RWD 19xx-1984 DeVille and Fleetwood, 1985-1996 Fleetwood and Brougham Forum Forum for discussions regarding the rear wheel drive Pre80s-1984 DeVille and Fleetwood, 1985-1996 Fleetwood/Brougham. | Cadillac Forums: '96 Fleetwood struggles to fire cold. Anyone?
04-13-08, 11:06 PM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | '96 Fleetwood struggles to fire cold. Anyone? Hi,
I'm glad to find this forum. Lot's of great info here!
I'm having trouble starting my '96 Fleetwood Brougham when it's cold. It turns over fine, but takes 3 or 4 good spins to catch fire. After running for a few minutes though it will start up again no problem.
Anyone familiar with this?
My mechanic had it for 3 days and it started for him first time, every time. (Ain't that always the way.) He thought it might be the pass key and had me clean it with rubbing alcohol, but no help.
Any insight/advice is appreciated. |
04-14-08, 02:53 AM
|  | Cadillac Owners Enthusiast Cadillac(s): 1985 Cadillac Fleetwood Brougham d'elegance - 1969 Coupe DV | | Join Date: Sep 2006 Location: Santa Cruz, CA Age: 20 | | | Re: '96 Fleetwood struggles to fire cold. Anyone? my suburban does the same thing. i've been too lazy to investigate it. my theory is there's not enough pressure in the fuel lines to get it to fire right away.
let's see what others come up with. |
04-14-08, 03:36 AM
|  | Cadillac Owners Member Cadillac(s): 99 Deville Delegance 93 Fleetwood Brougham | | Join Date: Jan 2005 Location: St louis | | | Re: '96 Fleetwood struggles to fire cold. Anyone? I would suggest checking the fuel pressure to make sure the fuel pump is doing it's job properly. Have you changed the fuel filter yet?
If you have acess to a lift or can get your car high enough check the condition of the fuel sending lines to and from the pump will need
a small inspection mirror. the one on my 93 brougham were rusted up bad. had the dealer replace the fuel pump/sending unit/float assembly.
Hope this helps some. |
04-14-08, 08:49 AM
|  | Auto Enthusiast Cadillac(s): NONE | | Join Date: Jul 2005 Location: Downers Grove,IL Age: 29 | | | Re: '96 Fleetwood struggles to fire cold. Anyone? Welcome!
How many miles are on it?
Is it on the original plugs, wires, and optispark?
__________________ 1996 Cadillac Fleetwood Brougham "SS"- sold but not forgotten 1998 Lincoln Mark VIII- the daily driver 2002 Trans AM WS6 CE Convertible- the show car 2003 Infiniti M45-wifes daily driver |
04-14-08, 09:20 AM
|  | Cadillac Owners Master Cadillac(s): 94 Fleetwood Brougham | | Join Date: Aug 2004 Location: Rockford, IL Age: 42 | | | Re: '96 Fleetwood struggles to fire cold. Anyone? In every car I have ever had that did just as you describe, it was poor ignition (plugs, wires, cap/rotor). LT1's are known to be sorta hard on the ignition lead from the coil to the Opti.... "keep one in the glovebox" is what Scott Mueller used to say...
Tank also makes a good point which is why I feel the fuel pressure gauge is required in a EFI man's toolbox. Take that "issue" out....
You aren't running E85 now are you? E85 in an unmodified LT1 won't start cold well at all, IF at all. Modified PCM like I run, sure, easy and no problems.... I have probably close to 15K-20K on E85 now.....
PCM sensors. Bad or messed with IAT and CTS will do screwy things (like tell the PCM it is 80F out when it is 20F....). Datalogger is quick and easy test (they should read nearly the same at cold start, your mech should know this).
As for PASSKEY, look for the light staying on an unusual amount of time. If you suspect it, clean as he said, and try using the other key too. Passkey, aka VATS, can be disabled in the PCM tune if you really have issues with it. But clean the keys, run a q-tip with alky on it in the keyhole where the PASSKEY resistor is on the key. In all honesty it doesn't start like a PASSKEY problem, they just don't start..... |
04-14-08, 10:51 PM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | Re: '96 Fleetwood struggles to fire cold. Anyone? Thanks for your input. To answer questions; 112,000 miles... No ethanol... Wires, plugs, etc. replaced in the last year. I think that was it. My instinct says fuel filter or line, too.
I'll have to bring it back to the mech. I'll update after.
Thanks all.
Kevin |
05-09-08, 07:06 AM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | Re: '96 Fleetwood struggles to fire cold. Anyone? My 97 Deville (96,000 mi) does the same thing.
I recently replaced the fuel filter and got a new battery. Same problem.
Any updates on what the mechanic said? |
05-09-08, 10:01 AM
| | Cadillac Owners Fanatic Cadillac(s): 1995 Cadillac Fleetwood Brougham | | Join Date: Apr 2004 Location: Sunny Florida | | | Re: '96 Fleetwood struggles to fire cold. Anyone? It could be your fuel.
Many stations are selling E10 as regular fuel. And while E10 can be hard on engines not built to run E85 or ethanol fuel. The real problem is that many stations are watering down their fuel with ethanol and selling E10 with higher ethanol concentrations. Like the house watering down an alcoholic drink for profit. And while E10 is only marginally acceptable E10 with with higher concentrations of ethanol like 12% or 13% causes problems and damage. http://www.wesh.com/automotive/16200238/detail.html |
05-09-08, 10:46 AM
|  | Cadillac Owners Master Cadillac(s): 94 Fleetwood Brougham | | Join Date: Aug 2004 Location: Rockford, IL Age: 42 | | | Re: '96 Fleetwood struggles to fire cold. Anyone? If you drive a lot, no amount of Ethanol will hurt, but letting it sit, that can become problematic. It is the water in the ethanol that is the real issue, not so much the alky itself, as most fuel systems from the mid 90's up are make of most elements that aren't affected by Alky. Talked to our resident N* tuner and he said that there was a rash of problems when 10% alky became politically mandated (don't you love politicians screwing around with things they know nothing about??) and it caused untold millions of $$ in car repairs due to bad fuel pressure regulators and rust in the fuel lines plugging up fuel injectors and fuel filters. But now that we have been running it for a long time, it is much less of an issue, we have all paid the price somewhere.... water contaminated alky is bad news for sure, but isn't real common, and if it is, will be widespread problems in the area.
My 99 K2500 454 Suburban (that's 7.4L for you metric heads, affectionately known as the "guzzler") was getting crabby to start in the day and I found it to be RUST on the plug wire in the boot and the top of the plug. I have never seen. My "new" 00 Buick Park Ave Ultra had the same thing ony at the coils. I had to replace 2 coils and the wires to fix. Cleaning didn't cut it, I tried.
Oh, the plugs on the Burb were 6 months old and Autolite platinums. I am done with platinums. NGK TR5's for me... Nothing else. I am back to real plugs not the platinum junk.... It helps keep hot spots out of the chamber so pinging (even inaudible, but enough the PCM hears it) is eliminated and overall power is improved. |
05-09-08, 11:47 AM
| | Cadillac Owners Fanatic Cadillac(s): 1993 Fleetwood Brougham V4P | | Join Date: Nov 2007 Location: St. Louis, MO USA Age: 26 | | | Re: '96 Fleetwood struggles to fire cold. Anyone? Interesting. I wonder if I should fire up the Cadillac and drive it around more often. I sometimes go a whole month without starting it up. |
05-09-08, 11:51 AM
| | Cadillac Owners Fanatic Cadillac(s): 1995 Cadillac Fleetwood Brougham | | Join Date: Apr 2004 Location: Sunny Florida | | | Re: '96 Fleetwood struggles to fire cold. Anyone? I've got a slow drain, so if mine sits for a week or so, I have to charge up the battery. It's not a problem if I drive it everyday it's just been sitting lately because I'm waiting on my wood wheel. |
05-09-08, 02:51 PM
|  | Cadillac Owners Master Cadillac(s): 94 Fleetwood Brougham | | Join Date: Aug 2004 Location: Rockford, IL Age: 42 | | | Re: '96 Fleetwood struggles to fire cold. Anyone? I check for drains by putting my DVM in current mode in series with the battery cables and then start pulling fuses one by one till it stops, then dig deeper.... Start with the Maxi fuses under the hood, that gives a great pointer to the rest of the car where to look.
Just be careful you don't blow the meter by opening the doors and the dome lights come on and draw too much current, some meters will be damaged or blow fuses in the meter. |
05-13-08, 11:16 PM
| | Cadillac Owners Fanatic Cadillac(s): 1996 Seville STS | | Join Date: Feb 2008 Location: Pensacola, FL | | | Re: '96 Fleetwood struggles to fire cold. Anyone? Quote:
Originally Posted by Fat96 Thanks for your input. To answer questions; 112,000 miles... No ethanol... Wires, plugs, etc. replaced in the last year. I think that was it. My instinct says fuel filter or line, too.
Thanks all.
Kevin | What did you ever find out about your problem? Did you get it fixed? I am curious because I am experiencing the same problem with my 96 N* |
05-13-08, 11:31 PM
|  | Forbidden in Heaven and useless in Hell. Cadillac(s): 05 STS / 89 Fleetwood Brougham d'Elegance / 76 Coupe deVille | | Join Date: Dec 2003 Location: North Jersey Age: 23 | | | Re: '96 Fleetwood struggles to fire cold. Anyone? Quote:
Originally Posted by tenmark It could be your fuel.
Many stations are selling E10 as regular fuel. And while E10 can be hard on engines not built to run E85 or ethanol fuel. The real problem is that many stations are watering down their fuel with ethanol and selling E10 with higher ethanol concentrations. Like the house watering down an alcoholic drink for profit. And while E10 is only marginally acceptable E10 with with higher concentrations of ethanol like 12% or 13% causes problems and damage. http://www.wesh.com/automotive/16200238/detail.html | Hmmmmmmm..... This got me thinking about my problem.....
‡ DopeStar ‡  | | Cadillac Discussion Tools | | |
Censor is ON | | | |
