68 Deville posi rear end swap? - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 24 of 24
Like Tree2Likes
1985-1996 Fleetwood and Brougham Forum Discussion, 68 Deville posi rear end swap? in Past Cadillac Vehicle Discussion; Other are 3 basic diff types. Open has zero resistance and allows all power to go to one wheel if ...
  1. #16
    rodnok01's Avatar
    Feb 2012
    NC
    6,625
    Other are 3 basic diff types. Open has zero resistance and allows all power to go to one wheel if it's spinning.
    Limited slip has friction packs that attempt to equalize power between both wheels. It works good but under hjigh load/stress only one wheel will spin. Posi traction sends equal power to both wheel pretty much all the time regardless. It still allows a slight diff in wheel speed so you can corner.
    For most cars unless in the snow belt an open diff is fine. If you get stuck it sucks because only one wheel will ever spin. In the snow belt, limited slip will suffice most of the time. Posi traction is the gold crown diff option.
  2. #17
    LiQuid Explosion is offline Cadillac Owners Member
    Automobile(s): 1968 Cadillac Deville Convertible
    Jun 2010
    42
    10
    Little off topic and much later but does anyone think a 68 Cadillac Deville could tow a 14' Box trailer?
    I rebuilt my 472 to 8.5/1 compression and a RV Cam, Fuel injection etc. It also has a new 400TT with cooler and Front 13" Willwood brakes and 12" rear. Also Accuair air ride.
    I believe the car is probably stronger than most trucks. I was concerned about the rear end though. I understand it is pretty stout but, what does anyone think about towing with the standard gear?
    I am am relocating to FL from San Diego which I did with a Ram 1500 to San Diego. I'd rather not have the Caddy shipped again when it is more than capable of doing a trucks job. Unfortunately the truck was too much here so I sold it and I only have SRT8 as another car.
    I'm sure I would need a tow commander and it has load leveling.
    Anyone?
    Thanks
  3. #18
    the APEMAN is offline Cadillac Owners Enthusiast
    Automobile(s): 1980 FBC
    Mar 2010
    54
    536
    Re: 68 Deville posi rear end swap?
    I think it could do it with proper equipment if the trailer is under about 4700 lbs.
  5. #19
    Z71's Avatar
    Z71
    Z71 is offline Cadillac Owners Connoisseur
    Automobile(s): NONE
    May 2005
    1,379
    I got a 1965-79 Hollander Interchange in front of me and the Cadillac rear has no interchange except for another Cadi of similar vintage. 68-70.
    Fyi - Posi-traction is a Chevrolet brand name for its limited slip differential. Cadillac called it by another name, Controlled Differential.
  6. #20
    outsider is offline Cadillac Owners Connoisseur
    Automobile(s): 87 Brougham, 1969 Calais, 95 FWB, 05 CTS, 07 SRX
    Sep 2009
    Buxton, Maine, United
    33
    4,149
    depending on the weight of the trailer I'd say you'd be fine. those engines are real stump pullers.
  7. #21
    Jun 2010
    42
    10
    Quote Originally Posted by outsider View Post
    I agree the engine had ridiculous torque. Though with my new mods it is meant for gas mileage. It probably has around 400's in Tq now.
    I am worried about the rear though. 17' trailer and the WT of the car is 9700lbs if it is in fact 4700lbs restricted like someone else stated.
    I had a problem with a new Dodge Ram 1500 trans overheating going up the mountains east of San Diego. I had to turn around and sleep in Imperial Ca till it was cool enough 0430 in the morning. That thing is meant to pull too.
  8. #22
    TheStickman is offline Cadillac Owners Fanatic
    Automobile(s): 1996 Federal Heritage Hearse
    Jul 2015
    Allentown Pa
    103
    There is an option found in some mid 90's hearses and limos. That is the 14 bolt truck rear you mentioned. I have one in my Federal hearse. The mounts will be different I am sure. But the width should be close. It is a drum brake rear but the drums are huge. Not sure if they come in posi from the factory but you can get posi's for them. Mine has 4.10 gears and a tru trac diff.
    the APEMAN likes this.
  9. #23
    Mar 2010
    54
    536
    Man I'd love a 4.10 posi in my car for about 2 tanks of gas.
  10. #24
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    That'd be a fun 26 minutes.
  11. Remove Advertisements
