RWD 19xx-1984 DeVille and Fleetwood, 1985-1996 Fleetwood and Brougham Forum Forum for discussions regarding the rear wheel drive Pre80s-1984 DeVille and Fleetwood, 1985-1996 Fleetwood/Brougham. | Cadillac Forums: 77 coupe beltline/window 'wipes'/wthrstrip
04-06-08, 04:25 AM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | 77 coupe beltline/window 'wipes'/wthrstrip I am new here and just learnging to search the forum. I bought a new outer beltline weatherstrip/wipe for my 77 Coupe but it has a small chrome bead that would necessitate removing the original door ledge molding (integral to original wipe). Is there a way to install the new one without removing the original or is there a part number for this item that can be bought somehwere that is close to the original type?
many thanks |
04-06-08, 04:04 PM
|  | Cadillac Owners Enthusiast Cadillac(s): 1985 Cadillac Fleetwood Brougham d'elegance - 1969 Coupe DV | | Join Date: Sep 2006 Location: Santa Cruz, CA Age: 20 | | | Re: 77 coupe beltline/window 'wipes'/wthrstrip maybe take a picture so we can help you better? |
04-06-08, 04:37 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 77 CDV, 01 ETC, 06 DTS III, 69 FWB | | Join Date: Mar 2006 Location: Newbury Park, CA Age: 37 | | | Re: 77 coupe beltline/window 'wipes'/wthrstrip You might try checking hardware stores for rubber weatherstripping similar to the original. You'd then tack it on with screws or brads. I'd have to take my door apart to see exactly how this could work, but there's enough surface in the door structure to make this possible. BTW, where did you get this part? Best of luck.
Craig |
04-06-08, 07:04 PM
| | Cadillac Owners Fanatic Cadillac(s): '50 Hearse, '76 FWB, '79 SDV, '79 CDV, '80 Hearse, '80 CDV | | Join Date: Jan 2006 Location: Nova Scotia, Canada Age: 22 | | | Re: 77 coupe beltline/window 'wipes'/wthrstrip Exactly what I was wondering, 77CDV. I need the "window sweeps"/"bottom-of-window-weather strip for my '80 Coupe, too. Where did you acquire these pieces, kewpie?
Wonder if the '80 ones would be different from the '77-'79 coupes... |
04-07-08, 01:32 AM
|  | Cadillac Owners Connoisseur Cadillac(s): 77 CDV, 01 ETC, 06 DTS III, 69 FWB | | Join Date: Mar 2006 Location: Newbury Park, CA Age: 37 | | | Re: 77 coupe beltline/window 'wipes'/wthrstrip Don't quote me, but I think they'd be interchangeable. |
04-07-08, 01:49 AM
|  | Cadillac Owners Connoisseur Cadillac(s): Had to go bigger: '00 Silverado 3500 Crew 4x4 with the 454. | | Join Date: Apr 2006 Location: Texas A&M | | | Re: 77 coupe beltline/window 'wipes'/wthrstrip Yeah I need those too... except for an Olds, but they're the same as the old Caddies. I've never seen them anywhere, so that would be good news! Can you get them for the outside too? Alot get cracked from sunlight. (especially the old GM wagon's rear window rubber... but I don't mean to thread-jack.. haha)
Greg |
04-07-08, 07:26 PM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | Re: 77 coupe beltline/window 'wipes'/wthrstrip Bought the outer driver one from 1A Auto parts (on web.) It is xtra long and the holes for the factory screws are slotted to fit, but the original part was integral to the chrome window/doorledge while this replacement has a 3/16" chrome bead on it where it looks to overlap the door ledge.
I wass wondering if anyone had used these from 1A Auto before as I would not want to eliminate the original chrome trim on the beltline/door ledge. I suppose the 3/16" lip could be cut off, but that would take some careful cutting with a Dremel tool or something.
Someone had OEM ones for $80 each but I was told that these things are not as critical as one may think because some water will always get down into the door anyway. (These from 1A Auto are about 25$ ea. and they have them in sets for inner/outer as well.) I am thinking the 77-80 GM Coupes all had the same doors, i.e. Olds, Buick Cad, but would have to verify.
Thanks to all for responding.
Reason: spellling
04-07-08, 07:29 PM
| | Cadillac Owners Fanatic Cadillac(s): '50 Hearse, '76 FWB, '79 SDV, '79 CDV, '80 Hearse, '80 CDV | | Join Date: Jan 2006 Location: Nova Scotia, Canada Age: 22 | | | Re: 77 coupe beltline/window 'wipes'/wthrstrip Got my dad to check into this, who has worked at the back Parts Counter at Canadian Tire in Halifax, serving the mechanics since 1978.
It's the outside strips I'm looking for my '80, since the inside ones are good. I've got the GM part number for these outside 'sweeps' but the part is completely obsolete. However, some GM dealership might have 'em lying around somewhere. Dad's out right now but I'll get the part number from him and post it here incase you want to try your local dealership.
There aren't available through NAPA either. Wonder if any reproduction rubber places make these?? If so I'd be extremely interested. Right now water easily get inside my doors, and the windows make a squealing noise when in motion because they're not being held in place quite as tightly as they could be...  |
04-07-08, 07:32 PM
| | Cadillac Owners Fanatic Cadillac(s): '50 Hearse, '76 FWB, '79 SDV, '79 CDV, '80 Hearse, '80 CDV | | Join Date: Jan 2006 Location: Nova Scotia, Canada Age: 22 | | | Re: 77 coupe beltline/window 'wipes'/wthrstrip kewpie: I'd be interested in the OEM ones, even for that price if there weren't any alterations to be made.
Our dear friend Anthony responded to a private message I had sent earlier this week in regard to this same issue. He sent this link: http://www.1aauto.com/1A/Weatherstri...SK00156/484825
Is this the stuff you're working with, kewpie?
EDIT: Found these ones... appear to be the same as the 2 Door Fleetwood in measurements... are these the ones? http://www.1aauto.com/1A/Weatherstri...SK00156/484823
And could you snap a picture of these 1aauto ones? I want to see what is meant by the chrome bead, and can't really tell from the picture on the site.
04-08-08, 01:52 AM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | Re: 77 coupe beltline/window 'wipes'/wthrstrip Mine is numbered 1A-WSS-00027 on the tag stapled to the plastic sheat. Under the bar code it says "Replaces G2057."
The 'bead' is actually the 'lip' of the metal over which the rubber wipe is laminated. If you look at the INNER wipe on a Coupe, this item looks more like that inner wipe with the narrow lip that goes over the fake woodgrain on the door ledge.
I emailed 1A Auto but have not heard back from them. When I calleod them 2 months ago re: this item didn'tlook right i told them I wouldn't have time to put it on because of the weather here in Michigan and they told me to take my time and if I ddin't use it they would refund my money aslong as the part was not unwrapped.
I will call them tomorrow and see if they sent me the wrong part, altho this is not the INSIDE wipe because the felt 'spacer' in the center of the length of the item faces inward toward the window and this item must go on the OUTER side of the door/window.
Obviously, all their wipes have this chrome bead and they might know how to adapt it to the 77-79 Cadd w/o altering the original factory chrome piece on the door/window ledge.
I will try to respond tomorrow (later today actually) regarding what I find out. |
04-08-08, 02:37 PM
| | Cadillac Owners Fanatic Cadillac(s): '50 Hearse, '76 FWB, '79 SDV, '79 CDV, '80 Hearse, '80 CDV | | Join Date: Jan 2006 Location: Nova Scotia, Canada Age: 22 | | | Re: 77 coupe beltline/window 'wipes'/wthrstrip Thanks kewpie! Keep us posted.  |
04-09-08, 02:53 PM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | Re: 77 coupe beltline/window 'wipes'/wthrstrip I called 1A Auto parts and told them my problem. They said their replacement wipe had to replace the original chrome window strip (which is much wider than their chrome 'bead.')
I asked about their refund poicy and they said they would send me a label and an 'RMA' # so I could return the part and they would pay return shipping and then credit my credit card with the refund.
I will wait for the credit from them and re-post. Sounds so far that they are very good to deal with.
Now I will keep looking for a replacement part (!) If anyone finds a way to do it, let me know. |
05-12-08, 10:43 PM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | Re: 77 coupe beltline/window 'wipes'/wthrstrip Well, 1A Auto is supposed to be crediting me with a refund. I will keep everyone posted. (Sorry took so long, but have been away for a while.) |
05-13-08, 09:26 AM
| | Cadillac Owners Fanatic Cadillac(s): '50 Hearse, '76 FWB, '79 SDV, '79 CDV, '80 Hearse, '80 CDV | | Join Date: Jan 2006 Location: Nova Scotia, Canada Age: 22 | | | Re: 77 coupe beltline/window 'wipes'/wthrstrip Good to hear you're going to get your money back. A lot of places would take it and run, especially online. That's one point for 1A Auto, but it seems their product isn't quite what we're looking for.
I've already started checking big two-door GM's in my area and so far, every window sweep has been worse than mine. | | Cadillac Discussion Tools | | |
Censor is ON | | | |
