Go Back   Cadillac Owners Group > Past Cadillac Vehicle Discussion > RWD 19xx-1984 DeVille and Fleetwood,
1985-1996 Fleetwood and Brougham Forum
Forum for discussions regarding the rear wheel drive Pre80s-1984 DeVille
and Fleetwood, 1985-1996 Fleetwood/Brougham.
Cadillac Forums: Water on Passenger side Floor
Old 02-21-08, 02:44 PM
Cadillac(s): Cadillac
View bucanrs's Photo Album
Casino Cash: $674
I have a problem with my 1992 Brougham. there is water on Passenger side carpet on the firewall and down next to the trans hump. My mechanic has sealed everything poss. on the a/c system and it still is getting wet when I use the a/c.
What can it be?
  #2 (permalink)
Old 02-21-08, 02:55 PM
Cadillac(s): 1985 Fleetwood Brougham 1996 Cadillac Fleetwood Brougham
View elk9300`'s Photo Album
Casino Cash: $4571
Re: Water on Passenger side Floor
Sounds like a drain might be plugged. These usually sit under the heater core in the engine compartment.
  #3 (permalink)
Old 02-21-08, 11:29 PM
jayoldschool's Avatar
GM RWD V8 addict
Cadillac(s): 81 FWB 2DR, 65 Impala, 95 SS, 71 Pontiac, 94 Caprice, 92 RMW
View jayoldschool's Photo Album
Casino Cash: $17134
The drain elbow may be plugged or missing. Look on the passenger side firewall, down under the heater hose connections, sort of behind the wheel well. There will be a little fitting, and there should be a rubber 90 degree elbow on it that points down. If it is still there, pull it off, and make sure it and the fitting are clear. I'll bet it is gone. You can get another one, or just put long piece of tube on it that points down to the ground.
Here is a pic of one with the elbow where the owner added more hose so it doesn't drip on the frame:
  #4 (permalink)
Old 03-10-08, 01:54 PM
Casino Cash: $674
How high up the firewall is it? I can't seem to locate it.
  #5 (permalink)
Old 03-10-08, 02:14 PM
GM RWD V8 addict
Casino Cash: $17134
I just realized that you have a 92. The advice I posted was for the 93-up. I'm sure the 92s have a drain, too - I'm just not sure that it is in the exact same spot. Can someone else check? I can't open the hood of my 81 without moving one of my other cars...
  #6 (permalink)
Old 03-20-08, 10:39 AM
Casino Cash: $674
Does anybody have ideas? The botom of the floormat is wet like it has condesation on it.
Tags: , , ,
floor, passenger, side, water
