs,91 Geo Tracker 5spd 4WD Conv. | | Join Date: Jan 2006 Location: Staten Island NY | | | Re: Convertible Top Issue O yea, thats what im talking aout, thanks looks good.  |
05-15-08, 04:00 PM
|  | Cadillac Owners Fanatic Cadillac(s): 1978 Cadillac Coupe Deville Le Cabriolet | | Join Date: Aug 2007 Location: Washington DC | | | Re: Convertible Top Issue So any ideas on the actual issue?? I just wanna know if it will hurt to put the top down manually |
07-03-08, 08:44 PM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | Re: Convertible Top Issue hi i see you have a 78 lecabriolet with a top problem do not put it down manualy you will rip the top. i own a 79 lecabriolet also had that problem when i bought it its a cheap fix the motor is $220 and the pumps are 150 each you should change all the hosses too just to be on the safe side hope this helps good luck. |
07-03-08, 10:14 PM
|  | Cadillac Owners Fanatic Cadillac(s): 1978 Cadillac Coupe Deville Le Cabriolet | | Join Date: Aug 2007 Location: Washington DC | | | Re: Convertible Top Issue Where did you purchase the motor and pumps?? The thing is it goes down well, but to put it up I have my brother hold the button and I'll push it about half way, then it takes it from there. And what kind of cost is it to have those pieces installed? |
07-03-08, 10:15 PM
|  | Cadillac Owners Fanatic Cadillac(s): 1978 Cadillac Coupe Deville Le Cabriolet | | Join Date: Aug 2007 Location: Washington DC | | | Re: Convertible Top Issue Also, show some pics of that baby!! |
07-04-08, 01:54 PM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | Re: Convertible Top Issue i installed them myself i have some pics on car domain i dont alot about computers so i have to learn how to put the pics. the install is not too hard you need to take all of the interior out of the back section the pumps are tricky cause the need to be adjusted but its all common scence the motor is in the trunk 4 screws and the hosses check maybe you just need the motor take the back seat out check for any fluid leaks if you have no leaks its just probably the motor or the motor might need fluid it has a rubber grommet take it off if fluid does not come out its low add some and check it. |
07-04-08, 04:19 PM
| | Cadillac Owners Connoisseur Cadillac(s): 1988 Allante' (sold), 1984 Eldorado 4100 91 Allante | | Join Date: Feb 2003 Location: california Age: 62 | | | Re: Convertible Top Issue Most convertable top hydrallic pumps have a fluid bypass lever or screw to turn to allow fluid to flow thru the hoses as you lower the top manually. Trying to lower it without doing this can hydrallically lock the assembly and may bend something? |
07-04-08, 07:19 PM
|  | Cadillac Owners Fanatic Cadillac(s): 1978 Cadillac Coupe Deville Le Cabriolet | | Join Date: Aug 2007 Location: Washington DC | | | Re: Convertible Top Issue Hm, then yea it's probably a good idea to get all those things changed. Being a golfer and not a mechanic I won't be able to install it myself, so there's an added cost there. Caddymike, where did you say you got the parts? |
07-05-08, 03:41 PM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | Re: Convertible Top Issue call me ill let you know everything 1646 739 5245 |
07-05-08, 11:14 PM
|  | Cadillac Owners Fanatic Cadillac(s): 1978 Cadillac Coupe Deville Le Cabriolet | | Join Date: Aug 2007 Location: Washington DC | | | Re: Convertible Top Issue Ok, thanks a lot. I'll give you a call sometime soon, whenever I get the time to do so  | | Cadillac Discussion Tools | | |
Censor is ON | | | |
